Just an FYI.
The manual brake setup talked about in this thread uses the stock g-body manual brake configuration. The manual brake pin (stud), pictured in the pushrod linkage above, is pressed into a pre-drilled hole that is already in the stock vacuum power boosted pedal from the factory. There is no drilling involved with this setup.
