#737698 - 11/06/09 08:43 PM
Rebuilt carb now it keeps spraying gas !!!
Loc: Chicago,IL(Lombard)
MY brother rebuilt the CCC on my 1987 MCSS motor 20k orig. miles. Carb was leaking from one of the gaskets. Hence reason for rebuild. So I bought a kit from Advance, he swapped everything out. Put it on the car and fuel was coming out everywhere but the gaskets!!! So, bought a new float, swapped in old needle and seat. Pretty much same thing, maybe a little less fuel.
Any ideas? Btw my brother has rebuilt MANY carbs before and never had this issue.
_________________________
 Monte resto Here '85 Monte SS Bedliner Paint w/87 motor+trans, GTA rims,95 Formula seats ,2" drop spindles, 1" drop rear, lots more... '05 GTO
Top
#737751 - 11/07/09 12:20 AM
Re: Rebuilt carb now it keeps spraying gas !!!
[Re: Mikey340]
Loc: Pottstown, Pa
Just time for a few questions.
Have you installed a perf fuel pump? Fuel is leaking from where, primary venturi, vent? When the little hook on the needle was installed on the float it wasn't put into one of the slots in the float? A no no! Float height was set correctly and a check was made to unsure the float wasn't binding against the MC or bowl walls? A "high perf" needle and seat wasn't installed? Bigger than .035" may cause flooding with higher pressures. Bob
Top
#737756 - 11/07/09 12:39 AM
[Re: mmc427ss]
All stock. My brother rebuilt it so I'm unsure of the spring or float binding. Seems like it's coming out of the vent. Car only runs for a little while then dies i get out and see fuel all over the top of the carb.
Top
#737760 - 11/07/09 01:08 AM
[Re: Mikey340]
Loc: Ashby, MN
check to make sure all the screws are in place and tight. is it possible that he left a small piece of the old gasket under the airhorn or something stupid like that?
http://good-times.webshots.com/album/568279446VvVgWO86 MC SS- rough, but fixable. looks like something Dale Sr might have driven back to the transport after a race at Bristol. 84 regal T Type with 64,000 miles and almost no options 74 Monte Carlo cruiser
Top
#739638 - 11/13/09 01:44 AM
[Re: mmc427ss]
Winner winner chicken dinner:-) It wasnt hooked on the float but it was catching on something, pulled it off and runs great thanks for the idea. Mikey
Top
#739805 - 11/13/09 04:45 PM
[Re: Mikey340]
Loc: Pottstown, Pa
Oh great, a chicken diner, is that for two? Good to see you found the problem. Bob
Top
Moderator: 85_SS, Dalt10, Gruvin84SS, mannblk, MC87SS, mcss383, MY FYN 79, NYmonteSS, Phil87SS, Russ, ss4ever, Test Global Moderator, TPI Monte SS
by Dalt10
by Tolley1
by johnz138
by tovann
by SSCopperhead
