#965334 - 03/16/13 05:50 PM Exhaust Cut Outs
CocaColaPistola Offline
Lawrence, KS
Anybody have exhaust cut outs on any of their montes. If so, which do you guys prefer, the manual or electrical? Thinking about throwing some on my 85.
#965347 - 03/16/13 07:34 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
88ss408 Offline
88ss408  Offline
miramichi, NB
i have a set of 2.5 cut outs on my 84. i have the manual ones as i did not think the electrical ones would last if exposed to too much water and all that.
1988 monte carlo ss 408 sbc 11:1 compression a.f.r.195cc heads accel ignition system comp cams .507/.510 air gap intake 800cfm edelbrock carb th350 trans 3000 stall torque headman headers 3" dual super 40's 3.73:1 limited slip
1984 monte carlo cs 400,headers,th250c,air gap intake
#965355 - 03/16/13 08:14 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Lawrence, KS
Thanks for the reply!
#965361 - 03/16/13 09:19 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
JMonte7892 Offline
JMonte7892  Offline
Baltimore, MD
I was thinking about getting some. From what I hear, electrics aren't that bad.
#965367 - 03/16/13 10:51 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Ben Meyer Offline
Ben Meyer  Offline
Four Oaks, NC
I had a cut-out welded into a flanged test-pipe which I replaced the converter with. I put a quick-time electic cut out on it and ran the switch below the dash. Being able to open and close it with the push of a button beats the crap out of having to crawl on your back and do it. Most of the parts on the electric cut-out are stainless and last a while. Keeping it greased up helps as well. Mine lasted about 5 years before I sold it and it is still working for the guy I sold it to 3 years ago. I'm doing the same thing on my next SS.
PWRHOUSS
87 SS, Glasurit Black, ZZ4, Edelbrock TES(Jet-Hot),MSD 6A, 3" TT exhaust(Jet-Hot), Flowmasters 40,Quadrajet w/Jet stage 2 rebuild
#965387 - 03/17/13 03:35 AM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Slackerzinc Offline
Slackerzinc  Offline
Saint John, New Brunswick
Do electric/manual cut outs leak? I was always under the understanding they always leak, and the removable plates where the way to go
#965396 - 03/17/13 01:00 PM Re: Exhaust Cut Outs [Re: Slackerzinc]
rons87mcss Offline
rons87mcss  Offline
PA
^^^^^^ I was wondering the same thing. It's hard enough sometimes to get two properly sized pipes together without a leak. Seems like a simple flapper would surely leak(?)
#965446 - 03/17/13 08:14 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Ben Meyer Offline
Ben Meyer  Offline
Four Oaks, NC
Mine leaked a tiny bit. Not enough to hear inside the car, but if you were right beside it underneath the car, you could hear a slight leak. There is just no way a flapper could ever completly close the exhaust off the way a bolt on plate would. Keeping the high temp grease around the edges and on the butterfly valve really helped though. If you want zero leaking then get a bolt on. I wouldn't have traded mine in a million years for a bolt on though. I guess it is up to you. Here are a couple pics of mine.
PWRHOUSS
#965452 - 03/17/13 09:32 PM Re: Exhaust Cut Outs [Re: Ben Meyer]
Lawrence, KS
Thanks for the info and pics Ben. Nice Monte!
#965577 - 03/18/13 11:48 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. Forget the brand name, but there are also mufflers available that the internal baffle flips out of the way at WOT...
#965620 - 03/19/13 04:34 AM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Bad Co Offline
Bad Co  Offline
Earth
Doug's Headers electric cutouts don't leak. But they are big $$$.
#965622 - 03/19/13 05:22 AM Re: Exhaust Cut Outs [Re: CocaColaPistola]
84ss355*4spd Offline
Edmonton,AB,Canada
I have a set of 2.5 electric cut outs frm quick time performance. no leaking and easy to install. paid 400 i think with shipping . love them.
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#965624 - 03/19/13 05:23 AM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Edmonton,AB,Canada
86 ss gone
85 ss new
85 z28 tpi
#965626 - 03/19/13 05:25 AM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Edmonton,AB,Canada
86 ss gone
85 ss new
85 z28 tpi
#965683 - 03/19/13 11:36 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
xitabl442 Offline
xitabl442  Offline
St. Henry, Ohio
I have a set of QTP 2.5in on my 442. They are about 5-6 yrs old and I haven't done a thing to them and they still work great. Here's some pics of my set up that dumps out the side in front of the rear wheel . I have since changed them to straight out the header with the 45 going to the X before the cutout. I also have a pair of turn-outs on the cutouts. With cutouts after the X it sounded like it had open manifolds and not headers. I had made the spiral baffles as the short cherry bombs were still very loud. I have since hung a pair of modified C5 Corvette mufflers under it with dual pipes on each side. Sorry, no pics of the newer setup installed.
Live your life like an exclamation, not an explanation. Remember, it only has to be perfect.
#965711 - 03/20/13 03:50 AM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Edmonton,AB,Canada
If you can weld you can install them yourself. i have mine right after the collector on my long tube headers. going to put little turn downs on cut out flange soon. Ill look for pics and try to post them.
86 ss gone
85 ss new
85 z28 tpi
#965741 - 03/20/13 01:38 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Lawrence, KS
Thanks guys, appreciate all the replys. Spring needs to hurry up and get here!
#965757 - 03/20/13 04:18 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
JMonte7892 Offline
JMonte7892  Offline
Baltimore, MD
Amen to the above statement.
Are summit electric cutouts any good?
#965772 - 03/20/13 07:10 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
tall t-top Offline
tall t-top  Offline
San Antonio, Texas
There are also the flowtech warlock mufflers that have a removeable cap that lets the exhaust blow right through them.
Andrew
#968896 - 04/16/13 03:34 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
Jakey87SS Offline
Jakey87SS  Offline
Grand Rapids MN
I have a pair of QTP cutouts also for My 87 and I have no idea where to find a switched 12v source. Help?
#968899 - 04/16/13 03:53 PM Re: Exhaust Cut Outs [Re: CocaColaPistola]
SSeabee Offline
SSeabee  Offline
Wilmington, DE
Fuse panel under left side of dash has an available switched connection. I believe it is labeled IGN, or something like that. I used it for my elec. fans.
#968957 - 04/16/13 11:21 PM Re: Exhaust Cut Outs [Re: Bad Co]
NYmonteSS Offline
NYmonteSS  Offline
Brentwood N.Y.
X's 2, these will never leak!!
About the best cutout on the market!
#969460 - 04/22/13 03:02 AM Re: Exhaust Cut Outs [Re: Jakey87SS]
RenoReno2 Offline
RenoReno2  Offline
Chicago, IL
Cigarette lighter works too
88 Monte SS
500/thumbs/33740_436649656670_631466670_5657902_1034745_n.jpg
by smooth ss
1056/thumbs/IMG_17191.JPG
by Jeff wida
500/thumbs/Crash_Bandicoot_002.JPG
by Dave84
500/thumbs/Super_Power.jpg
by SPR-PWR
500/thumbs/sleeping_on_the_job.jpg
by 87/88 SS's
