Topic Options
#736639 - 11/02/09 10:02 PM Let's talk cams...
BlueBoy84 Offline
Loc: Northern KY
Ok. I'm getting ready to pull it apart, replace the oil pan gasket, rear seal and valve seals. Got to thinking that it would be a good time to replace the timing chain and maybe upgrade the cam.
Right now, it's basically a stock L69 with headers. What would be a good choice for a cam to wake it up a bit? I don't want too lopey of an idle, since it's basically a summer daily driver. Thx
Any other suggestions while I'm in there (aside from just tossing it in favor of a 350) smile Also, suggestions/PNs for timing chain replacement?
_________________________
Keystone Klassics, Pioneer CD, TES headers, Flowmaster Super 40s, 2 1/2" stainless exhaust
Progress pics at: http://home.insightbb.com/~rodger.turner/
Top
#736650 - 11/02/09 10:15 PM Re: Let's talk cams... [Re: BlueBoy84]
BuzzLOL Offline
Loc: Toledo, Ohio
.. A cam under 220*/230* duration at .050"...
.. Summit has an inexpensive SBC true roller timing chain...
'86 Monte LS 305" soon 405", '87 GTA TransAm TPI350, '85 Fiero, '79 Riv, '02 LHS, '75 MG Midget V8, '77 Astre Formula, '78 F150 4WD 351M, 19' Slickcraft 425HP 351W, 22' Glaspar 225HP 302W
Top
#736662 - 11/02/09 11:01 PM Re: Let's talk cams... [Re: BuzzLOL]
Loc: Kentville,Nova Scotia
This Lunati Voodoo cam might be a good choice;
http://www.jegs.com/i/Lunati/638/60100LK/10002/-1#
But it wouldnt hurt to call the cam company of your choice and talk to a tech person,or call a bunch of companies and see what their recommendation is.Be sure to have all the specs available,compression ratio,gearing,etc...
GuysMonteSS 454 LS-6 BBC,Solid Roller Cam,Doug Nash 4+1 5 Speed,Hurst In-Line Shifter,Ford 9 Inch Rear,160 MPH!Hang On Tight!!
Top
#736664 - 11/02/09 11:05 PM Re: Let's talk cams... [Re: GuysMonteSS]
Cloyes is a well known manfacturer of timing sets,heres one;
http://www.jegs.com/i/Cloyes/220/9-1100/10002/-1#
Top
#736665 - 11/02/09 11:05 PM Re: Let's talk cams... [Re: GuysMonteSS]
Monte_ExpreSS Offline
Loc: Whitby, Ont. Canada
I was just going to suggest a Voodoo Guy. Although I would up it to the 60101lk. Great flat tappet cam for a 305. I've been running one in mine for a while now & have been very pleased with it. It goes without saying to replace the lifters as well as the springs when you're changing the cam.
88 T Top Monte SS - Ram Air - 17" Budnik M5's & Nitto Nt555's - LS1 front brakes - HID conversion - Coming soon Vortec 383...
Top
#736667 - 11/02/09 11:18 PM Re: Let's talk cams... [Re: Monte_ExpreSS]
Loc: jacksonville, fl.
Those are all good suggestions. I would suggest that you call a couple of different cam companys and see what they suggest and then go with the advice they give you and make a choice from there.
1984 SS, w/87 Grand National 2004R, 355 vortec, CCC, Crane XE262, true 2 1/2 duals w/h pipe & hooker aero chamber muflers
1998 Pontiac GTP Supercharged
2003 Pontiac Aztek
Top
#736683 - 11/03/09 12:12 AM Re: Let's talk cams... [Re: cj84ss]
BADD87SS Offline
Loc: archie, mo
Maybe even some new pushrods as well...
87 SS/Vette rallies/235/70/15s/white/40221miles
86GMC4X4/355/700R4/4.56
92Lumina/60k=DD
Top
#736769 - 11/03/09 11:19 AM Re: Let's talk cams... [Re: BADD87SS]
Loc: Dunstable, MA
Roger, here's a post from a few months back:
305 Cams
Top
#736792 - 11/03/09 01:13 PM Re: Let's talk cams... [Re: FrankOC]
BuzzLOL Offline
Loc: Toledo, Ohio
.. Summit offers a TRUE roller timing chain set for the same price as what others sell a block roller for:
http://www.summitracing.com/parts/SUM-G6600
.. Yes, the Lunati Voodoo /60101 or /60102 would work well depending on how brave you are... it might be hard to tell the peformance of the VooDoo /60100 from the stock SS cam... Comp, Isky, Howard's, Herbert have similar cam grinds...
.. This Summit cam and lifters for $100 less than the Lunati kit would also work well, it's just not quite as cutting edge, basically about like the VooDoo /60101 :
http://www.summitracing.com/parts/SUM-K1103
.. If you have the '86-'88 SS w/ roller block and want to convert to a mild, but powerful roller cam 210/215 duration:
https://shop.enginekits.com/osb/itemdetails.cfm?ID=2143
.. The Chevy ZZ3/ZZ4 roller cam 208/221 duration would also be a good choice and can prolly be found used...
.. Here's some suitable 'Z28' type valvesprings (ignore what Lunati says about just using your "stock" valvesprings, they're a bit too weak):
https://shop.enginekits.com/osb/itemdetails.cfm?ID=2971
Top
#736794 - 11/03/09 01:22 PM Re: Let's talk cams... [Re: BuzzLOL]
Gruvin84SS Offline
Loc: Texas
the VooDoo 60100lk is on the ragged edge of too small giving a dynamic compression of 8.36 to 1... better be running headers and good exhaust, I would prefer that number to be closer to 8.2 for stock Iron heads...
The VooDoo 60101lk or the comp cams XE256-H will get you in the 8.2 to 1 dynamic compression ratio range which is better IMHO
87 SS bought 9-5-04: 7-30-09: just bought the power mirrors, good time to do it while the door panels are off! Interior update: race car style - seat & a shifter!
Top
#736908 - 11/03/09 07:28 PM Re: Let's talk cams... [Re: Gruvin84SS]
BlueBoy84 Offline
Loc: Northern KY
good food for thought, thanks guys
Top
#737140 - 11/04/09 05:32 PM Re: Let's talk cams... [Re: BlueBoy84]
DLV555 Offline
Loc: Findlay, OH USA
I run the voodoo 60101 in my 400. Since I didn't tear into the motor when I swapped it in I was stuck with old stock 400 compression. I couldn't go with a lot of overlap, I wanted to go with the 279 thumpr cam, so had to scale back a little. It has moderate lift, stock springs could probably handle it but mine are dual springs, and reasonable overlap with a 112LSA. In retrospect I probably could have gone to the 60102 and wish I had, but I didn't realize someone had already upgraqded the springs. I imagine that would make a great cam for a 305.
Former Member SMCC
1992 Pontiac Firebird TBI 305, shorty headers, 3" exhaust, Flowmaster 80, boxed SFCs and LCAs
1973 Mercury Montego MX 351C
1987 Monte Carlo SS, 400SBC, Edelbrock Intake, mild Lunati Voodoo cam, Flowtech LT headers, 2.5" true dual exhaust, Delta-Flow 40s
1987 Monte Carlo SS(RIP 11/17/2001)
Top
#737147 - 11/04/09 06:09 PM Re: Let's talk cams... [Re: DLV555]
roughskinjrz Offline
Loc: Miramich, NB
when ya get the bug, your screwed. when you take that apart you think horsepower, when ya dump a cam in it, you will want better flowing heads, intake, bigger carb, etc. lol. do er all at once!
489 BBC, Eagle Steel 4.250 Crank, Eagle 6.385 Forged Rods, SRP 0.030 Flat Top Forged Pistons, Crane Z 244/256 .632/.632 Roller Cam, Pro Comp 320cc Heads, Harland Sharp 1.7 Roller Rockers, Weiand 8-71 Blower, 2 x 800cfm Barry Grant Mighty Demon Blower Carbs. TH400 Trans Brake, Full Manual Reverse Valve Body. QP Ford 9" 3.70 Gears Spool 31 Spline.
Top
#737484 - 11/05/09 10:54 PM Re: Let's talk cams... [Re: DLV555]
BuzzLOL Offline
Loc: Toledo, Ohio
.. I have the Summit cam that is close to the 60102 for my 405"... little bit more duration, little bit less lift... maybe the gentler lobes won't be as hard on the valvetrain...
.. The 60101 is plenty for a street 305"... I run the Crane version of that size in my 351W... the 60102 would prolly be more suitable for a street/strip 305" with upgraded heads...
Top
#737594 - 11/06/09 11:49 AM Re: Let's talk cams... [Re: BuzzLOL]
Dark Ember Offline
Loc: Houston, TX
Wow, did all you guys actually run these cams in your monte's? Did they have press fit or screw in studs? I ran a set of 1.6 roller tipped rocker arms and I started pulling all the studs out. I cant imagine what a cam would do to those rockers. Maybe I was just unlucky?
88'SS Building: 355, scat forged bottom end, Dart Heads, 8.3:1 comp., 234/242 roller cam, Team G Intake, 1-7/8" headers, 3-1/2 collectors & full exh., Holley 700DP, Full MSD setup, T56, posi. 4.10's, 2" drop F/R. Full suspension upgrades. Blower is next.
Top
#737622 - 11/06/09 03:16 PM Re: Let's talk cams... [Re: Dark Ember]
BuzzLOL Offline
Loc: Toledo, Ohio
.. Generally the first valvetrain upgrade is to replace the push in studs with screw in studs... or at least pin the pushins in place... at $20/set for stronger screw in studs, why take a chance on them pulling out or breaking off? They can barely hold in with a stock valvetrain... and if they have 5/16" top threads, they break off...
.... https://shop.enginekits.com/osb/itemdetails.cfm?ID=2298
.. As far as I know, all aluminum heads already have screw in studs... aluminum is a little weaker, expands with heat more than iron/steel, and slippery, so prolly not a good substance for pushin studs that depend on just tight fit and friction to hold them in...
Top
#737640 - 11/06/09 04:45 PM Re: Let's talk cams... [Re: Dark Ember]
Yes, I'm running the Lunati with the stock, press in studs. Haven't had any trouble & I installed it close to 2 years ago.
Top
500/thumbs/MCSS_Side.JPG
by JP86SS
694/thumbs/DSC02204.JPG
by halfdozenbuzen
500/thumbs/BlueBomber.jpg
by PB86SS/87LS
832/thumbs/DSC01015_21.JPG
by mt5425
772/thumbs/monte17.jpg
by NVD_SS
MonteCarloSS.com Stickers
Order MonteCarloSS.com Stickers
Site Contributors
in the last Month:
RetroLSX.com
1NJIMID8TOR
chevelle502
miker82
1A Auto Parts
1A Auto Parts
BRP HotRods
GNS Performance
Mac-Ink Customs
MidNight Powder Coating
MV85SS Powder Coating
RetroLSX
SDCE
SMM Enterprises Inc.
Tri-Pro Automotive
