#718935 - 08/30/09 01:34 PM
Re: Intermediate shaft upgrade on flea bay
[Re: Tunedss86]
GuysMonteSS
Heres Aaron's phone # 1 303 807 1735,give him a call. Guy
#719027 - 08/30/09 07:26 PM
[Re: GuysMonteSS]
spacemanspif
Sewell, NJ
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=330351202746&viewitem=&_trkparms=tab%3DWatching
can anyone tell if this shaft is one that will work on out cars?
Mike
#729499 - 10/08/09 02:42 PM
[Re: onecool86]
TPI Monte SS
Moderator 15+ Year
Moderator 15+ Year
North Jersey
#735794 - 10/30/09 07:46 PM
[Re: LSJM1]
Duts87SS
Spanish Fort, AL USA
My Ebay "93-98 Grand Cherokee Steering Shaft" came in this week. I used a die grinder to open it up at the firewall end, made a notch in the in the steering column shaft with the Dremel, and she bolted up like a charm. Total install, including fab, was probably two hours. The bolt threads in both ends of this particular shaft were 3/8-16 (I thought for sure they would be metric). Comparing the Jeep shaft to the stock Monte shaft.  Modified and being installed. That's Anti-Seize in the opening; used it for lube as it was in arms reach.  Ready for the first test drive.
Dustin 87 SS
#735909 - 10/31/09 01:14 PM
[Re: LSJM1]
PB86SS/87LS
Administrator 20+ Year
by msubud73
by mightymonte10
by tonys57chevy
by jenifuriouSS
by Nino
