#727118 - 09/28/09 03:11 AM 700R-4
86_SS Offline
86_SS  Offline
League City, TX
Will the crossmember for a 200-R4 work for a 700-R4?
#727132 - 09/28/09 03:42 AM Re: 700R-4 [Re: 86_SS]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
Nope.
700R4 has a mount point that is 3" closer to the rear end. You need a different mount point on the crossmember and then you need a shorter driveshaft
#727163 - 09/28/09 12:23 PM Re: 700R-4 [Re: MattsMonte]
redlineSS Offline
redlineSS  Offline
South Jersey
YES
If you get the caprice or caddy 700r4 tailshaft housing, you can keep the 200 crossmember. It moves the mounting point back 3 inches.
http://www.rowand.net/Shop/Tech/AutomaticOverdriveTransmissionSwap.htm
about halfway down the page, there is a picture and instructions!
~Dave~
#727361 - 09/29/09 04:31 AM Re: 700R-4 [Re: redlineSS]
baaboo Offline
baaboo  Offline
Racine, WI
I'll go along with redline. I redrilled the hole in the mounting pad back, and while a little tight for the bolts, it worked out ok.
#727363 - 09/29/09 04:41 AM Re: 700R-4 [Re: baaboo]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
Learned something new.
#727368 - 09/29/09 05:45 AM Re: 700R-4 [Re: MattsMonte]
86_SS Offline
86_SS  Offline
League City, TX
thanks for the info. .the 700 came extra with the car when i bought it so i wasnt sure what had to be done. .ill have to go measure the tailshaft housing. .thanks again fellas
#727385 - 09/29/09 01:39 PM Re: 700R-4 [Re: 86_SS]
redlineSS Offline
redlineSS  Offline
South Jersey
When doing the 700r4 swap, you will need to get your 200 4r driveshaft cut 3 inches, or have a new one made! 49 1/2" is what you need for the 700r4.
~Dave~
#757656 - 01/18/10 07:32 PM Re: 700R-4 [Re: redlineSS]
Intimid88tr Offline
Intimid88tr  Offline
Girard PA
Where would you cut the Drive shaft at?
Int.
aka
Greg
#757666 - 01/18/10 07:53 PM Re: 700R-4 [Re: Intimid88tr]
Retro Offline
Retro  Offline
Macon,Ga.
In the Center. Just kidding. At the front or rear where the Yokes are welded on.
#757754 - 01/18/10 11:45 PM Re: 700R-4 [Re: Retro]
Intimid88tr Offline
Intimid88tr  Offline
Girard PA
ahh ok Thanks Retro! smile
Int.
aka
Greg
#757958 - 01/19/10 05:42 PM Re: 700R-4 [Re: Intimid88tr]
Intimid88tr Offline
Intimid88tr  Offline
Girard PA
One other question guys...what year caprice or caddy do you get the tail shaft out of?
Int.
aka
Greg
#758051 - 01/19/10 11:36 PM Re: 700R-4 [Re: Intimid88tr]
Retro Offline
Retro  Offline
Macon,Ga.
Greg there's lots of Tailhousing Info here, starts about 1/4 way down page >> http://www.rowand.net/Shop/Tech/AutomaticOverdriveTransmissionSwap.htm
The TH400 & TH2004R share rear mount locations so this Info will help. It has the Info you're looking for & much more.
Todd
#758069 - 01/20/10 12:57 AM Re: 700R-4 [Re: Retro]
redlineSS Offline
redlineSS  Offline
South Jersey
Another thing to consider when doing this swap is the speedometer drive mechanism.
700r4 used several setups. The electronic housing can be gear driven or reluctor driven. Both these are compatible with Autometer electronic speedometers. ALSO there is two mechanical setups that use different "driven" gear sets. PATC transmissions sells these different gear setups.
I have used all of these setups with great success! Getting the proper drive and driven gears for your rear ratio and tire size is all that is needed for the mechanical setup.
Greg, Buick roadmasters also used those tailshaft housings. Try 88-92, those big boat wagons!!
Here is PATC speedo INFO:
http://www.partshp.com/speedometer_gears.htm
~Dave~
#758078 - 01/20/10 01:31 AM Re: 700R-4 [Re: redlineSS]
Houlie Offline
Houlie  Offline
Spencer, MA
Originally Posted By: redlineSS
YES
Gee I remember another member doing this also?........hmmmmmm?
#758161 - 01/20/10 01:50 PM Re: 700R-4 [Re: Houlie]
redlineSS Offline
redlineSS  Offline
South Jersey
YES
THAT was BMP (Before MAN PEDAL).................LOL
~Dave~
#762415 - 02/03/10 10:22 PM Re: 700R-4 [Re: redlineSS]
JBreu Offline
JBreu  Offline
Livonia,N.Y.
I went looking for one of these tailshaft housings........I not only found one....I scored two of them..... I figured as they are so rare.....I will keep one and sell the other.....if anyone here is interested shoot me a PM.....
1984 Monte Carlo sbc bored/stroked to 388 c.i. 514 Dynoed HP.700r4 w/2000 stall,12 Bolt w/4:10
Old Chevy's Don't Die, They Just Get Faster
Best E.T. to date : 12.20 @ 110 MPH All Motor
500/thumbs/DSC00199.JPG
by nighttech
500/thumbs/IMG_13351.jpg
by jvssmail
500/thumbs/L69_Spark_Table.jpg
by Duts87SS
989/thumbs/my_monte_34.jpg
by 85montanezcarloss
1164/thumbs/IMG_00281.JPG
by Witman69
