#921447 - 03/03/12 03:04 PM
SS Aerodynamics and cooling.....
Loc: NY
I've been researching aerodynamic enhancements for the SS and have read and been told about a couple of things that may or may not make sense. Here are several of the things I've either been told or read about; - Block off the grill, It would clean up the air flow on the nose of the car and allow it to transition smoothly over the nose.
- Open up the airbox in front of the chin spoiler and allow all radiator cooling airflow to enter from under the car
- install functional hood vents to vent engine compartment air
Another item to consider is the airflow over the rear of the car. As anyone with an SS knows the rear of the decklid gets dirty very quickly. This is indicative of a turbulent low pressure zone on the rear of the car. I've been considering the addition of vortex generators on the roof above the notch window like these, Vortex generators SO, has anyone else considered any of these items or have actual experience with them?
_________________________
1986 Monte Carlo SS, 427 SBC, Edelbrock Victor 'E' manifold, FAST 1375 CFM TB FAST XFI T56 6spd, Moser M9 3:70 SC&C G5,, Spohn Tubular A arms, Pirelli P Zero 275-40x17 rear, 245-45x17 front
Top
#921457 - 03/03/12 06:03 PM
Re: SS Aerodynamics and cooling.....
[Re: John S]
Loc: Fort Walton Beach, FL
Only thing I can consider, is to use headlight covers and turn signal covers on the SS.
To answer your question, no, havent had enough experience modding the airflow/aerodynamics.
Good luck.
Thanks, Richard. MC SS 1986 Monte Carlo SS, 5.7 355, Edelbrock intake, Holley 4160, 2004R with TCI lock-up, headers, 3" dual-40's Flowmasters
Top
#921470 - 03/03/12 08:17 PM
[Re: Bad Co]
Loc: Newburyport , MA
Taping up the grill comes from Nascar. You have to be at a high rate of speed or else the engine is gonna get hot real fast.
America, Love it or leave it
1999 GMC Sierra Z71 5.3- 6000K Hids, tinted, cranked, LT's 1969 Camaro Yenko clone- 383-461hp, Lemans blue 1971 Pontiac Trans Am- 455 4speed street machine
Top
#921485 - 03/03/12 09:14 PM
[Re: Mnt86ss]
Loc: Colonial Beach, Va
John, Although I have no experience with the linked parts, most of that stuff is junk, if it seems too good to be true, it likely is.
Top
#921493 - 03/03/12 10:08 PM
[Re: 86ttop]
Loc: NY
to: mnt86ss, it's all about balance. All my research indicates that there is more than sufficient airflow available from under the car provided you have fans capable of flowing the correct amount of CFM, all other airleaks are sealed and you can vent the engine compartment. An example of venting the engine compartment can be taken from the GNX's fender vents.
Leo, Like you I am very skeptical of things. There is a lot of information about vortex generators out there though and I've even read some reports published by NASA on their use in aircraft. One of the things I will be doing is to perform what is called the a yarn puff test. This simulates a windtunnel. I may try a couple of the air tabs just to see what affect they have.
Top
#921499 - 03/03/12 10:51 PM
[Re: John S]
the 2+2 I have is open under the nose, like regular cars back then.
Top
#921530 - 03/04/12 08:39 AM
[Re: 86ttop]
Loc: Jacksonville, Fl.
I've been a aircraft mechanic for a while and they do have vortec generators in the intakes of fighter jets. One in each one. It's worth the try but I really don't think it will do what you are looking for.
 1984 SS, w/87 Grand National 2004R, 355 vortec, CCC, Crane XE262, true 2 1/2 duals w/h pipe & hooker aero chamber muflers 1969 Road Runner 2003 GMC Serria 1998 Pontiac GTP Supercharged
Top
#921596 - 03/04/12 05:08 PM
[Re: cj84ss]
Loc: little egg harbor nj
told you my thoughts by phone + my mind is still burning lol
Pres. Wicked Rides car club,member of NJMCC,NYMCC 1983 Monte Carlo Convertible white, 1983 Monte Convertible red 1983 Monte Convertible white, 1983 monte convertible white 1957 Chevy 85 SS, 86 SS 8,272 miles www.wickedmontes.com www.wickedridesnj.com
Top
#921624 - 03/04/12 08:02 PM
[Re: tonys57chevy]
Loc: NY
I too am skeptical but there really is only one way to find out. Perform a yarn puff test before and after installing a few of them to see if there is any difference. Am I going to be the one to do it.... maybe , maybe not. Right now I have other things to get done, but if I ever do I'll let you know how it turns out.
More importantly to me right now is the front end and affects on cooling.
Top
#921678 - 03/04/12 09:54 PM
[Re: John S]
Loc: Maerngo.IN
I race stock cars and a dirt modified. The stock I have was using a 99 Monte body from fivestar. But I help several teams that use the 80-88 monte body. And now I am being forced to use it too thanks to the higher class getting cancelled! Taping the grill will make the air go up and over causing down force. we also tape the seams/gap between the fenders and hood with tape. We try to sneak by with as much gap between the hood and windshield too pull the air out of the engine bay. We tweak the fenders so that the front lowers sections are out further than the rear. all this creates suction or low pressure under the hood. That low pressure pulls that car down low at speed. Lowering your car will have a similar effect. We are restricted by frame and valance(bottom of nose and side skirts) heights.
One thing a found with my second SS is that there are 2 different spoilers. I never knew before! Believe it or not but the laid back version will give MORE down force! Found this out with the mod. The angle of most spoilers are extreeme and are used in a stall position. next warm day stick you hand out the window at 55. try different angles and you'll see the shallower angles will push harder down! That older style spoiler may be the reason for the dirt collection!
The link parts look a lot like our naca ducts we use to draw in air for cooling of brakes and even drivers. I couldn't say much about them since I havent tried them. Aero is an art. The guys that are the best seem to be able to see air. I have used the yarn trick myself.
About the air turbulence behind the car...Good aero for a race car is meant for something very different than a street car. If your trying to get a slicker car for top speed you would benefit from different mods than one looking for handling. Gas mileage seekers would be another story. Watch a few youtube videos of dirt late models. Look for ones on a dusty track. And watch the air go nuts directly behind the car! Even at 25 mph through the pits they will kick up something fierce!
Top
#921684 - 03/04/12 10:09 PM
[Re: John S]
Loc: Bristol, VA USA
I've been considering the addition of vortex generators on the roof above the notch window like these, Vortex generators SO, has anyone else considered any of these items or have actual experience with them? I work for a semi trailer manufacturer. Certain customers order these to be installed at the very end of the sidewall and roof of there trailers to redirect the air flow from wrapping around the back doors. But these things are small and it takes one about every six inches. Im no expert, but it appears these would have to be installed at the end of the quarter panels at the taillights to work.
1987 Monte Carlo SS 5.3 4L60E
Top
#922100 - 03/07/12 01:13 PM
[Re: SickSpeedMonte]
Loc: Grand Prairie, Tx
Slightly off topic, but I had an Aero professor that told us a little story about early Boeing wings. If you look and see the little "shark fins" sticking up on the top surface of the wing, those are there because the original design was not stable enough as designed, but it was not discovered in time to change the design. Back then, it was a different process of design, test on model scale, finalize design, start production, and it wasn't until the early production phase that full scale planes were built that revealed the problem. The shark fins disturb the air flow to keep it from transitioning hard at certain speeds/angles of attack etc.
Long story short, these types of aero devices can go a long way to band-aid a problem, but aren't a substitute for a good design to start with. Unfortunately, we missed the boat on a good initial design on most of our cars...
Top
Moderator: 85_SS, Dalt10, Gruvin84SS, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, TPI Monte SS
by Dalt10
by doughboy24
by PB86SS/87LS
by Hamburgerler1987SS
by BORICUA
Site Contributors
in the last Month:
ronnie84ss
BADD87SS
Monte_ExpreSS
Steve Lane
notsocleverusername
jwc55
