#812606 - 07/26/10 03:38 AM Speedometer Gear Help - TH350
Sherdep Offline
Sherdep  Offline
Saint Cloud, Florida
Here is my issue - took my GPS in the car today and founf my Speedo is off by atleast 5 miles an hour at 45 mph and gets worst as I go faster.
Here are the specs of the car - I have a TH350 in my 86 Monte
stock height tires 215/65/15
3.73 Posi Rear end.
Does any one know where to buy the correct gear and the part # or am I going to have to pull the one out and figure out what it is an make an educated guess to the next set of teeth and hope I am right
Any help would be greatly appreciated
86 Monte Carlo SS - 350 - built Turbo 350 tranny - Computer Delete with a Mallory Vac advance Distributor #8548201C - Eddy Carb #1406 Eddy 2101 Aluminum Dual Plane Intake, Eddy Performer plus Cam and Lifter Kit with #5794 Valve Spring Kit
#812625 - 07/26/10 06:21 AM Re: Speedometer Gear Help - TH350 [Re: Sherdep]
Retro Offline
Retro  Offline
Macon,Ga.
#812639 - 07/26/10 11:06 AM Re: Speedometer Gear Help - TH350 [Re: Retro]
Sherdep Offline
Sherdep  Offline
thanks for the Info - one problem is I do not know what the # of drive teeth are without pulling the drive shaft and counting the # of splines unless I am reading that wrong
#812655 - 07/26/10 12:42 PM Re: Speedometer Gear Help - TH350 [Re: Sherdep]
Retro Offline
Retro  Offline
Macon,Ga.
Look at the cutaway Pic in Post #4 here >> http://www.hotrodders.com/forum/speedo-gears-139340.html
You should be able to shine a small light on the Drive gear after removing the Speedo bullet & Driven gear to see what color it is. May be able to count the teeth also. The TCI chart has the gear colors >> http://www.tciauto.com/Products/TechInfo/speedo_gears.asp#350
Todd
#812753 - 07/26/10 09:09 PM Re: Speedometer Gear Help - TH350 [Re: Retro]
Sherdep Offline
Sherdep  Offline
Thanks Todd - I'll take a look at it - after I posted the above statement I got a chance to read some stuff at work today and realized there are two gears for the speedo - now I understand what it means by drive and driven
The drive teeth are the ones in the upper portion and the driven teeth are the ones attached to the speedo cable
#825550 - 09/23/10 12:19 AM Re: Speedometer Gear Help - TH350 [Re: Sherdep]
Sherdep Offline
Sherdep  Offline
Ok Drive Gear is Green (9)
Driven Gear is White (36)
Gears are 3.73
tire size (215-65-15) = 26.00
According to the TCI website I need Driven Teeth - 26.01397679243833
The closest one is 27
Gonna order it and hope it isnt off as bad as I am now LOL
Thanksfor the help
631/thumbs/DSC_3870_Medium_.JPG
by AWDVETTE
500/thumbs/ehuhrty.JPG
by juangomez22
500/thumbs/5248.jpg
by gbodydude496ci
835/thumbs/DSCF00251.JPG
by timw
500/thumbs/ssside2.jpg
by valvefloat ss
