Page 1 of 4 1 2 3 4
#963041 - 02/23/13 04:02 PM new weather stripping question?
Rodney Offline
Rodney  Offline
Jackson, MO
Anyone got new weather stripping for their car recently? I should just need it for the doors and trunk. Curious about what brand is the best and where you've found the best prices.
Rodney
87SS Silver/Gray w/t-tops 17X8 Foose Nitrous II's, 350 w/serpentine setup, Stainless steel exhaust, custom leather interior with f-body front seats, embroidered headrests & rear seat, hood & trunk liner.
http://www.cardomain.com/ride/519099/1987-chevrolet-monte-carlo
#963046 - 02/23/13 04:11 PM Re: new weather stripping question? [Re: Rodney]
www.mikesmontes.com I used factory on my car, don't know if that is still available. Good luck.
#963059 - 02/23/13 07:52 PM Re: new weather stripping question? [Re: Rodney]
carloss Offline
carloss  Offline
Burnaby, BC
I would use GM for the doors if you can afford it. Nothing else seems to fit right.
Rt Dr Lower #20277448
Lf Dr Lower #20277449
Rt Dr Roof Rail #20737658
Lf Dr Roof Rail #20737659
http://www.ebay.ca/itm/NOS-78-88-MONTE-C...#ht_1116wt_1163
#963083 - 02/24/13 01:00 AM Re: new weather stripping question? [Re: Rodney]
Justino Offline
Justino  Offline
Ellicott City, MD
I bought these, they were cheap and I'm poor so it worked out. Looks good, fits good, easy install. No complaints here.
(outer only)
http://www.partstrain.com/store/details/...de-comma-_Outer
(outer and inner)
http://www.partstrain.com/store/details/..._Inner_Or_Outer
(trunk)
http://www.partstrain.com/store/details/...M71MW00101.html
#963098 - 02/24/13 02:38 AM Re: new weather stripping question? [Re: Rodney]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
$199 9pc door and trunk kit ---door seals roofrail seals-- inner and outer door sweeps --and trunk seal
www.mikesmontes.com
1-800-811-5851
#963152 - 02/24/13 05:30 PM Re: new weather stripping question? [Re: Rodney]
Rodney Offline
Rodney  Offline
Jackson, MO
Are those GM or something else?
#963154 - 02/24/13 06:00 PM Re: new weather stripping question? [Re: Rodney]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
soffseal --Gm are good but this kit would cost almost $1000 Gm
www.mikesmontes.com
1-800-811-5851
#963156 - 02/24/13 06:10 PM Re: new weather stripping question? [Re: MikesMontes]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
MIke got any nos lower door seals??
#963184 - 02/25/13 12:19 AM Re: new weather stripping question? [Re: Rodney]
From my experience, aftermarket roof rail seals work okay, but only GM door seals fit right. Aftermarket door seals have incorrect end pads that do not mesh right with any brand of roof rail seal. You also can't get a correct seal with bad door hinges.
#963185 - 02/25/13 12:49 AM Re: new weather stripping question? [Re: Rodney]
carloss Offline
carloss  Offline
Burnaby, BC
I believe the drivers side door seals are now discontinued by GM
#963186 - 02/25/13 01:44 AM Re: new weather stripping question? [Re: Rodney]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
couple sets in stock
www.mikesmontes.com
1-800-811-5851
#963369 - 02/27/13 12:20 AM Re: new weather stripping question? [Re: Rodney]
Joe b. Offline
Joe b.  Offline
west haven ct.
soft seal are very good and fit well to.
custom paint 383 stroker 450hp 700r4 trans posi rear
#963373 - 02/27/13 01:04 AM Re: new weather stripping question? [Re: Buick Runner]
kevins88ss Offline
kevins88ss  Offline
Southern Maine
x2
#963390 - 02/27/13 04:13 AM Re: new weather stripping question? [Re: Rodney]
tmos87 Offline
tmos87  Offline
Canton TWP MI
I haven't been around for a while but for what it's worth, I used Soft Seal weather strips...I glued plastic to the back of the door seals where they screw to the rear of the door. Kind of like the factory parts...Keeps them from tearing at the screw holes...overall I'm very happy with the fit and function of both upper and lower seals. I got them to fit...but good hinges are a must as stated above.
#963419 - 02/27/13 02:26 PM Re: new weather stripping question? [Re: Rodney]
Rodney Offline
Rodney  Offline
Jackson, MO
Thanks for all the info guys.
#963430 - 02/27/13 03:40 PM Re: new weather stripping question? [Re: Rodney]
runupfront Offline
runupfront  Offline
Eatonton, GA
I got Soffseal lower door seals for my 86 Monte and they don't fit the doors. Was a real bummer.
Pete Scuderi
1986 AeroCoupe
#963612 - 03/01/13 03:30 AM Re: new weather stripping question? [Re: Rodney]
Flyith2 Offline
Flyith2  Offline
Greencastle pa
Id try to find factory replacements. Mine have lasted for 28 years now and there isn't any problems. My dad has a 72 chevelle ss and got new weather weatherstripping for that and it was very expensive and didn't fit 100 percent right. Like 86 ttop said, check mikesmontes.com they have some nice stuff
#963688 - 03/01/13 07:39 PM Re: new weather stripping question? [Re: Rodney]
Hi Folks,
Interesting that over the years, the reports about Soffseal have been all over the map - from "they fit like a glove," to, "they didn't fit at all." This seems to suggest that part-part variation is high. Since mold cavities tend to be very consistent, this seems to suggest high variation in material, which can, among other things, affect shrinkage after extraction from the mold.
I'm curious if anyone has further insight here.
#964219 - 03/06/13 01:55 AM Re: new weather stripping question? [Re: Rodney]
phils_super sport Offline
creedmoor,nc
I bought the whole soffseal kit.I didn't have a problem with the fitment on the hood,trunk or doors.but its been about 4 years and now the door seal are starting to break apart a little bit at the seam.also I have problems with the t-top seal around the top of the window where their not thick enough.if you can go original thats the way i'd go.
#964233 - 03/06/13 05:01 AM Re: new weather stripping question? [Re: Rodney]
carloss Offline
carloss  Offline
Burnaby, BC
It's interesting that GM shows a different part # for Regal/Cutlass door weatherstrips than Monte Carlo/ Grand Prix and Soffseal only shows one for all g-bodies. Maybe there's a slight difference and the soffseals are more universal resulting in less than perfect fit.
Here are the Monte Carlo PN's:
Here are the Regal/Cutlass PN's:
Rt Dr Lower #20201221
Lf Dr Lower #20201220
#964252 - 03/06/13 04:00 PM Re: new weather stripping question? [Re: MAP]
Originally Posted By: MAP
Hi Folks,
Carlos: I always suspected something like that, that kind of things is a very big problem with using aftermarket brand parts. They tend to label generic, universal fit parts as correct fit when they really are not. Like FRAM's incorrect spec PCV valves that they sell for our cars.
This will probably make some mad, but I suspect most of the "good" reports are from people who don't know how the door should seal. My lower door Softseals, the end pads were not even remotely the correct shape to mesh with the roofrail seals. The end pads just pushed the glass and the roof seal out of alignment causing a gap and a hard to close door. One of the big factors is that the end pads on the GM seals have a nylon reinforcement plate molded into the end pads. Softseal and Metro seal don't have the backing plates which is why they tend to rip out from the screw holes, they just don't hold their shape. Sometimes the aftermarket just sells us pure trash.
#976597 - 07/01/13 03:48 PM Re: new weather stripping question? [Re: Buick Runner]
aeromonteSS Offline
aeromonteSS  Offline
Erie, PA
Just installed a set of Softseal door seals. Horrible fit - the washer ripped out of the super thin end and I had to stretch the hell out of that end to even get it close to the factory screw hole (door jam with latch assembly end). The quality of the seal seems nice and the plastic fasteners line up great, but the end caps are like a generic universal fit that do not fit at all (actually the end closest to the door hinges fit pretty good - it's the other end you see when you open the door that's not even close to a good fit).
Any other reproduction brand that fits more like OEM????
I heard that Metro are good, but who knows..
Anyone try these? They are expensive for after market but still less than GM ones..
http://www.gbodyparts.com/product_info.p...54980563fdd9fb4
1987 Monte Carlo SS Aerocoupe
#976629 - 07/01/13 11:37 PM Re: new weather stripping question? [Re: Rodney]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
hint Trimparts make no seals at this time --(you would get the same part in a red bag instead of blue)
www.mikesmontes.com
1-800-811-5851
#976639 - 07/02/13 01:09 AM Re: new weather stripping question? [Re: Rodney]
robert87ss Offline
robert87ss  Offline
Lakeland,FL
anyone try steele rubber?
1987 Monte Carlo SS Pontiac powered project
too much time not enough money
#976653 - 07/02/13 10:38 AM Re: new weather stripping question? [Re: Rodney]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
steele is metro rebagged
www.mikesmontes.com
1-800-811-5851
Page 1 of 4 1 2 3 4
500/thumbs/32578_625642206218_37705991_35767420_7392210_n.jpg
by fordguy
611/thumbs/Thruster_in_park.JPG
by StripedSS
933/thumbs/On_the_Trailer5.JPG
by Sherdep
728/thumbs/Moneyshot.jpg
by THEmean1
500/thumbs/DSCF0445_edit.jpg
by LAJ
