#876353 - 05/29/11 03:34 PM TV Cable Adjustment Help
johnz138 Offline
johnz138  Offline
Sterling Heights, Mi
I need help adjusting the TV cable on my monte. My repair manual makes no sense to me. I have the stock TV cable, holley 4160 carb and the holley throttle bracket. and the holley kickdown bracket.
Book says to depress the re-adjust tab and move the slider back through the fitting, away from the throttle body, until it stops against the fitting. Release the re-adjust tab.
Then, open the throttle to the full throttle stop position and then release it. This will automatically adjust the TC cable.
So, I pressed the button and slid the piece back into the fitting (that's being held in place by the bracket). I then let go of the button, and turned the carb throttle linkage all the way open and let go. Is that slide piece suppose to come out some when I have the throttle opened up? Cause mine doesn't. It just sits all the way into the fitting.
1987 Monte Carlo SS, Lightning Rod equipped, engineless/2004-R,Holley carb, edelbrock intake, heddman headers, moog,Iceman crossmember, energy suspension, eibach springs,so much more,no computer/emissions.
wave
#876375 - 05/29/11 06:32 PM Re: TV Cable Adjustment Help [Re: johnz138]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
Adjustments and install
http://www.tciauto.com/Products/Instructions/instructions/gm_tv_cable_adjust.htm
http://www.cpttransmission.com/tech_tvcable.htm
http://www.bowtieoverdrives.com/Instructions/QuadraJet%201902-1903-1904-1905-1906.pdf
http://monstertrans.com/store/news/7/700R4%2C-2004R-Adjustable-Throttle-Valve-Cable-Instructions.html
Can't quite get the last link to work. You can copy it into your address bar and press enter
#876379 - 05/29/11 06:51 PM Re: TV Cable Adjustment Help [Re: MattsMonte]
johnz138 Offline
johnz138  Offline
Thanks for the sites. I do that but I dont get no clicks, like its not adjusting.
wave
#876428 - 05/29/11 10:38 PM Re: TV Cable Adjustment Help [Re: johnz138]
Hootie Offline
Hootie  Offline
'Ol Wyo
did you disconnect the tv cable from the throttle linkage at the start? I don't know if this is a needed step, but I always disconnect the cable from the carb, adjust, then hook the cable back up before turning the throttle.
HTH
1986 white / gray bucket / t-top SS / Hecho 350, Performer intake, CCC, TES to Flowmaster 2.5", stock open rear.
Just enough to embarrass my wife, and not enough to get me into trouble.
#876430 - 05/29/11 10:45 PM Re: TV Cable Adjustment Help [Re: Hootie]
johnz138 Offline
johnz138  Offline
I will try that.
wave
#876449 - 05/30/11 01:05 AM Re: TV Cable Adjustment Help [Re: johnz138]
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
Did you change the TV cable? Or is it the original you had from before?
Only reason why I ask is that some time ago, when I did a rebuilt on my 200-4R,. when to local Chevy dealer and got myself a brand new cable for 86'MCSS. Then tried adjust the cable but just like yours, nothing came out. Went out for test drive, and found that trans didn't feel right. It didn't shift right. So took off the cable and compare to my old one. Alas. New one is about inch long!
Put the old cable back in, and everything went OK. Went back to the Chevy dealer, but they couldn't give me a refund because I had put the cable on already. Lesson learned.
#876508 - 05/30/11 12:59 PM Re: TV Cable Adjustment Help [Re: FinallySS]
johnz138 Offline
johnz138  Offline
Yeah, its the original cable.
wave
#876535 - 05/30/11 03:58 PM Re: TV Cable Adjustment Help [Re: johnz138]
NYmonteSS Offline
NYmonteSS  Offline
Brentwood N.Y.
Do you have a pic. of your setup?
That would help us out.
#876538 - 05/30/11 04:07 PM Re: TV Cable Adjustment Help [Re: NYmonteSS]
JMD83 Offline
JMD83  Offline
Boston, MA
Does the cable sit in the same position now with the Holley equipment as it did when the factory Quadrajet equipment was installed?
You may need to relocate the TV cable slightly further away from the linkage in order to get the correct tension.
Is the Holley stuff newly or recently installed?
Have you test driven with the adjustment the way it is?
My Other Respectable Rides so far:
1987 Monte Carlo LS LG4 305
1984 Firebird w. 1962 327
1978 K-20 w. 1962 327
1985 Monte Carlo SS L69 305
1984 Trans Am 15th Anniversary L69
1987 Monte Carlo SS Aerocoupe Targetmaster 350
1983 Trans Am LG4 5Spd
#876545 - 05/30/11 05:22 PM Re: TV Cable Adjustment Help [Re: JMD83]
johnz138 Offline
johnz138  Offline
Cant remember if its in the same spot, been too long since the stock stuff was in there.
Yeah, the holley stuff i just put on this weekend.
Haven't test drove it yet, battery charging.
wave
#876948 - 06/01/11 05:10 PM Re: TV Cable Adjustment Help [Re: johnz138]
corvettemark2005 Offline
Oak Creek
There should be a large metal button push it down and push the cable all the way in towards the button release it. now go in the car and push the accelerator all the way to the floor. The cable should now be set.
#877177 - 06/02/11 11:15 PM Re: TV Cable Adjustment Help [Re: corvettemark2005]
johnz138 Offline
johnz138  Offline
Yeah, that's what I did. But nothing moves.
wave
550/thumbs/small118.JPG
by stonecoldtim
500/thumbs/IMG_0390.JPG
by PrinceJay
by GearedSS
500/thumbs/Monte_Radio.jpg
by Chevyman540
500/thumbs/after2.jpg
by 87/88 SS's
