This week I put on the Wilwood big bore calipers. I got them bled and immediately had less pedal pressure when using the 7/8” G-Body manual brake master cylinder. The pedal almost went to the floor. I assume it is from the increased piston diameter over the Speedwaymotors.com “Big Bore” calipers (2.704” Wilwood v 2.565” Speedwaymotors/CCP) that I replaced. When driving with the Wilwood big bore calipers, I could pump the pedal 3 or 4 times and get the pressure I needed and would lock up the right rear tire and stop the car just like the other calipers. I suspect now I will need a 24mm bore G-body master cylinder (from a power, vacuum boosted G-body) and EE rated front pads to replace the FF rated front pads I have on the front now. The EE rated front pads have better “bite” when the rotor is colder. FF rated front pads have better “bite” when the rotor heats up. Since this is a street driven car, the EE rated pads should be a better choice and will match the rear EE rated shoes that are already on the car.
