The TPI F-bodys use a bracket that bolts to the rear two intake bolts on the pass side. Should be able to use one of those brackets.
_________________________
86 MCSS 5.7 TPI 700R4, T-Tops, DIY-PROM, Moates G3 Switcher and AutoProm, Modified World Sportsman II's,Stealth Ram polished, BBK 52mm TB,224/230 HR cam, 30# SVO's, Pypes 3" dual w/X, WB O2(LC-1), UMI reloc LCA's, Eddy Adj UCA, DS loops all Finally together
