#864632 - 04/02/11 11:11 PM Rough Idle at at low idle
WestCoastMonteSS Offline
Los Angeles, CA
Hi Guys, got a 86 SS Monte Carlo 305 and the car idles fine or decent when in park, but when you put it in drive it gets a really rough idle, and when you step on the gas it hesitates and slowly goes barely without dying, when the rpm passes 1 then it takes off. Carb has been rebuilt by previous owner, new egr valve, looks like new cables, plugs distributor cap. ANy help, maybe a module or something in the distributor? I am at a loss.
1960 Chevy Impala 2 door
1964 CHevy Impala
1963 Chevy Impala ragtop
1959 2 door Chevy impala drool
1998 Chevy Silverado 1500 (DD)
#864636 - 04/02/11 11:26 PM Re: Rough Idle at at low idle [Re: WestCoastMonteSS]
Check the choke out. Where is it idleng at in park? RPM? When in gear and the brakes applied it should idleing at 650-700. Sounds like the timing may be off a little also?
#864639 - 04/02/11 11:30 PM Re: Rough Idle at at low idle [Re: cj84ss]
Los Angeles, CA
In park it sits at 1.5 rpm, (a little high i think), and yes in drive it idles at around 700. When stopped at a light, it idles rough and when you step on the gas the engine wants to die and then if you can baby it up to 1 rpm then it takes off. I was thinking the timing too, but havnt had a chance to get that checked out. It seems like the engine is choking when taking off from a stop but the carb has been rebuilt and i took it my dependable carb guy today and he said the carb is not the issue.
1964 CHevy Impala
#864644 - 04/02/11 11:37 PM Re: Rough Idle at at low idle [Re: WestCoastMonteSS]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. Has it ever run properly since you owned it?
#864653 - 04/03/11 12:13 AM Re: Rough Idle at at low idle [Re: BuzzLOL]
Los Angeles, CA
No i bought it like this.
1964 CHevy Impala
#864747 - 04/03/11 04:56 AM Re: Rough Idle at at low idle [Re: WestCoastMonteSS]
Sounds like the rebuilder didn't clean the idle tubes. What's the M/C dwell at idle?
2008 ex NPS P71 Crown Victoria
#865000 - 04/04/11 05:31 PM Re: Rough Idle at at low idle [Re: Buick Runner]
Los Angeles, CA
In Park at around 1.5 in drive around .600.
1964 CHevy Impala
#865004 - 04/04/11 06:03 PM Re: Rough Idle at at low idle [Re: WestCoastMonteSS]
that looks like the TPS, the M/C dwell should be around 30 degrees and wavering when at idle and up to operating temp, on the 6 cyl scale on the meter.
#865088 - 04/05/11 01:52 AM Re: Rough Idle at at low idle [Re: 86ttop]
It would be a good idea to check the TPS output though the complete throttle range with a voltmeter. Worse comes to worse you could head to Sean Murphy Induction in Huntington Beach
CA. He seems to be quite the expert with CCC carbs.
#865252 - 04/05/11 10:44 PM Re: Rough Idle at at low idle [Re: Buick Runner]
Los Angeles, CA
thanks for the hrelp everyone, turned out to be the distributor and all the ignition modules etc in the ditributor underneath the rotor, had a rebuilt one replaced for $250 at a shop. Car runs like new now.
THanks everyone MCSS rocks
1964 CHevy Impala
#865446 - 04/06/11 09:11 PM Re: Rough Idle at at low idle [Re: WestCoastMonteSS]
basemonte Offline
basemonte  Offline
Old Bridge, NJ
I've always had ign modules totally fail, (no start). Never had one kind of fail where it affected performance.
500/thumbs/motor4.jpg
by Big Hitter
500/thumbs/100_0152.JPG
by SMITHFOG
500/thumbs/image32.jpg
by Blown Monte
959/thumbs/photo1.jpg
by atarian
500/thumbs/First_Collage.jpg
by BadSS
