#711608 - 08/08/09 03:13 AM
STICKY: Every monte bulb part number you need!!!
83montecarlo632bbc
omaha nebraska
Well heres a list i put together of every part number for every light bulb on the monte ss, i recommend this be a sticky!! If any of these are wrong or im leaving any out let me know please!!
Ash Tray Light Bulb=wagner 1892
Back Up Lamp Bulb=OE TYPE #BP1156
Back Up Lamp Socket=ACDELCO Part # LS2
Brake Light Bulb=OE TYPE #BP2057
Clock Light Bulb=168
Courtesy Light Bulb=original #BP906
Dome Light Bulb=OE TYPE #BP561
Engine Compartment Light Bulb=original #BP93
Glove Box Light Bulb=OE TYPE #BP1895
Headlamp Socket=ACDELCO Part # LS144 (low),ACDELCO Part # PT1899 (high)
Headlight Bulb=4651(high), 4652(low)
High Beam Indicator Light Bulb=OE TYPE #BP161
Hood Light Bulb=original #BP93
Ignition Light Bulb=OE TYPE #BP168
Instrument Panel Light Bulb=OE TYPE #BP168
License Plate Lamp Bulb=OE TYPE #BP194
License Plate Lamp Socket=ACDELCO Part # LS247
Marker Lamp Socket=ACDELCO Part # LS247
Parking Brake Warning Light Bulb=OE TYPE #BP168
Parking Lamp Socket=ACDELCO Part # LS8
Parking Light Bulb=168(in dash), OE TYPE #BP2057
Radio Dial Light Bulb=OE TYPE #BP168
Seat Belt Light Bulb=OE TYPE #BP168
Side Marker Lamp Socket=ACDELCO Part # LS247
Side Marker Light Bulb=OE TYPE #BP194
Stop Socket=ACDELCO Part # LS6
Tail Lamp Socket=ACDELCO Part # LS253
Tail Light Bulb=OE TYPE #BP2057
Trunk or Cargo Area Light Bulb=OE TYPE #BP1003
Turn Signal Lamp Bulb=OE TYPE #BP2057
Turn Signal Lamp Socket=ACDELCO Part # LS248
3rd brake light bulb=OE TYPE #BP1156
1983 monte carlo ss "drag car" powered by 638 cubic inches of big block power 1985 monte carlo ss "street car" eventually will be powered by a 434 ci sbc f2 procharged
#713543 - 08/13/09 04:08 PM
Re: Every monte light bulb part number you need!!!
[Re: MikePEI]
MIKE D
BROOKLYN, NY
#721217 - 09/07/09 03:31 AM
[Re: MIKE D]
Shaun1414
Tulsa, oklahoma
Thank you, that was helpful
1987 Monte Carlo SS Aerocoupe. Edelbrock 3706 Intake, Kenwood KDC-mp435u head unit, B&M Street/Strip Shift Kit, Energy Suspension Poly Bushings, Holley 600CFM carb, Hooker Competition Headers, 3 inch X-pipe, 3 inch(in/out) Flowmaster 40's Accel HEI Distributor, MSD Digital Control Module, MSD Coil, Moroso Advance Kit. IceMan Chromoly Crossmember
#721281 - 09/07/09 03:37 PM
[Re: Shaun1414]
TURBO
TN Smoky Mtns
Great info. My 87 glove box light is a plug in bulb not a socket like the 1895. Any more info? Again, great find.
 87 SS White/ Saddle,t-top,350/330 hp
#721317 - 09/07/09 05:20 PM
[Re: TURBO]
Rich.S85SS
Long Island New York
 1985 SS, Hotchkis suspension kit, Edelbrock shocks and Air Gap RPM intake, Eibach Springs, Hurst quarter stick, GM crate 350HO long block, Edelbrock 650 AVS Thunder carb, MSD ignition, Hooker Headers, Steel cowl hood, Pro-Torque converter. Proud member NYMCC.
#735038 - 10/28/09 04:45 AM
[Re: woodss]
gmguy3car
Authorized Vendor
Authorized Vendor
Silverdale,Wa
Thats an exellent list.......Someone should sell a kit that includes all the bulbs for the whole car. Great Idea, I'll give it a shot and create a bulb kit and get the price and see if it sells. Thanks for posting this 83.
#735609 - 10/30/09 12:32 AM
[Re: woodss]
83montecarlo632bbc
omaha nebraska
how about a kit with all led bulbs for the whole car?
#784580 - 04/13/10 02:25 PM
[Re: Dr.D]
JBreu
Livonia,N.Y.
Saves a big Pain in the bass.GREAT JOB
1984 Monte Carlo sbc bored/stroked to 388 c.i. 514 Dynoed HP.700r4 w/2000 stall,12 Bolt w/4:10 Old Chevy's Don't Die, They Just Get Faster Best E.T. to date : 12.20 @ 110 MPH All Motor
#954651 - 12/09/12 04:02 AM
[Re: Cheford]
Robert 29
Oceano,Ca
#1021089 - 03/16/15 11:04 PM
[Re: 83montecarlo632bbc]
RoadWarrior
Mechanicsburg, Pa
168, 194 or 2825
they're all the same base, the only difference is the output. the factory 168 are only about 38 Lumens, the 194's are 25 lumens, but the 2825 are the brightest at 50 lumens.
MadMax 88 SS, 355 owned since '03
#1028647 - 08/27/15 03:52 AM
Re: STICKY: Every monte bulb part number you need!!!
Bitflipper
Las Vegas, NV
I thought I'd chime in on this thread with my LED lighting experience. After researching the LED light options, I decided to splurge on Sylvania bulbs for the dash after seeing some other people's experience with the cheaper kind burning out a lot. You can buy the high-end Sylvania bulbs for the dash and rear license area here: http://www.amazon.com/SYLVANIA-2825-Premium-White-Miniature/dp/B00AIJY2ZMHere is a photo of my dash lit up at night, no assistance from street lights or otherwise. My signature has a photo of the license area under the same conditions. (And incase someone is judging my mileage - it's a Canadian car so that's km's on the odometer and it's been around once; I replaced the face from an El Camino in a US junkyard when I relocated) That one dead area in the gear indicator area is somewhat unavoidable due to the bulky indicator mechanism blocking even the brightest light almost completely. Still, never imagined my dash could be so brilliant. Close to $100 in premium LED lightbulbs to do the dash and license area. The cheap bulbs with the multiple "light pads" on them might work for a time, though from what I hear, they're going to burn out on you in short order. I hope this is useful info for someone!
#1028652 - 08/27/15 03:11 PM
[Re: Ubowl]
Ole Blue
Lugoff, SC
What about the turn signal indicator in the dash You can go to the Album using the link at the top of this(or any) page and in the Search box type in Lamp Bulb Specifications to view every original bulb requirement. The page I posted there is from my original 'Owner's Manual'.
#1044463 - 10/17/16 05:49 PM
Maverick_Monte
Perry, IA
This list is a BIG help. I'm doing some upgrades to my '79. Had more than a few folks mention that my brake lights are not the easiest to see during the dayight. I used this post & Rockauto as a guide. Figured I'd replace most of the bulbs around the outside outside and the instrument panel ones as well as they are mostly original and, in the case of the instrument panel, some are burn't out too. Some of my PNs differ from the list, but I figure that is normal with mine being a 3rd gen. I have the OEM PN as well as what RockAuto calls "Maximum Brightness" listed below. Most of the Max Brightness are the PHILIPS CrystalVision series. Thought about LED, but that gets a tad pricey. 3 questions. - Do I have accurate OEM and Max Bright PNs?
- How many of each do I need?
- Am I missing any that I SHOULD upgrade?
- Is there a PN for upgrading the engine compartment light socket? The internal mercury switch crapped out on mine, so I ditched it.
- Any downside in going to the "Maximum Brightness" Bulbs?
- If memory serves, the 1157 Brake light bulb does the rear turn signal as well?
 Thanks in advance, Russ
by BLUE
by myfirstmontess
by PB86SS/87LS
by Chevy350
by hot rust
