#813862 - 07/31/10 09:41 AM
11.92 @ 113.92mph at E Town
Loc: Ozone Park,NY
 Last test n tune at E town went pretty good. I still run NA. I never ran electric for solenoids. Here are the time slip #s from second pass. first pass blew the tires off ran a 14.98 lol 60' 1.699 330' 4.930 1/8 7.619 @ 91.17mph 1000' 9.948 1/4 11.924@113.92mph Final pass #s 60' 1.720 330' 4.946 1/8 7.649@90.83 1000' 9.984 1/4 11.96@113.75 http://www.youtube.com/watch?v=B9PoL6fQYlw&feature=channel
Edited by 02intimidator (07/31/10 09:52 AM)
_________________________
Just your typical 11 sec 305
Top
#813901 - 07/31/10 02:16 PM
Re: 11.92 @ 113.92mph at E Town
[Re: 02intimidator]
Loc: Stafford, VA
Nice runs, need to work on your burnouts alot though. Not getting them hot enough to really work for you like they should.
Frame Off Restoration in Progress 406 Roller, Trick Flow aluminum heads, 10.5 comp, 750 Holley mech sec, MSD ign, 350 tranny, 3400 stall, TCI line lock, 3.73 posi 7.5 rear, 28x12.50x15 MT's, Autometer gauges 11.96 E.T at 114.44 all motor.
Top
#813929 - 07/31/10 05:18 PM
[Re: 406monte]
Loc: Ozone Park,NY
I agree. I'm hitting 3rd gear in the burnout but these tires dont smoke like the should. A couple of them were shortened because it started to drift sideways. The first run I had 17 psi in the tires and left at 3200 rpm, and melted the tires when I left. The last 2 runs I dropped to 11 psi and left at 2200rpm which worked out pretty good.
Edited by 02intimidator (07/31/10 05:19 PM)
Top
#814102 - 08/01/10 01:54 PM
[Re: MY FYN 79]
Loc: Ozone Park,NY
I run with the MT Drag Radials. The first run was with 17 lbs. and launched at 3200rpm. The last 2 runs were with 11 lbs of air and a launch rpm of 2600. I have a ProTorque 3800 Billet convertor. It flashes at 3600. Next time out which is Weds. I'm going to try an off idle launch. My 60' times have not improved but ET has. I think it's a lil wierd.
Top
#814521 - 08/03/10 01:11 AM
[Re: MY FYN 79]
Loc: Pottstown, Pa
Can't give much advice on launching an auto, just keep playing with technique while watching the short times, that will tell you whether you went the right way. Only make one change at a time, minimum two passes on each change to see results.
MPH is very good, ET is pretty close to were it should be, but I would think there are a several more tenths left in the car.
E-town looks like a really nice track, never been there, maybe some day make a trip over there. Bob
Top
#814731 - 08/03/10 09:59 PM
[Re: mmc427ss]
Loc: Ozone Park,NY
Tomorrow is the day. We'll see what happens with off idle pass first, if I'm not happy i'll drop air to 11 lbs and give it 3200 launch. With the air that low I should not have a traction issue. As far as my burnouts I'll rev it a lil higher before shifting gears.
Edited by 02intimidator (08/03/10 10:02 PM)
Top
#814732 - 08/03/10 10:00 PM
[Re: 02intimidator]
Loc: Ozone Park,NY
E town is a very nice track. There is also Motor cross, drifting (which I think is the biggest waste of rubber and money) and a nice lil road coarse.
Top
#814820 - 08/04/10 08:15 AM
[Re: DMI518]
Loc: Stafford, VA
When I am in the box I hit my line lock and then go through all three gears before releasing the lock then I roll out of the box. I then throw it in neutral and clean out the carb with a few blips of the throttle, then I line it up and stage. I found that I get a better launch by coming just slightly above idle then I smash it on the third yellow and I am off. I run around 18psi in my Mickey Street E.T's.
Top
#815062 - 08/05/10 08:36 AM
[Re: 406monte]
Loc: Ozone Park,NY
ok the best last night was 11.83 @ 114.23 mph. On 12 psi in the tires and a 3300 rpm launch. I tried launching off ilde with no improvement 11.96 , then at 2600 rpm for an 11.95 I'l post videos in a lil bit
Top
#815064 - 08/05/10 08:41 AM
[Re: 02intimidator]
Loc: Ozone Park,NY
BTW new vids were taken with a much better camera man LOL
Top
Moderator: 85_SS, Dalt10, Gruvin84SS, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, TPI Monte SS
by gmguy3car
by Capitalsfan
by 02intimidator
by MrTurboHappy
by 1 slow ss
Site Contributors
in the last Month:
GuysMonteSS
