#866345 - 04/11/11 05:34 PM Oil & Temp Gauges not working
Mike87monte Offline
Mike87monte  Offline
Mansfield, MA
My temp gauge has worked since I swapped in my 350 but only when it overheated because of low coolant. It doesn't work now that the coolant is at proper levels now.
Oil gauge doesn't work either. The plug that goes onto the oil sensor which is on the back of my older 350 block by distributor looks like a 3prong plug. This plug is off of my wire harness loom from the drivers side. There is also this same looking plug that is coming off of the harness for all the emissions junk.
Any other ways to get these gauges working or how to re-wire them?
all gauges worked when the 305 was in there
87' Monte Carlo SS
350 .060" over, Thumpr Cam, RPM Air-Gap, 600cfm Carb, T5 5spd, 8.5" 3:73 rear, 18" Chrome IROC's, 2" Steel Cowl Hood, Belltech Spindles, Eibach Springs
#866347 - 04/11/11 05:54 PM Re: Oil & Temp Gauges not working [Re: Mike87monte]
This is the connector that runs to your oil pressure gauge in your dash.
It used to be plugged into the sensor just above your oil filter. Sorry I don't have a picture of the sensor.
This is the connector that runs to the water temp gauge in your dash
It should be plugged into the sensor on the passenger side head
There is also an oil pressure sensor on the choke circuit that won't let the choke work until there is oil pressure.
It plugs into the sensor screwed into the back of the block by the distributor.
This does not affect the oil pressure gauge though some people move their oil pressure sensor from the area by the oil filter up to this port do to adding headers and space restraints.
#866350 - 04/11/11 06:04 PM Re: Oil & Temp Gauges not working [Re: SSLance]
richan Offline
richan  Offline
little rock,ar
See there all the harness pictures did come in handy. LOL good job ! ! !
87 MCSS Aerocoupe, 2 84 Elco V6 & V8, 87 Elco V8
#866351 - 04/11/11 06:05 PM Re: Oil & Temp Gauges not working [Re: richan]
shaking my head... laugh
Now I just need to get them all in one place and maybe get it stickied so I don't have to run and fetch every time there is a question...
#866357 - 04/11/11 07:25 PM Re: Oil & Temp Gauges not working [Re: SSLance]
Mike87monte Offline
Mike87monte  Offline
Mansfield, MA
Lance,
I have that plug (choke) plugged to my oil sensor in the back of the block above the oil filter, to the drivers side of the distributor. Is this the reason why my oil pressure gauge isnt working?
I have that green line attached to my temp sensor in the drivers side head. There is coolant passing it as when I loosen it, coolant starts to leak out.
87' Monte Carlo SS
#866371 - 04/11/11 09:08 PM Re: Oil & Temp Gauges not working [Re: SSLance]
You need this connector
plugged into the brass looking sensor that used to be down by your oil filter in order for your gauge to read oil pressure.
If the green temp gauge wire is plugged into the sensor in the head and the gauge isn't working, I guess either the sensor has failed or the wire is broken somewhere.
#866441 - 04/12/11 03:09 AM Re: Oil & Temp Gauges not working [Re: SSLance]
autowolf80 Offline
autowolf80  Offline
wichita, KS
If the temp sensor only showed when too high temp I would replace it since its not working with coolant and lower temperatures. I've heard that an air bubble can make then not work also, but mainly with supermarket ones and the adapters used on them. Make sure to check your wires for cracked insulation and grounding out on something metal. That will make them not work.
1988 Monte LS. 76 350 sbc, Weiend stealth intake, Holly 650 carb, 350 trans, stock rear end.
#866484 - 04/12/11 11:56 AM Re: Oil & Temp Gauges not working [Re: autowolf80]
Mike87monte Offline
Mike87monte  Offline
Mansfield, MA
Lance,
The sensor on my 305 that was on the back of block to the drivers side of the distributor is the oil pressure sensor correct? I assumed this was the oil sensor and I just put it back in the same location on my 350. The sensor however is a 2-prong sensor and I still have that plugyou have pictured above, but it is only a 1-prong plug. Do I need to get a new oil pressure sensor (1-prong) to match the 1-prong plug pictured above?
I will just get a new temp sensor as I can't imagine they would be anymore than $10.
87' Monte Carlo SS
#866490 - 04/12/11 12:30 PM Re: Oil & Temp Gauges not working [Re: Mike87monte]
Behind the header in this picture you can see the oil pressure sensor that feeds the gauge on our cars.
It is screwed into a port just above the oil filter. Most of us that put headers on our cars have to put a fitting or two between it and the block to get it to clear the headers.
You need the single prong plug above plugged into a sensor like this in order for your gauge to work.
The sensor you are talking about up by the distributor just opens up the choke circuit once oil pressure is detected. It does not send a signal to the gauge.
You can also see the one I'm talking about here
#866491 - 04/12/11 12:30 PM Re: Oil & Temp Gauges not working [Re: Mike87monte]
Gruvin Offline
Gruvin  Offline
Texas
http://static.1aautoimages.com/catimage/95/main.JPG
you need the silver one on the right side of these three in this image, it screws in on the drivers side down above the oil filter. it is a single prong plug like the connector shown above... this is an oil pressure sensor or sending unit
the other one by the distributor is an oil pressure switch.
#866493 - 04/12/11 12:44 PM Re: Oil & Temp Gauges not working [Re: Gruvin]
Mike87monte Offline
Mike87monte  Offline
Mansfield, MA
man that is going to be a PIA to get to with the motor in there. Well thanks for the good news, but thanks for the work I got ahead of me!
Just ordered Holley 534-2 Temp Sensor and Standard Motor Products Oil Pressure Sesnor PS154
87' Monte Carlo SS
#866507 - 04/12/11 02:28 PM Re: Oil & Temp Gauges not working [Re: Mike87monte]
Where was the sender on the 305 you took out?
#866522 - 04/12/11 04:02 PM Re: Oil & Temp Gauges not working [Re: SSLance]
Mike87monte Offline
Mike87monte  Offline
Mansfield, MA
on top of the block near the dizzy. connected to it was the 2 prong plug. i thought that was the oil sensor, but clearly i was wrong lol
87' Monte Carlo SS
#866700 - 04/13/11 01:59 AM Re: Oil & Temp Gauges not working [Re: Mike87monte]
jigsaw Offline
jigsaw  Offline
Laredo TX
thats oil pressure sensor, the one by the oil filter is the oil pressure sending unit, one is for the oil light n the other one for the gauge
#866775 - 04/13/11 12:05 PM Re: Oil & Temp Gauges not working [Re: jigsaw]
Mike87monte Offline
Mike87monte  Offline
Mansfield, MA
I'm looking for the gauge to work. I have a HV pump so I'm going to go ahead and say my pressure is fine, but I just want the gauge to work.
87' Monte Carlo SS
500/thumbs/monte214.jpg
by tovann
536/thumbs/IMG_0611.jpg
by ssmnt408
500/thumbs/P1030365.JPG
by Ole Blue
500/thumbs/my_81_SS_Monte_clone2.jpg
by Dave84
688/thumbs/l_619513f50c2a3391323ff09f4b35de59_2_.jpg
by Vondross
