#717827 - 08/26/09 05:53 PM LED 3rd. brake light for around $10.00
irene Offline
irene  Offline
Toledo,Ohio
I just compleated turning my 3rd. brake light into LED for $9.95
I found a company in Holly Michigan,that makes led boards and I got a 6" red led wide view board off of them.
To begin,You need to take your light apart.
After you get it apart(2 screws),you toss out the chrome plastic and bulb. Then you peal off the sticky tape from the rear of the LED board and press it on to the screw studs inside the original housing.
Then you put the lens back on and screw it back together.
Push the wires down into the trunk and splice them together.
You are finished.
Hope this helps someone else.
The company that makes the leds can be contacted at icu2dad@aol.com
I am not a part of this company,and you may find a better deal some where else.
My photos are to big. But I can e-mail them if you want to see them.
Good luck
Irene
#731873 - 10/17/09 07:15 PM Re: LED 3rd. brake light for around $10.00 [Re: irene]
Kyp Offline
Kyp  Offline
Wayne, NJ
Thanks for the great write-up!! That looks real nice. I'll have to try this on my aerocoupe where the 3rd light is a different design. I'll pass along my procedure as well. Thanks again.
Family first, car hobby second makes for slow progress but memorable experiences.
HAVE: 1987 MCSS Aerocoupe, 1975 Pontiac Grandville Conv.
#732078 - 10/18/09 04:35 AM Re: LED 3rd. brake light for around $10.00 [Re: Kyp]
T-Top Tony Offline
T-Top Tony  Offline
Rialto, CA
Ok you just spliced the wires and connected them? Thats it?
1987 Monte Carlo SS with T-Tops, lowered with Belltech drop spindles and lowering springs. LS1 brakes up front and LT1 brakes in the rear. Trying to make a comeback!
whiteside whitefront
#771336 - 03/04/10 08:22 PM Re: LED 3rd. brake light for around $10.00 [Re: irene]
Michael T. Offline
Michael T.  Offline
Las Vegas, Nv
Great job on the pics and write-up. Thanks for your effort and sharing the process with all of us. I'll be converting my '86 SS with the LED bar and will "tweek" your procedure by painting the inside of the housing with silver/chrome paint for more illumination. Thanks again.
Michael T.
This ain't no dress rehearsal !
#771631 - 03/05/10 06:50 PM Re: LED 3rd. brake light for around $10.00 [Re: Michael T.]
redlineSS Offline
redlineSS  Offline
South Jersey
Post up a link to the company, you got that from, Please!
~Dave~
#771819 - 03/06/10 08:29 AM Re: LED 3rd. brake light for around $10.00 [Re: redlineSS]
Michael T. Offline
Michael T.  Offline
Las Vegas, Nv
I ordered one yesterday on ebay. $9.95 plus $1.95 S&H. The Ebay listing number is #390152645350 LED light strip wide view - red 12 volt - 6" long.
Michael T.
#772551 - 03/08/10 08:46 PM Re: LED 3rd. brake light for around $10.00 [Re: Michael T.]
Hi Folks,
Many PSA's lose their adhesion at high temperatures, and this area of the car can get quite hot (roughly 200 deg F) in sunlight. For this reason I'd use a mechanical fastening scheme as a backup - maybe, for example, some small nylon tie-wraps could be snugged in between the LED's and the screw bosses.
#786449 - 04/20/10 03:31 AM Re: LED 3rd. brake light for around $10.00 [Re: MAP]
I am about to do this upgrade, the socket for my brake light is rotted out by the sun which is why I am going to LED. Just ordered the LED board from EBAY and I am going to use wire to hold it in place.
#793121 - 05/11/10 10:34 PM Re: LED 3rd. brake light for around $10.00 [Re: MAP]
87Aerocoupe Offline
87Aerocoupe  Offline
Texas (DFW Area)
Originally Posted By: MAP
Hi Folks,
Alternatively: could you not simply cut slots in the outer edges of the curved reflector, insert the board, and tack it in place with some hotglue (on the back side)?
"all throttle, no bottle"
#807789 - 07/04/10 06:22 PM Re: LED 3rd. brake light for around $10.00 [Re: 87Aerocoupe]
Gill Offline
Gill  Offline
Little Rock,AR
Great post just found the item on ebay. Thanx for the pics and info
#807793 - 07/04/10 06:46 PM Re: LED 3rd. brake light for around $10.00 [Re: 87Aerocoupe]
MIKE D Offline
MIKE D  Offline
BROOKLYN, NY
Great info. I converted my 3rd brake light looks great. Took it one step further, ordered the same led board (color of your choice) and upgraded the interior floor lighting on the drivers and pass side. pm if you want pics
#840188 - 12/04/10 02:22 AM Re: LED 3rd. brake light for around $10.00 [Re: MIKE D]
85montanezcarloss Offline
Bayshore,NY
I like i will do too.
Stock bottom,Flat top pistons,Heads ported,RPM Air Gap intake,Lunati bracket master cam,Roller rockers,200R4,3:73 posi,650 Holley.
#841458 - 12/10/10 02:38 PM Re: LED 3rd. brake light for around $10.00 [Re: 85montanezcarloss]
VENNIX Offline
VENNIX  Offline
Louisville, KY
MIKE D pics to jachur02@louisville.edu your pm box is full and wont allow me to send anything any more
DerbyCity(502) 1986 Monte Carlo SS
#842009 - 12/13/10 07:35 PM Re: LED 3rd. brake light for around $10.00 [Re: VENNIX]
TMANN Offline
TMANN  Offline
ORLANDO, FLORIDA
Hey Guys,
Take a look at this one. It appears to be self contained.
SeaSense 4" Utility Strip Light 6 LED 12V Red 50023840
1988 Monte Carlo SS, T-Top,Black With Saddle Interior, Stock Engine and Transmission.
#846638 - 01/09/11 04:31 AM Re: LED 3rd. brake light for around $10.00 [Re: TMANN]
ksp135 Offline
ksp135  Offline
pikeville, ky
If you are looking for any LED bulbs, try this link.
http://www.autolumination.com/ I haven't bought anything from them but it looks pretty good. I own and operate an auto accessory business and it is hard to find all of these bulbs, sockets and pigtails in one location.
Also I am new to the site. Been watching the site for a while and just learning what's here.
The site looks great
Bringing back memories
after 17 years I finally bought another 87 MC SS
#849955 - 01/27/11 11:45 AM Re: LED 3rd. brake light for around $10.00 [Re: ksp135]
delreyss Offline
delreyss  Offline
del rey,CA
mike d i tried sending you a pm but your inbox if full. but if you end up reading this could you pm me some pics of the floor lighting
#856012 - 02/24/11 06:06 PM Re: LED 3rd. brake light for around $10.00 [Re: delreyss]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
About 5 years ago I made my 3rd brake light into an LED unit. I bought some of the kind with holes from Rat Shack and bought some red LEDs from SuperBright.com ...just make sure you use the correct current limiting resistors.
As strange as it seems you need to use red LED's (not white) for the light to pass through the red lens.
I held the board in place with high temp RTV.
#882600 - 07/02/11 07:44 PM Re: LED 3rd. brake light for around $10.00 [Re: Phil87SS]
Bladewalker Offline
Bladewalker  Offline
Fairport NY
When I was updating to LED using Irene's write up, I realized you could easily get two of the six inch boards into the housing with no problem. Is there any reason not to such as current draw or heat??
thanks
#883564 - 07/08/11 04:54 AM Re: LED 3rd. brake light for around $10.00 [Re: Bladewalker]
onecool86 Offline
onecool86  Offline
clarksville, tn
anyone tried this with the front turn signals or the sidemarkers?
#906654 - 12/03/11 05:48 PM Re: LED 3rd. brake light for around $10.00 [Re: onecool86]
MonteMan29 Offline
MonteMan29  Offline
Tampa Fl.
Looks like a easy enough project ty for the information . I think I will be doing this in the future aswell as getting some LED replacement bulbs for the tailights.
1986 Monte Carlo 4.3 my second Monte and won't be my last .
#926124 - 04/02/12 09:17 PM Re: LED 3rd. brake light for around $10.00 [Re: MonteMan29]
DutchSS Offline
DutchSS  Offline
The Netherlands
I followed this DIY (thanks for writing!), but I used two strips.
The result is perfect: a bright red 3rd brakelight that fills the whole surface.
So, my advice, when you do this, use two strips and not one.
#946822 - 09/26/12 07:13 PM Re: LED 3rd. brake light for around $10.00 [Re: DutchSS]
tall t-top Offline
tall t-top  Offline
San Antonio, Texas
Instead of a rigid board, I just got two 12 inch flexable red led stips from Autozone ($20) and just stuck them to the refector inside the light and trimmed off the excess. It looks great. As a backup I drilled small holes above and below the strips and just used some safty wire to hold them on.
Andrew
#983782 - 09/22/13 02:32 AM Re: LED 3rd. brake light for around $10.00 [Re: irene]
Rebelson101 Offline
Rebelson101  Offline
spring lake nc
how hot do they get? im wondering if with 2 strips some small vent holes or slots or something towards the top of the housing might be a good idea. with the sun hitting it all day and then you sitting at a red light for 5 min on the way home might be enough to melt something. just a thought.
ETHER RAY
#983937 - 09/23/13 05:20 PM Re: LED 3rd. brake light for around $10.00 [Re: irene]
TMANN Offline
TMANN  Offline
ORLANDO, FLORIDA
Hello Ethan,
LED typically do not get hot. I used two homemade strips of white LED's when I converted over (I didn't drill any holes). It will look a lot cleaner and brighter once finished. I even installed them is my reverse lamps, all inside bulbs were change as well. It looks really nice and bright.
Terence "TMANN"
#999768 - 04/10/14 01:25 AM Re: LED 3rd. brake light for around $10.00 [Re: irene]
87ttop Offline
87ttop  Offline
Chattanooga, TN
I wonder if I could use these in the taillights
500/thumbs/monteback.jpg
by Cimerian
500/thumbs/toms_monte-11.jpg
by 84casper ss
500/thumbs/tub_paint.jpg
by jnw86
871/thumbs/Foose_6.jpg
500/thumbs/Monte_Carlo_new_paint002.jpg
by troublesnc
