#925907 - 04/01/12 08:35 AM
Re: CruizinKev´s 1979 Monte Carlo
[Re: CruizinKev]
Loc: overseas
Top
#926092 - 04/02/12 01:30 PM
[Re: CruizinKev]
Loc: Stafford, VA
Awesome congrats Kevin. As for the name of that piece...not a clue Sorry. Things are looking good though.
_________________________
Frame Off Restoration in Progress 84 Monte Carlo SC 406 SBC 78 Monte Carlo 305 sbc SOLD 78 Monte Carlo Landua 350 sbc SOLD 81 Malibu Classic 350 sbc SOLD 84 Monte Carlo LS 350 sbc SOLD 84 Buick Regal 229 v6 SOLD
Top
#927996 - 04/15/12 04:27 AM
[Re: CruizinKev]
Loc: overseas
Top
#928080 - 04/15/12 08:47 PM
[Re: CruizinKev]
Moderator 10+ Year
Loc: North Jersey
Great, looks awesome Kevin!! Nice progress!
Top
#928122 - 04/16/12 01:31 AM
[Re: TPI Monte SS]
Loc: St Charles , Mo
Doesn’t get better than that , well done !!!
 OUT OF THE DARKNESS RIDES THE DARK HORSE ... " HEY - O " ... LET THE HORSES RUN 502 HP, 383, Coan 350 Extreme, GV overdrive, Currie 12 bolt
Top
#929068 - 04/22/12 03:53 AM
[Re: Hey-O]
Loc: overseas
Top
#929339 - 04/24/12 08:29 AM
[Re: CruizinKev]
Loc: Austin, Texas
Good job Kevin!!!
 __________________________________________ My Web Page
Top
#930933 - 05/05/12 02:53 PM
[Re: CruizinKev]
Loc: overseas
Top
#930936 - 05/05/12 03:01 PM
[Re: CruizinKev]
Kevin , It looks great !!! I’ll be cutting another inch off mine today . It looks and fits like it was made for the car , well done !!!
Top
#931000 - 05/06/12 11:08 AM
[Re: CruizinKev]
I cut mine off so the bottom of the dash sticks out 1 inch in front of the side kick panel . I was going to cut it again to bring it even with the kick panel on the bottom , that would have been one more inch . I decided to leave it stick out as far as I could to leave as much room as possible under the dash because of the heater . It looks like you cut off more then I did . My center gauge sits right at the joint for the tilt wheel . My goal was to bring the dash closer to the driver for an in your face look with out interfering with anything . The dash looks like it came in the car originally . I bought a new glove box insert which will have to have a corner cut off to clear the heater because of depth problems , no big deal . The brackets will go from the two center speaker holes that are left out of the four that were there to hold the old speaker in , to the original lip that the old dash laid on which I‘ll cover with a piece of the fuzzy half of Velcro to keep metal from metal contact . This will be done so it can be mounted from the top and the grill snapped in to cover it up when done . The welded end caps should be made big enough so you can mount it to the side kick panels from underneath with a screw / bolt . I’ll leave it at that and check if it needs more anchor points , then add as needed . The heater gets in the way of most everything , I’ll just deal with it as I go . I sandblasted it first so I could prime it , it makes it easier to see the marks and the lay out points I drew on it before cutting , nice and clean . It’s unbelievable how much I love this dash and how great it looks in it . Even my wife thought it looks great . The most important thing to me is it look as if it came with it from the factory !! I bought two extra ashtrays that I’ll use the skins off of to close in where the old heater controls and anything else , there already the contour of the dash , easier then bending my own . I’m welding on a skirt at the bottom of the dash for the vents , I’ll do that after the console is located so they flow into it and give the look as if they continue down as part of the console . All this can be done anyway you want for what ever look your looking for . There is no right or wrong .
If your not going back with your heater you can weld angles along the bottom of the dash and bolt anywhere , much easier .
Top
#931009 - 05/06/12 01:06 PM
[Re: Hey-O]
Loc: Abingdon, Maryland
I'll already oogling this dash!! CANT wait to see it in final trim! Going to look great in the car. Very nice work so far, and good parts choices
 LsX: DO IT~ 11.32 @120mph
Top
#931033 - 05/06/12 06:21 PM
[Re: Sixtoes1313]
IMG] http://i60.photobucket.com/albums/h1/CruizinKev/KevsMonteCarlo/2012-05-05/IMAG0268.jpg[/IMG] Adam , The reason for the 59 /60 dash for me was the fact the passenger side has the same basic profile as the drivers side . The gauge pods will be about as far out as the original was but the difference being the passenger side comes out also . It gives it the feeling of seating in what feels like a control center with everything somewhat around you . Any dash from the mid 50’s to the mid 60’s will be installed basically the same way . The one difference with the 59 / 60 dash over the others is there is a definite center line to follow with the big gauge and column . Our column doesn’t line up center if you cut equal amounts off each end of the dash . It’s about 3/8’s off of center . This would not be an issue with any other dash . The other choose was 60 corvette which if you look at it has somewhat of the same profile . All metal wins every time . I relies that this isn’t for everyone , but I’m not a fan of plastic . It’s fine in my everyday driver , but it’s so nice to make it anyway you want by welding and cutting here and there .
Top
#931867 - 05/13/12 12:42 PM
[Re: Hey-O]
Loc: overseas
Top
#932709 - 05/19/12 02:55 PM
[Re: CruizinKev]
Loc: overseas
Top
#932710 - 05/19/12 03:48 PM
[Re: CruizinKev]
Kevin , You do fine work my friend !!! Those seats are going to look sweet in that car , well done !!!
Top
Moderator: 85_SS, Dalt10, Gruvin84SS, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, TPI Monte SS
by MikePEI
by PIMPC3692
by 94ONLYSS
by javi05
