#492085 - 10/12/07 01:57 AM Dyeing Door Panels - Oxblood
jac1599 Offline
jac1599  Offline
Bartlesville, OK
I'm willing to bet that the majority of you guys have faded door panels. Well, if everything but the color of yours is in good shape, it seems kind of dumb to shell out $150+ for a replacement set. Here are the steps I took to restore mine:
Dyeing Door Panels
___________________________________________________________________
Materials Needed:
1. "Wine" color RiT fabric dye - Wal-Mart
2. Old wash cloth
3. Faded door panelso
Picture - Materials:
Instructions
1. Clean door panels. Don't want to trap any dust or other trash.
2. Fold the wash rag into fourths and using your index and middle finger put the rag over the dye and tilt upside down for a split second so that a little bit of dye stays on the rag. The spot of dye should be about the size of a quarter.
3. Using the same two fingers begin to apply the dye to the very top of the door panel (right at the window felt). Use a circular motion so that the dye is applied to all sides of the material. This amount of dye is good for about 3-4 columns (in between stitching).
Picture - application:
4. After you've applied dye to the top, move down about an inch and use the same circular motion. DO NOT REAPPLY DYE unless the fading is so severe that it goes down further. In this step we are blending the dye because it is not a 100% perfect match.
Picture - progress comparison:
5. Continue to work slowly, blending as you go.
6. Be sure to wipe off any dye that gets on the trim piece for the window felt.
Results:
Before:
After:
As it dries it lightens up and blends much more evenly.
1987 SS, 355 TPI and a work in progress
#604644 - 09/11/08 12:40 AM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
jrdrag Offline
jrdrag  Offline
Erie, PA
Just a heads up, that dye is not permanent. I just tried this on my door panels and after drying two days it wiped right off with a damp cloth. I can only imagine how my GF would react if that was her good white shirt. It did look 1000x better but be careful, it does come off.
Caleb Peterson
#800463 - 06/07/10 06:10 PM Re: Dyeing Door Panels - Oxblood [Re: jrdrag]
gwssmonte Offline
gwssmonte  Offline
VA beach/ Nyc
Has anybody else tryed this dye ??? Also do you think it can be used on the top of my rear seats????? Thanks for your input ahead of time....
#800697 - 06/08/10 05:25 AM Re: Dyeing Door Panels - Oxblood [Re: gwssmonte]
under-aged boss Offline
atlanta, ga
has anybody tried dying maroon panels to black?
#802829 - 06/16/10 12:47 AM Re: Dyeing Door Panels - Oxblood [Re: under-aged boss]
jrdrag Offline
jrdrag  Offline
Erie, PA
I put this stuff on the door panels and the tops of the back seats. Looked Great. Problem is it never dries. I wiped mine off before anyone got it on their clothes.
Caleb
Caleb Peterson
#803057 - 06/16/10 09:54 PM Re: Dyeing Door Panels - Oxblood [Re: jrdrag]
Snowboi Offline
Snowboi  Offline
Fort Walton Beach, FL
Just paint them, the paint will dry. You can use the dye on stuff like the rear package tray, or you can put it on anytrhing, you just cant touch it after you dye the parts.
I guess you can consider dying parts if you plan on entering a car show for a prize, and you dont want to buy new parts.
#895909 - 09/20/11 09:24 PM Re: Dyeing Door Panels - Oxblood [Re: Snowboi]
Beachbum Offline
Beachbum  Offline
Clearwater, Florida
Has anyone tried taking off the seat upholstry covers and dyeing them in the washing machine like you would with clothing? Just curious!!
#904527 - 11/19/11 04:13 PM Re: Dyeing Door Panels - Oxblood [Re: Beachbum]
elcaminobill Offline
Greenville, SC
I think what makes this dye permanent is very hot water. What I thought of doing was to mix up a batch with near boiling water and spraying it through a paint gun. Of course you would want to remove whatever you dye and be careful not to get it too wet.
#917280 - 02/08/12 07:01 AM Re: Dyeing Door Panels - Oxblood [Re: Snowboi]
redfaced88 Offline
redfaced88  Offline
Knoxville,Tn
There is an upholstery dye called simply spray. Rustoleum also makes one. Both specifically for these types of applications
#967208 - 04/01/13 07:52 PM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
toastedoats Offline
toastedoats  Offline
Fitchburg, MA
I used Dupli-Color Vinyl and Fabric Coating which I picked up at AutoZone http://www.duplicolor.com/products/vinylFabricCoating/
I am quite impressed with the results, the seats and door panels look brand new aside from a couple spots where you can see some wear in the fabric. The only prep work I did was vacuuming all of the loose crap off of the seats and scraping off a couple crusty spots then went to town taping and spraying. Incredible results for 2 hours and $12 investment.
Before (Right) and After (Left)
Both Seats done. The left only looks lighter because it is in the sun, they are really a perfect match
Got the 2 front seats done and the upper door panels before I ran out of paint
-Aaron-
1986 Monte Carlo SS, 2002 Nissan Maxima , 2010 VW CC
#970397 - 05/02/13 02:03 AM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
dw329 Offline
dw329  Offline
Beersheba Springs, Tn.
looks good
#978492 - 07/22/13 12:10 AM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
monte_man_2020 Offline
Lisle, IL
I've used the spray paint on nearly ALL interior pieces and either chipped off the plastic parts or 'dusts' of the fabric. Did I do something wrong toastedoats? On the plastic, was it that I should have used wax/tar remover first?
#978824 - 07/26/13 12:19 AM Re: Dyeing Door Panels - Oxblood [Re: toastedoats]
stickyfingers Offline
winnipeg manitoba
That dye paint worked mint for me 2.
Thx 4 the tip.
#979040 - 07/28/13 11:06 AM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
SKIDMARK Offline
SKIDMARK  Offline
New Bern NC
To get the paint to stick 1st clean the plastic parts with dish derergent (DAWN) rinse and let it dry. 2nd use a degreaser spray to make sure all the little crevaces have no old oil residue (armor all) 3rd spray with a quality adhesion promoter 4th apply several light coats of your color of choice. You may need more coats if your changing the color. Try not to handle the parts for about one day.
I have not tried fabric paint but Im sure that if you follow the manufactures instructions it will work out just fine.
#989022 - 11/28/13 06:41 AM Re: Dyeing Door Panels - Oxblood [Re: toastedoats]
Skillsz87ss Offline
Skillsz87ss  Offline
wichita KS
"looks nice have you ran into any problems with it since im thinking of doing this to my 87 but in black.."
#989052 - 11/28/13 03:04 PM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
Bad86SS Offline
Bad86SS  Offline
Kentucky
SEM 15063 is a great spray for us. Damn near perfect
#992703 - 01/17/14 04:41 AM Re: Dyeing Door Panels - Oxblood [Re: toastedoats]
Amp Offline
Amp  Offline
Fitzgerald GA
pm sent , seats look good
#992708 - 01/17/14 04:58 AM Re: Dyeing Door Panels - Oxblood [Re: Skillsz87ss]
Amp Offline
Amp  Offline
Fitzgerald GA
how many coats did u put on the seats and
#992843 - 01/19/14 02:36 PM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
sswalt Offline
sswalt  Offline
San Francisco, CA
Always used SEM interior paint with great results
#992850 - 01/19/14 05:02 PM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
JMonte7892 Offline
JMonte7892  Offline
Baltimore, MD
How does black look?
#998760 - 03/30/14 02:19 PM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
darriuSS Offline
darriuSS  Offline
South, NJ
What color is it that toasted oats used?
#1035971 - 03/06/16 05:20 PM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
GotGrunt Offline
GotGrunt  Offline
Long Island, NY
The burgundy interiors look amazing but it's crazy how bad they fade if left in the sun. The spray looks like an easy way to bring it back.
#1038277 - 04/24/16 03:38 AM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
Lostcause87 Offline
Lostcause87  Offline
Lumberton, NJ
How well do you think this would work to turn a grey part oxblood?
#1050523 - 05/02/17 03:33 AM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
Smokin88 Offline
Smokin88  Offline
Lakeland, MN
I dyed my upper door panels answer they turned out great and the dye dried. Now I'm not saying that the dye will come off if it gets wet from a little rain or something. Just need to be careful around the chrome pinstripe on the panel as mine discolored and wanted to peel.
#1057459 - 05/27/18 09:27 AM Re: Dyeing Door Panels - Oxblood [Re: jac1599]
Lisle, IL
Thanks Skidmark. After all these years, I never got back to it. I did trade up (some may disagree) to the 87 aerocoupe. I will be freshening up the oxblood interior and follow your instructions. Interior is all orginal and going to keep it that way this time 😁
500/thumbs/306537_10151142014953465_994827867_n.jpg
by adi
500/thumbs/CH220175compressed.JPG
by John S
500/thumbs/SS_on_22_inch.jpg
by G-bodySS
1130/thumbs/ResizedImage_1390834191345.jpg
by O.G.
500/thumbs/IMG_0552.JPG
by montesleeper83
