#835464 - 11/08/10 06:47 AM New guy here..
the_merv Offline
the_merv  Offline
Northern, Florida
What's up fellas..I'm new here to the forum..for those of you on LS1tech you might recognize the name..:)
Well here it is..
1984 Monte Carlo SS..:D
Paid $4800 for it. Solid, very little surface rust on the frame..if any. Body is probably 95%, just little paint touchups n stuff like that. Interior is about 95% as well..:)
It Vin checked and car faxed out to be an original 1984 MCSS, clear title.
Currently it has a 350/200R4 in it with the 3.73 Posi 10-bolt Rear. Plans are to swap in a 408 LQ4/L92 Stroker & Built T56 setup that I had in my 1998 Camaro SS..the Camaro had wrecked last saturday.
Those are the stock 14's, 17's are a must and will be going on..atleast a 275/40 tire.
9" Rear, 3.89 Gears, needs a new Radiator, all wiring from the Camaro will be going in with the F-body Gauges so everything will be working correctly. It will have the capability to be tuned with my HP Tuners..;)
Hedman 1 3/4"/3" Long Tube Headers, Strange Chromeoly Drive Shaft, definately some UMI Aftermarket Suspension..LCA's, Adjustable Rear UCA's, Front & Back Sway Bars, Coil Overs all around. Brake Upgrade to 4-way Disc that are worth a xxxx . Prob LT1 for the Backs, whatever will work for the front. Clutch Pedal I'm workin on, I'm pondering adapting the Camaro Center Console to fit in the car since it will be a 6spd.
True-dual 3" Exhaust with X-pipe using my Flo-Pro Twistie Mufflers piped out the back.
Then once it's worked out with the LS Engine and all the old non-needed 80's stuff is out..sound system upgraded.:)
1984 MONTE CARLO SS 6spd
#835465 - 11/08/10 06:53 AM Re: New guy here.. [Re: the_merv]
gbodydude496ci Offline
scranton,pa
welcome and good luck with you build.and keep us posted on it.if you have an ??? just ask.
85'monte ss race car with a cage and notch frame.soon to have my bbc and t400 trany wih a 9inch rear.86'monte ss sbc,200r4 plan for it.
#835466 - 11/08/10 07:03 AM Re: New guy here.. [Re: gbodydude496ci]
the_merv Offline
the_merv  Offline
Northern, Florida
Thanks man. I've seen John B runnin around Tech so I know he's definately on here..there is another guy on here that is in my local area, he has a LS in his car.
I have a pretty good idea where to find my stuff and I'll be doing the wiring for this..I have a whole Camaro worth of wiring to work with.
How many of you guys here have Manual swaps in your cars?
#835470 - 11/08/10 09:29 AM Re: New guy here.. [Re: the_merv]
scranton,pa
if you go to the drivetrain area on here you well see The Official Manual Monte Cult Register.
#835492 - 11/08/10 02:49 PM Re: New guy here.. [Re: gbodydude496ci]
blubaldmontess Offline
Clarksville, TN
When you do it, I'll probably need a little help from you! I did the swap but used a 4l80e tranny for now. Now I'd like to go over to a t56 swap, but am having a hard time finding write ups on what I'll need beside the trans, bell housing, crossmember, and pedal...man do I feel dumb wink
#835534 - 11/08/10 06:19 PM Re: New guy here.. [Re: blubaldmontess]
Looks like a very solid car - congrats on the purchase and welcome to the board wave
Just as an FYI, the stock '84 SS wheels are actually 5-hole 15x7" as seen here:
I've seen the 6-hole wheels you have but can't quite place them. I'm thinking they might be from an S10 or Berlinetta Camaro?
#835540 - 11/08/10 06:48 PM Re: New guy here.. [Re: 85_SS]
They look like 3rd gen Monte wheels...amongst other car from the same era.
The car looks like a nice solid foundation for which it sounds like you have fun plans for.
#835543 - 11/08/10 07:01 PM Re: New guy here.. [Re: SSLance]
Nice car, welcome aboard. It looks like you have a nice solid plan for the transformation. Going to have to watch this build. Make sure you take lots of pics.
#835555 - 11/08/10 08:14 PM Re: New guy here.. [Re: 406monte]
Looks like a great base to start a nice build from, and I like your plans. Keep us posted!
#835652 - 11/09/10 02:27 AM Re: New guy here.. [Re: SickSpeedMonte]
84LS1T56SS Offline
84LS1T56SS  Offline
Central, Arkansas
Glad to see you made it.
#835673 - 11/09/10 04:37 AM Re: New guy here.. [Re: 84LS1T56SS]
Mikey340 Offline
Mikey340  Offline
Woodstock, IL
Noice, a build of my dreams, goodluck take lots of pics then take more:)
I'm Mikey340 on ls1tech also.
Welcom.
Monte resto Here
'85 Monte SS Bedliner Paint w/87 motor+trans, GTA rims,95 Formula seats(sold)
'05 GTO
1977 Monte Carlo bedliner v2
#835755 - 11/09/10 06:04 PM Re: New guy here.. [Re: Mikey340]
WestCoastMonteSS Offline
Los Angeles, CA
Very nice, your on the right forum.
1960 Chevy Impala 2 door
1964 CHevy Impala
1963 Chevy Impala ragtop
1959 2 door Chevy impala drool
1998 Chevy Silverado 1500 (DD)
#835768 - 11/09/10 07:19 PM Re: New guy here.. [Re: 84LS1T56SS]
the_merv Offline
the_merv  Offline
Northern, Florida
Thanks guys..I hope this thing goes together well..nice winter project. smile
I've seen that Yellow GTO on tech..
Oh I just meant stockers..lol..
Hey what's up guy..
#835824 - 11/09/10 11:31 PM Re: New guy here.. [Re: the_merv]
Hey-O Offline
Hey-O  Offline
Ballwin, Mo
Welcome to the house ! Definitely a great car to start with , plan sound great to !
#835931 - 11/10/10 03:05 PM Re: New guy here.. [Re: Hey-O]
Welcome to the BEST Monte Carlo site on the net. thumbs
#835941 - 11/10/10 03:33 PM Re: New guy here.. [Re: 86ttop]
javi05 Offline
javi05  Offline
houston, tx
VERY NICE! hey you wouldnt happen to have the trim rings on any of those stockers??? i need one.? ls1tech. im on pt.net... LS engines are great!!! is that a repaint? i thought all 84's were white or blue??
http://www.youtube.com/watch?v=kEMXAg9hlNE&feature=related
7th monte- 79 burgandy t-tops 305 4bbl. current project. (coolest one)
#836158 - 11/11/10 02:53 PM Re: New guy here.. [Re: javi05]
the_merv Offline
the_merv  Offline
Northern, Florida
It's a repaint..a cheap econo one from the looks. For now it will suffice. Eventually I'll get it redone.
I have all 4 of them rings.
#836160 - 11/11/10 03:08 PM Re: New guy here.. [Re: the_merv]
1984Monte Offline
1984Monte  Offline
Austin, Texas
Welcome and good luck on the build!
#836566 - 11/14/10 02:32 AM Re: New guy here.. [Re: 1984Monte]
the_merv Offline
the_merv  Offline
Northern, Florida
Thanks guys, Blazer Brakes bought today. smile
#836986 - 11/16/10 06:09 PM Re: New guy here.. [Re: the_merv]
the_merv Offline
the_merv  Offline
Northern, Florida
Well the 9" Housing has been ordered for the rear. It was a custom order G-body Housing, Axle Tubes have been extended out 2" on each side to clear the LT1 Disc Brakes. They will bolt the same way they do on the F-body so I can keep my Axles from the setup I had in my Camaro..:D
#836990 - 11/16/10 06:31 PM Re: New guy here.. [Re: the_merv]
jarid Offline
jarid  Offline
calgary, alberta
start with the rims and tires, it will make a huge difference, will look great finished, have fun
87ss 85ss 87ls all blended together to make 1 ss . 450hp 383ci , tci200r4 , 8.5"w/3.42 , all the suspension goodies. 13"baer brakes , nexxus guages, custom GSI int.no paint yet
#836991 - 11/16/10 06:41 PM Re: New guy here.. [Re: jarid]
the_merv Offline
the_merv  Offline
Northern, Florida
Rims and Tires will be last..there is a 640+hp Engine goin in this thing so I need to make the Chassis hold it..lol..
#837003 - 11/16/10 07:45 PM Re: New guy here.. [Re: the_merv]
Monster Offline
Monster  Offline
ArroyoLawns
640hp?
any more info on it?
#837012 - 11/16/10 08:08 PM Re: New guy here.. [Re: Monster]
the_merv Offline
the_merv  Offline
Northern, Florida
408 LQ4/L92 Stroker, 10.9:1 Comp, mid 240's duration Cam on .620 lift.
Oh update to the above, 1 7/8" Headers will be going in.
500/thumbs/74350.jpg
by 350MCSS
564/thumbs/oscars_LS_MONTE_CARLO_002.jpg
by Big Reazon
500/thumbs/012.jpg
by pazzo1969
500/thumbs/DSC03554small2.jpg
by eric305TPI
500/thumbs/1014081349.jpg
by mightymonte10
