#814104 - 08/01/10 06:03 PM Neutral Safety switch, Shifter install Help!!
Makavelli22 Offline
Makavelli22  Offline
Los Angeles, California
Hello,
I recently purchased a B&M Quicksilver shifter for my 1983 Monte Carlo SS. I am forced to do the column to floor shifter conversion because my 700r4 transmission is too big for the column shifter to work right. This is not a big deal since I wanted to do this from the begining. Anyways, I have the setup ready, I already drilled the holes and ran the shifter cable to the transmission. Now its time to hook up the Neutral safety switch and the Reverse light switch but im stuck!! I am not sure where to run the wires from the shifter to the actual neutral safety switch. I wanted to know if anyone had pictures of the neutral switch location or if they can explain how to do this install better than the Instructions B&M sends with its shifters (which show nothing on how to do this). Any help or pics are greatly appreciated. Thanks in advance.
#814126 - 08/01/10 07:04 PM Re: Neutral Safety switch, Shifter install Help!! [Re: Makavelli22]
Speedy84SS Offline
Speedy84SS  Offline
Lindenhurst, NY
#815612 - 08/07/10 08:12 PM Re: Neutral Safety switch, Shifter install Help!! [Re: Speedy84SS]
JAWSS Offline
JAWSS  Offline
Ft. Hood, TX
Yep. Grab a linkage setup for an 85-88 G-body with a 2004r from the factory and it should work perfectly with your 700r4. The neutral safety switch and reverse lights are all in the column and is adjusted with the linkage on a column or floor shift car.
86 Monte Carlo SS T-top
69 Cutlass S Convertible
12 Cadillac CTS-V Wagon
#815867 - 08/09/10 03:23 AM Re: Neutral Safety switch, Shifter install Help!! [Re: JAWSS]
Makavelli22 Offline
Makavelli22  Offline
What do you mean by "safety switch and reverse lights are all in the column and is adjusted with the linkage on a column or floor shift car." I no longer have the column shifter, only the floor shifter and Im suppose to hook up the wires from the shifter to the neutral switch and reverse lights on the column. Im trying to find out which wire is what. I heard a green wire from the column is for the reverse lights and a purple wire running to the starter is for the neutral. Is this correct?
#815881 - 08/09/10 05:04 AM Re: Neutral Safety switch, Shifter install Help!! [Re: Makavelli22]
JAWSS Offline
JAWSS  Offline
Ft. Hood, TX
There is white module on top of the column shift and floor shift cars steering column. There is no reason to have to wire it up on the shifter. The bowl on floor shift cars rotate just the same as a column shift car. The only difference is no nub for the arm to attach to on the floor shift cars. Just leave all of the wires and linkages attached and install your new shifter.
#815996 - 08/09/10 09:40 PM Re: Neutral Safety switch, Shifter install Help!! [Re: JAWSS]
84supersport Offline
Louisville, KY
Well he said he no longer has a column shifter so he never had the linkage for a floor shift. Makavelli, on a floor shift car there is linkage that runs under the car and up the firewall to actuate the column indicator, reverse lights, and neutral safetly switch. You could either find the linkage in a junkyard or use micro switches on the sifter wired up to the module on the column. I'm not sure which wires you splice into though.
519/thumbs/DSC00032.JPG
by Ted88SS
500/thumbs/090618_124025.jpg
by 87Aerocoupe87
1013/thumbs/3eng.jpg
by Barney
500/thumbs/87SS.jpg
by MikePEI
500/thumbs/rsz_img_0436.jpg
by monteSS4mike
