#928823 - 04/20/12 06:38 AM FI fuel tank/non-FI fuel sender wire?
86_SS Offline
86_SS  Offline
League City, TX
getting ready to install the fuel tank in my 86. I noticed both tanks I have are for the fuel injected G-bodies. Both tanks have the baffels and both sending units are for the electric fuel pumps.
The sending unit has a 3-wire weather pack
(pump +, ground, fuel gauge) <--i assume
My wiring harness is a single pink wire.
Will it work correctly if I just connect the pink wire to the fuel gauge wire on the sending unit? TIA
#928836 - 04/20/12 01:27 PM Re: FI fuel tank/non-FI fuel sender wire? [Re: 86_SS]
Duts87SS Offline
Duts87SS  Offline
Spanish Fort, AL USA
That will work just fine. I'd still put a matching weather pack on the cars in case you want to go FI later.
Dustin
87 SS
#929013 - 04/21/12 11:24 PM Re: FI fuel tank/non-FI fuel sender wire? [Re: Duts87SS]
baaboo Offline
baaboo  Offline
Racine, WI
Yes.
#929454 - 04/25/12 02:01 AM Re: FI fuel tank/non-FI fuel sender wire? [Re: 86_SS]
LM7monteSS Offline
LM7monteSS  Offline
Kingston Springs TN
Would you like to sell the other tank and sending unit you are not using?
86 SS t-top 5.3 4L60E
#929535 - 04/25/12 03:57 PM Re: FI fuel tank/non-FI fuel sender wire? [Re: LM7monteSS]
86_SS Offline
86_SS  Offline
League City, TX
I can't right now.. my brother is looking at putting FI in his Cutlass and might be needing it
#929598 - 04/26/12 01:09 AM Re: FI fuel tank/non-FI fuel sender wire? [Re: 86_SS]
LM7monteSS Offline
LM7monteSS  Offline
Kingston Springs TN
No problem just thought I'd ask
500/thumbs/Monte_Drop_Spindles.JPG
by 85RESTOSS
500/thumbs/79_and_84SS3.jpg
688/thumbs/l_619513f50c2a3391323ff09f4b35de59_2_.jpg
by Vondross
1050/thumbs/Monte_Carlo_006.JPG
by BaerMonteSS83
500/thumbs/monte_tanner_pk_.jpg
by NYmonteSS
