#832493 - 10/25/10 02:57 AM Where to buy an EGR Solenoid?
86LKConquista Offline
Fort Collins, CO
Hello,
I need to get ready to pass emmissions, and I get a code 53 after cruising the interstate. After an afternoon with the scanner and my service manual, I've found I need to replace my EGR solenoid. I've checked online at all the local parts stores (Checker, Advance, Autozone, NAPA) and they all reference one, but no one shows it as available. Either out of stock or unavailable.
Anyone purchase one lately? I've done a search on "EGR Solenoid" here on the forum and it did not bear fruit.
Thanks in advance. Steve
Conquista 305 all original 86K. With new tires it drives nice. Pray that I will pass emissions in 2011
#832505 - 10/25/10 04:16 AM Re: Where to buy an EGR Solenoid? [Re: 86LKConquista]
Try Rockauto.com.
#832624 - 10/25/10 08:55 PM Re: Where to buy an EGR Solenoid? [Re: Buick Runner]
Fort Collins, CO
Thanks for that link Buick. Lots of good parts at good prices. But no EGR solenoid. I'll keep looking.
#832630 - 10/25/10 09:20 PM Re: Where to buy an EGR Solenoid? [Re: 86LKConquista]
redlineSS Offline
redlineSS  Offline
South Jersey
~Dave~
#833674 - 10/30/10 08:43 PM Re: Where to buy an EGR Solenoid? [Re: redlineSS]
Fort Collins, CO
Thanks Dave. That's it.
I'm going to try one for a 86 pick up or Astro van. It looks like the connector is in a slightly different location, but the same soleniod. Looks like this one is still available at all the parts stores. We'll see.
#833690 - 10/30/10 09:46 PM Re: Where to buy an EGR Solenoid? [Re: 86LKConquista]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. Maybe your old EGR port just needs the carbon cleaned out of it...
#833797 - 10/31/10 05:01 AM Re: Where to buy an EGR Solenoid? [Re: BuzzLOL]
X2 on the intake or head port being clogged up, 305s have a tendency to leak at the valve seals, EGR passages pay the price and coked.
For a EGR solenoid, Standard Motor Product VS8. EGR valve number for Standard is EGV328, GM number for an 86 305 is 17113433. Many of the old EGRs are being discontinued. More "one size fits all" EGRs that use an orifice washers to adjust the EGR flow rate, here's one.
http://airtexenginemanagement.com/pdf/instruction_sheets/990700686.pdf
Remove the EGR from the intake and check for coking of the valve's pintle and intake passage.
#833822 - 10/31/10 11:27 AM Re: Where to buy an EGR Solenoid? [Re: mmc427ss]
Snowboi Offline
Snowboi  Offline
Fort Walton Beach, FL
I have one, not sure if the Chevy v6 will fit the sbc though.
#834085 - 11/01/10 06:46 PM Re: Where to buy an EGR Solenoid? [Re: Snowboi]
Fort Collins, CO
Thanks to all that replied. I'm impressed with all the valuable expertise that is shared on this site.
The SMP part number and EGR OEM part number were very helpful. I've been able to find the solenoid online, at a reasonable price.
I've already replaced the EGR valve, and appreciate the advice regarding the exhaust passage cleaning that was required. I think it took a couple days to finally burn all the residual in there after it opened up.
Once you fix all the vacuum leaks and get all the sensors and switches working, the CCC 305 runs really good!
1103/thumbs/207340_10200670121863899_1212977643_n.jpg
560/thumbs/monte_engine.jpg
by Slash
532/thumbs/sm.JPG
by Blown Monte
500/thumbs/imagejpeg98.jpg
by blkcharlotteman
500/thumbs/4206.jpg
by Bricktop
