Page 3 of 4 1 2 3 4
#856841 - 02/28/11 01:54 AM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
Out with the old junk.
New brake lines.
Upper control arms
LS1 disk brakes
All installed
CLOSE but i should be ok
Dont mind the missing/xxxx lug nuts they are only temporary
Still need to figure out the ebrake cables. I also need to cut and reflare the brake lines to match to the new lines. Then load the suspension and tighten down all of the control arms.
SMCC
Broken Car Disease
#856901 - 02/28/11 03:08 PM Re: SSlowly rising again.... [Re: MonteC]
axisg Offline
axisg  Offline
Toronto, Ontario
Looks great, I noticed a huge differnce when I upgraded the brakes. However when I installed the rear brakes I switched sides so the calipers were at the front of the rotor and I wouldnt have any shock clearance issues ( apparently this won't work with lowered cars )
TES Headers - done !
new cat-back exhaust - done !
5.7 swap - done !
3.73 posi rear - done !
blazer front brakes - done !
LS1 Rear Brakes - done!
transmission - rebuilt !
#857826 - 03/04/11 02:57 AM Re: SSlowly rising again.... [Re: axisg]
MonteC Offline
MonteC  Offline
Summerville, SC
I was more concerned with frame to caliper clearance than shock to caliper clearance.
Im glad it worked out for you but I didnt want to chance it, with the calipers toward the back there is much more clearance to the frame.
SMCC
Broken Car Disease
#857842 - 03/04/11 04:25 AM Re: SSlowly rising again.... [Re: MonteC]
Sixtoes1313 Offline
Sixtoes1313  Offline
Abingdon, Maryland
Looking forward to seeing this done!!! Looks like a nice driver build- if its not rusty...why waste time and money to pretty somthing up you'll never see. Good so far!
LsX: DO IT~ 11.32 @120mph
#857939 - 03/04/11 06:04 PM Re: SSlowly rising again.... [Re: Sixtoes1313]
MonteC Offline
MonteC  Offline
Summerville, SC
Pretty much my whole mind frame right now. Maybe later ill worry about cleaning things up and making everything under the hood and under the car look nice. But at this point, i just want to DRIVE the car.
SMCC
Broken Car Disease
#858453 - 03/06/11 08:45 PM Re: SSlowly rising again.... [Re: MonteC]
mannblk Offline
mannblk  Offline
NC
Looking good Rob! At this rate, you'll be driving her by spring/summer. Keep up the great work!
#860311 - 03/15/11 02:32 AM Re: SSlowly rising again.... [Re: mannblk]
MonteC Offline
MonteC  Offline
Summerville, SC
Another weekend gone by, another little chunk taken out. A problem though...
The UMI upper control arms dont clear my wheels, not sure why. Im going to install the slip on rotors but I really dont see that making much difference.
SMCC
Broken Car Disease
#873331 - 05/15/11 09:24 PM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
i upgraded the rotors and painted the calipers and brackets this time.
Got the headers installed.
SMCC
Broken Car Disease
#873341 - 05/15/11 10:28 PM Re: SSlowly rising again.... [Re: MonteC]
Hey-O Offline
Hey-O  Offline
Ballwin, Mo
Looks great !!! Well done !!
#873684 - 05/17/11 03:52 AM Re: SSlowly rising again.... [Re: Hey-O]
texboi709 Offline
texboi709  Offline
killeen texas
Very nice work it pay off when you take your first test drive
O7 malibu ltz daily driver
86 ss crushed first ss lookin for one
01 blazer stock for now
#891716 - 08/25/11 02:16 AM Re: SSlowly rising again.... [Re: texboi709]
MonteC Offline
MonteC  Offline
Summerville, SC
Yep, been a while. Got a lot full of cars, havent had any spare time.
Brought it over to a buddy of mine who runs a local speed shop. Im turning over the reins of final assembly, wiring, and getting it to run.
Off the bat im going to have to come off over 2k for wheels. Going with Weld RT-S.
SMCC
Broken Car Disease
#928777 - 04/20/12 12:36 AM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
And definitely not going with the weld RT-S's, some unexpected life changes have come up. lol.
SMCC
Broken Car Disease
#928778 - 04/20/12 12:39 AM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
so close!
SMCC
Broken Car Disease
#973406 - 05/31/13 10:42 PM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
The car outlasted my friends business. Its back at my shop now. Pretty much the same condition as the last pics I posted.
I did pick up some wheels for it.
SMCC
Broken Car Disease
#973494 - 06/01/13 10:13 PM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
SMCC
Broken Car Disease
#973545 - 06/02/13 10:52 AM Re: SSlowly rising again.... [Re: MonteC]
SKIDMARK Offline
SKIDMARK  Offline
New Bern NC
Nice build. You will get it finished some day just dont get discougaged. I really like what has been done so far.
#973989 - 06/06/13 11:58 AM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
SMCC
Broken Car Disease
#974344 - 06/09/13 03:16 PM Re: SSlowly rising again.... [Re: MonteC]
Sixtoes1313 Offline
Sixtoes1313  Offline
Abingdon, Maryland
Good so far! What'd you do for the AC lines and compressor setup?
#975008 - 06/15/13 05:16 PM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
http://www.currentperformance.com/Swap_Parts/AC.html
Current performance. Had all the lines made at a local rubber and gasket shop.
all my pics died. frown
SMCC
Broken Car Disease
#975009 - 06/15/13 05:29 PM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
gas tank, fuel pump and lines are good.
SMCC
Broken Car Disease
#975044 - 06/16/13 02:41 AM Re: SSlowly rising again.... [Re: MonteC]
6.084 BlueSS Offline
attleboro ma.
Looking good.
#975524 - 06/20/13 11:39 PM Re: SSlowly rising again.... [Re: MonteC]
Precision Power Offline
Goose Creek, SC 29445
Looking good Rob.
#986479 - 10/27/13 11:08 PM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
Got the car started last weekend. Something found its way into the cylinder during its trip from shop to shop.
SMCC
Broken Car Disease
#986480 - 10/27/13 11:18 PM Re: SSlowly rising again.... [Re: MonteC]
MonteC Offline
MonteC  Offline
Summerville, SC
Was a stock 5.7 ls1 with a hot cam, stock 853 heads and ls6 intake. Motor had less than 2 minutes of run time. Noise started out real small and got louder and louder. Open headers made it tough to hear at first. All of the bearings, rod and crank looked great, something was inside the cylinder. Dont know if it was messed up when I bought it or if something made its way into the cylinder in the last 6 years its been moved around.
I saw red, car was almost sold. I slept on it and declined to entertain offers.
Found another 5.7 short block, with a set of 241 heads already off. Heads are getting a port and polish, pac springs, keeping the ls6 intake, more aggressive custom grind cam, and comp cams timing set. Going to check the rod bearings and install ARP hardware. Gotta buy another H3 oil pan set.
SMCC
Broken Car Disease
#986481 - 10/27/13 11:22 PM Re: SSlowly rising again.... [Re: MonteC]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Man, if that aint a kick in the newts.
I guess this way you'll know exactly whats in the new motor.
Page 3 of 4 1 2 3 4
500/thumbs/Monte_Liberty_State_009_sm.jpg
by nickg
500/thumbs/Passanger_side.jpg
by Morbius3369
500/thumbs/just_washed.jpg
by amendez86
1130/thumbs/ResizedImage_1390834191345.jpg
by O.G.
500/thumbs/engine_pic_3.jpg
by 555ss
