reading your build ( I replied in your other post also) . I see your wanting a budget daily driver. I am no LS expert , I have done several swaps and cam changes though. I work on a budget base also so I spend where needed. you will need a correct pan and mounts. I use HOLLEY exclusively now. spend your money once .
