#887177 - 07/27/11 11:37 PM rocker arm/pushrod problem
Atl_Monte Offline
Atl_Monte  Offline
Atlanta, GA
I've run into an issue while trying to select the proper pushrod lenght for my 95 LT1. First off the first problem I ran into was I told I need to upgrade my rocker studs due to the extra lenght on hte stud for the roller rockers, so I did this and ran into my first problem the bottom portion of my aftermarket studs were to long and bottomed out in my aluminum head before properly seating so the store gave me some washers that corrected this problem so onto my current problem of trying to determine proper pushrod lenght the stock rod appears a little to long as the tip of the rocker is not hitting dead center of the valve tip but when I try to use my pushrod length checker set on a shorter rod the bottom of the roller rocker housing comes in contact with the base of the rocker stud, if seems if I didnt have the washers under the studs I'd have a few more thousandths of clearance....but for now I'm stuck at a stand still not sure which direction to go it seems the fix would be ot find some rocker studs that are meant for roller rockers but not guidplates...
1988 Monte Carlo SS fully customizedm, cowl hood, Kandy paint w/ ghost flames, power sunroof, 24" rims 327 SB - SOLD
1986 Monte Carlo SS 350 create motor, cowl hood, shaved handles & trunk, power sun roof, digital dash
http://youtu.be/aKZI0FhUP6U
1984 H/O Cutlass lightning rods 8.5" rear LT1 and C5 brake conversion under way 24" rims
#887256 - 07/28/11 12:30 PM Re: rocker arm/pushrod problem [Re: Atl_Monte]
Joe87monteSS Online thumbs
Joe87monteSS  Online Thumbs
Memphis,TN
A few questions:
Are these factory aluminum LT1 heads?
Are you using guideplates?
Which stud did you get, the one for guideplates or without?
Were the heads milled, or the block decked?
You shouldn't have needed to change the studs for roller rockers.
Joey
Engine/head builder/machinist
2004 Silverado
Facebook
#887266 - 07/28/11 02:08 PM Re: rocker arm/pushrod problem [Re: Joe87monteSS]
Atl_Monte Offline
Atl_Monte  Offline
Atlanta, GA
I wasn't thinking I needed to change the studs either but most forums I read suggested it. Yes these are factory aluminum heads, I didn't have the block or heads milled not to say the machine shop didn't do it No I'm not using guide plates though I believe the the studs they gave me were intended to be used with them hence the need for the washer under nest them and the comment made by the sales person that most aftermarket studs were intended for use with guide plates :-/
#887347 - 07/29/11 12:21 AM Re: rocker arm/pushrod problem [Re: Atl_Monte]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. The rocker usually doesn't touch the valve in the middle of the stem to start with, but slightly toward the rocker from center, then halfway through lift, moves past center to away from rocker, then at max lift, back across center and toward rocker again... hopefully, this info will alleviate what's causing your concern...
.. You didn't specifically say it, but I'm assuming you thus have the self-guiding rockers... and the matching retainers/valves that allow the valve tips to stick up sufficiently for the rockers to guide on them... and checked retainer to seal clearance/valve spring coil bind for the lift of the cam being used?
#887377 - 07/29/11 03:36 AM Re: rocker arm/pushrod problem [Re: BuzzLOL]
Atl_Monte Offline
Atl_Monte  Offline
Atlanta, GA
Yes I have self aligning rockers and I'm trying to determine the correct pushrod length
550/thumbs/small118.JPG
by stonecoldtim
500/thumbs/IMG_0390.JPG
by PrinceJay
by GearedSS
500/thumbs/Monte_Radio.jpg
by Chevyman540
500/thumbs/after2.jpg
by 87/88 SS's
