#926869 - 04/07/12 12:36 PM
Re: The SickSpeedMonte 3/26/12
[Re: SickSpeedMonte]
Loc: MD
Top
#926885 - 04/07/12 02:04 PM
Loc: St Charles , Mo
Well done Bernie !!! I’ve never had a car you could push the clutch in that easily . One of the reasons I don’t have one , old and bad knees . I only drove sticks for years . You and Adam are both a trip , don’t change , I enjoy it ……. Hey , I love that dash . If something comes up and you don’t like the out come , which I doubt !! If you need a new one and Ron doesn’t want it , I have one , we’ll talk .
_________________________
 OUT OF THE DARKNESS RIDES THE DARK HORSE ... " HEY - O " ... LET THE HORSES RUN 502 HP, 383, Coan 350 Extreme, GV overdrive, Currie 12 bolt
Top
#927119 - 04/09/12 07:44 AM
Loc: MD
Seems like one step forward, two steps back. I went to pull the car back in the garage and heard a loud metal on metal bang when the engine fired, and another when it shut down. I fired it back up to see if I could track it down, and noticed the crank pully wobbling. So I removed the pully and rigged up a dial indicator to see what the runout was.    A good 20 thousandths of runout, so I guess it's time for a new pully. Removing the pully allowed me to remove the cover for the timing marks that was on the damper, and then I noticed that the outter ring of the damper was loose from the inner hub, and could be spun as it screwed on or off the hub... so I pulled that.   So I need a new damper. This one was like 2-3 years old, Summit brand. I guess I'll be going with ATI this time around. That's gonna hurt the car fund  IDK if the cover might have prevented air flow on the damper and it got hot or what, but the next damper will have timing marks engraved on it so I don't have to use the cover. In the process of removing the damper, I managed to gack up the threads in the crank like a total idiot, so that's going to have to be drilled out to 1/2" more than likely. If you pay close attention to the pictures, you can probably figure out my bonehead move.
Top
#927254 - 04/09/12 09:55 PM
[Re: 1 Slow SS]
Loc: Abingdon, Maryland
AHA I KNEW the noise was in the accessory area!... unfortunately it a little bit of a pricey fix. Theres alot of nice small block balancers floating around- I'd look used before buying new
 LsX: DO IT~ 11.32 @120mph
Top
#927900 - 04/14/12 06:53 AM
Loc: Louisville, KY
Hell Bernie, you can feel mine wobble a little with your finger when the engines running. Just turns some old v-belts, I wouldn't worry about it. I also have one of those covers on a stock balancer and haven't had any issues for the couple years it's been on there.
84 Monte SS stolen September 2012. 077 DFE Jefferson County KY plate. $2500 reward. Vortec headed 350ci, th350, 3:73 limited slip, Autometer gauges, Pro-Stick, 2.5" fiberglass hood.  Matt
Top
#927901 - 04/14/12 07:31 AM
[Re: 84supersport]
Loc: Mableton, GA
Man. See that puller in....bad bad boy. I used sevral summit balancers all did the abot same length of time. Ati
Top
#928015 - 04/15/12 10:30 AM
[Re: pazzo1969]
Loc: MD
Adam and Doug (Sixtoes and sicmonte) came over yesterday because Doug was in the area. We had a little shop day and got a stock balancer installed. Thanks to Mark (benchseatracin) for the screamin deal on the balancer!! The new bolts that I got weren't threaded far enough and the shoulder would have hit the threads before the balancer was seated. The stock bolt went back in after cleaning up the thread, and torqued to 60 ft-lbs. I might still get a 3" bolt and see if the shoulder isn't too long to install that. The pulley still wobbles a bit, but the balancer doesn't wobble at all so that's good news. Can't wait for the next shop day with my bros! We are planning a get together/car show/shop day at doug's shop at a date TBD, but probably after mother's day (and the OC cruise). Anyone is invited
Top
#928016 - 04/15/12 10:37 AM
Loc: Woodbine, MD
Adam and Doug (Sixtoes and sicmonte) came over yesterday because Doug was in the area. We had a little shop day and got a stock balancer installed. Thanks to Mark (benchseatracin) for the screamin deal on the balancer!! The new bolts that I got weren't threaded far enough and the shoulder would have hit the threads before the balancer was seated. The stock bolt went back in after cleaning up the thread, and torqued to 60 ft-lbs. I might still get a 3" bolt and see if the shoulder isn't too long to install that. The pulley still wobbles a bit, but the balancer doesn't wobble at all so that's good news. Can't wait for the next shop day with my bros! We are planning a get together/car show/shop day at doug's shop at a date TBD, but probably after mother's day (and the OC cruise). Anyone is invited Yes anyone on these boards is invited...but they have to show up in a hot rod!! And yes I consider a modified monte a hot rod...lol. If all goes well there should be some wicked pro-touring and race cars coming.
Edited by SicMonte (04/17/12 10:53 AM)
why list my mods...the car speaks for itself...and scares old ladies and children.
Top
#929213 - 04/23/12 12:17 PM
[Re: SicMonte]
Loc: MD
Top
#929307 - 04/23/12 11:37 PM
[Re: SS Ninja]
Loc: Small town USA
Well it's got a good look through the windshield. Kinda reminds me of the mid 90'S F body's. I would like to add my constructive  ..... I would remove the pointed edges that meet into the door panels. That whole outward sloped end on each side of the dash should be inverted. Then it would conform into the door panel reveal better IMO. And free up those window switches a bit.
Top
#929314 - 04/24/12 12:00 AM
[Re: 1 Slow SS]
Moderator 10+ Year
Loc: North Jersey
Well it's got a good look through the windshield. Kinda reminds me of the mid 90'S F body's. I thought the same thing when I saw that pic. I would like to add my constructive  ..... I would remove the pointed edges that meet into the door panels. That whole outward sloped end on each side of the dash should be inverted. Then it would conform into the door panel reveal better IMO. And free up those window switches a bit. Nice idea! Since you're glassing it anyway, it's probably easy enough to cut it back 1-2" and make a gentle curve instead of the triangle point that it has now.
Top
#932902 - 05/21/12 09:05 AM
Re: The SickSpeedMonte 5/21/12
Loc: Colonial Beach, Va
I think Anthony had to do the same thing to his car.
Top
Moderator: 85_SS, Dalt10, Gruvin84SS, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, Z65_Paul
by Big E's 83SS
by 85montanezcarloss
by 86AeroDave
by bigal
by Turbo5
Site Contributors
in the last Month:
ronnie84ss
BADD87SS
Monte_ExpreSS
Steve Lane
notsocleverusername
jwc55
