#813844 - 07/31/10 08:28 AM
Any with Dynomax long tubes? Oil sender placement.
Loc: Ewa Beach, Hawaii
Ok, I've got a lot of helpful responses as to locate my oil pressure sender (with stock guage). The problem is that one of the header tubes is so close to the bolt where the sender was. I looked behind the intake manifold on the driver's side where I could place the pressure sender there, but there's a 4 inch (unknown to me) sensor or thermal valve that's residing there. I have the L69 for my '86SS, does any one know what that thing is? If so, can I unscrew that and place my oil sender there? Anyone come across this situation?
_________________________
1986 Monte Carlo SS. L69, SMI stage 2 carb, Hypertech 180 degree stat, off road chip, Dynomax long tube headers, BBK underdrive pullies, g force crossmember, Pypes exhaust, centerline split spoke wheels, BFG Drag Radials, Goodmark cowl hood, Susp. Tech. springs, Bilsteins, UMI uppers & lowers
Top
#813864 - 07/31/10 09:50 AM
Re: Any with Dynomax long tubes? Oil sender placement.
[Re: Joe87monteSS]
Joe, Is that switch vital to the operation if I retain the CCC system? What is that original switch for? Is it a 1/8 NPT thread type of 45 degree adapter I should look for? I found a bunch of 90 degree fittings/adapters made of brass at the plumbing section of home depot, but no 45 degree ones. Wonder who carries 45 degree adapters? Any additional pics would be very helpful. Thanks for your help.
Top
#813868 - 07/31/10 09:55 AM
[Re: 86SS&87TR]
Loc: Indpls.,IN
Choke switch IIRC. And parts stores have plenty of 45s (street elbow may be the name used). Yes, it's 1/8NPT for that port.
Edited by 85t5mcss (07/31/10 09:55 AM)
1985 Monte Carlo SS, T-Tops, 355cid w/ AFR 195s 409HP/429TQ, C5 Front Brakes, T5 5 Speed, QA1 Adjustable shocks/springs Front and Rear blah, blah, blah.......... Silly "Ricers", useless wings are for penguins!
Top
#813872 - 07/31/10 10:26 AM
[Re: 86SS&87TR]
Loc: jacksonville, fl.
For your set up I would suggest a t fitting to just keep the choke light off. You can also get some 90's and small pieces of the 1/8 pipe to move the sender a little in the stock location also.
 1984 SS, w/87 Grand National 2004R, 355 vortec, CCC, Crane XE262, true 2 1/2 duals w/h pipe & hooker aero chamber muflers 2003 GMC Serria 1998 Pontiac GTP Supercharged 2003 Pontiac Aztek
Top
#813873 - 07/31/10 10:28 AM
[Re: Joe87monteSS]
Loc: South Jersey
If You remove that oil switch, make sure to jumper across the two female prongs inside the connector. Or you will lose power to your automatic electric choke! Found out the hard way.
~Dave~ Monte Carlo...."Born on the Track, Driven on the Street"
Top
#813887 - 07/31/10 11:37 AM
[Re: redlineSS]
Awesome feedback gentlemen. I appreciate all of your expert responses. Now off to Napa.
Top
#814030 - 08/01/10 07:34 AM
[Re: 86SS&87TR]
Loc: Indpls.,IN
Any luck? They should have that in stock in the Weatherhead Cabinet. Part number is going to be something similar to 3350X2
Top
#814086 - 08/01/10 12:43 PM
[Re: redlineSS]
Loc: Saint Cloud, Florida
If You remove that oil switch, make sure to jumper across the two female prongs inside the connector. Or you will lose power to your automatic electric choke! Found out the hard way. I dont have the two prong connector hooked up and I measured 12 volts to the wire going to my carb for the choke - the only thing I noticed though is that it keeps the choke light on the dash. Guess I am gonna have to go check that out since I am running a Edelbrock carb with Electric choke to be sure.
 86 Monte Carlo SS - 350 - built Turbo 350 tranny - Computer Delete with a Mallory Vac advance Distributor #8548201C - Eddy Carb #1406 Eddy 2101 Aluminum Dual Plane Intake, Eddy Performer plus Cam and Lifter Kit with #5794 Valve Spring Kit
Top
#814170 - 08/01/10 05:23 PM
[Re: Joe87monteSS]
I'm running the E4ME Quadrajet, stage 2, Sean Murphy carb.
Top
#814423 - 08/02/10 06:36 PM
[Re: Joe87monteSS]
I was referring to the other guy. I must be the "other guy"
Top
Moderator: 85_SS, Dalt10, Gruvin84SS, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, TPI Monte SS
by Spider_carb
by Mirada Mama
by KILOCCS 86 SS!!!!
by Vondross
by MikePEI
Site Contributors
in the last Month:
GuysMonteSS
