H
HyperV6 Online Content OP
OP Online Content
H
I'm looking for a 2.5" header back exhaust system with x-pipe with stock exit Monte SS tail pipes. What system fits and works good? Any suggestions?
Thanks, Craig
I bought the Pypes exhaust and found it poorly engineered and ill fitting. Pypes refused to do anything about it so I returned it to Summit for a refund. Do not recommend
Im running 3" torgue tech, fits great.
I got the pipes from the headers to the "X", to the mufflers.
Im not running tail pipes at the moment.
If you have some extra coin and like flow master, then I would recommend their kit. I put one of the first ever G-body kits they offered on my old 84 Monte SS. It didn't fit well and gave them info to correct their front pipes. I just installed the same kit on my 86 SS and it fit much better. It's high quality parts: full mandrel bent stainless pipes band clamps for joining sections, X-pipe, Super 44 mufflers, and nice tail pipes to finish it off.
http://www.jegs.com/i/Flowmaster/389/817457/10002/-1?parentProductId=
86 Monte Carlo SS T-top
69 Cutlass S Convertible
12 Cadillac CTS-V Wagon
I agree the flowmaster system is a very good fit. I just installed the American Thunder cat back system in my 87 MCSS kit was well thought out even came with stainless steel tips and Super 44's plus all hangers and clamps.
Y
Y
i have the pypes kit. it does not fit well out of the box, you need to make a few cuts in strategic spots in order to make it fit well. i installed everything myself in my driveway, located the cats and mufflers where i wanted them, then took the car to an exhaust shop to finish the welds. i love it. good quality bends, welds are nice and it sounds great. i also like the slash cut on the quarter exit tailpipes, but you wouldn't have to worry about that with bumper exits.
'79 Monte Carlo: LQ9/4l60/8.5”
'08 Mitsubishi Mancer GTS
Torque Tech all the way. i have the 3" SS style on my monte with SLP LM1 mufflers. i recommend sectioning the exhaust. install a set of 3" flanges after the X-Pipe so you can drop the center section down incase you need to pull out the trans. makes things so much easier
I have the Pypes catback sys , not impressed with tailpipes fitment at all , other than that nice sounding stainless sys
Hi what engine are u running that require 3" exhaust pipe! Or this for stock engine!
K
K
I installed my Pypes with the Race Pro mufflers and X-pipe with band clamps and it worked out great. Good fit and great sound. Been running that way for years.
Hi' Do you have the stock engine" I am interested in the Pypes Race pro and system, right now i have true dual exhaust, and it time to change. Are you running with 3" inch? Have you ever heard of Gibson MWA?
I see no reason for 3" unless you have a high HP engine. From what I see Pypes offer a 2 1/2" which is more than enough. Just my 2 cents.
E
E
I go with flowmaster I installed many of this kits on g body cars never had a problem Guys in my club have Pypes not happy very poor design
K
K
Interesting. Mine went on fine. Been on for years. I installed it myself in the garage with band clamps. Only thing a shop had to do was set up the two ends that went to my headers. Mine run straight out the back stock style.
I will be upgrading to 1 7/8'' LT's and 3''( currently 1 3/4'' with 2 1/2'' w/ x pipe ) . I have been looking at the HOLLEY kit , as I will be using their LT's and I used their swap mounts. any one out there used them yet? btw, I have a bigger cu.in. build going on.
16,069 Registered Users
