Topic Options
#638547 - 01/15/09 12:30 AM Speedometer Needle Wiggles, Removing Speedometer??
Trevor Johnson Offline
Loc: Roanoke, Texas
I was repalecing the bulbs in the speedometer on my Monte SS. I pull everything back together, take it out for a drive. I notice that as the needle moves up and down it wiggles real bad as if something is in the gears. You hear a tick the faster you go, it gets faster. What would have caused this and how can I fix it? I don't know how to take out the speedometer completely. I would like to take it out and make sure that nothing fell in there causing it to start ticking like that and wiggling. I know there is a way to remove the speedometer and I just can't figure it out. Also the Speedometer worked just fine before I moved it a little. Thanks for the help guys. I do appreciate it. Trevor
Top
#638614 - 01/15/09 10:37 AM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: Trevor Johnson]
TPI Monte SS Offline
Loc: North Jersey
That sounds more like a cable issue, than the speedo itself. If you moved it, you might have put a kink in the speedometer cable. On the back of the speedometer head, there's a tab that you need to squeeze to release the cable. Try checking it to make sure it's not binding anywhere and reconnect it. If you didn't have any issues with it before, it's probably something that happened when you reassembled the dash. Good luck!
_________________________
SSeeya,
Steve Ragusa - North Jersey
Top
#638617 - 01/15/09 10:54 AM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: TPI Monte SS]
QuikZilver Offline
Loc: Delray Beach,FL
I agree with TPI. If after checking the cable, the speedo still jumps and clicks, then pull speedo back out, pull cable out and lube cable. Or, go ahead and lube cable while you have the speedo out so you don't have to pull it back out. Any parts store sells the speedo cable lube.
1986 Monte Carlo SS - lots done to it!
2008 Chevrolet Corvette - 530+rwhp 418 Stroked LS3
1970 Chevrolet Camaro RS/SS - Next project
2007 Dodge Charger Daytona R/T #981 of 1400 Plum Crazy's
2007 GMC Yukon XL - my new DD
Top
#638667 - 01/15/09 01:40 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: QuikZilver]
Loc: Roanoke, Texas
Ok I will look at it for kinks how do you go about lubing the cable?
Top
#638686 - 01/15/09 02:57 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: Trevor Johnson]
baaboo Offline
Loc: Racine, WI
Remove cable at the the rear of the speedo, pull cable out, and clean. If it worked good before, I'd make sure the rear attachment is back where it should be. I also used brake cleaner to flush junk from the housing, THEN lube it. Use compressed air to dry it out first.
Top
#638728 - 01/15/09 05:24 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: ]
Loc: Roanoke, Texas
OK what do I lube it with? thanks
Top
#638764 - 01/15/09 06:35 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: Trevor Johnson]
84montecarloss Offline
Loc: Cedar Falls, Iowa
go to your local parts store and they will have speedo cable lube
Dale Earnhardt Sr He may be gone but he isn't forgotten
1984 Monte Carlo SS 1/2 mine, 1/2 dad's
1987 Pontiac Fiero TOTALLED 1984 Fiero DD
people around home call me greasemonkey.
AIM: adams63283
Top
#643270 - 01/29/09 04:49 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: Trevor Johnson]
sapost Offline
Loc: Wood Dale, Illinois
I have the same issue on my '86. I wasn't able to remove the speedometer needle - did you have any luck?
Top
#643295 - 01/29/09 06:06 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: sapost]
Loc: Roanoke, Texas
haven't tried yet man.
Top
#643315 - 01/29/09 07:13 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: Trevor Johnson]
Loc: Ontario, Canada
Why do you want to remove the needle?
Speedo heads rarely malfunction (I've actually never heard of it). It's almost a guarantee that the cable needs to be lubed or replaced as mentioned
Top
#643328 - 01/29/09 08:15 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: 85_SS]
rmodys Offline
Loc: Ft. Myers, Florida
Mine made an awful squeaking after getting about 150 miles on the engine and drivetrain after a total rebuild. We just pulled out the cable and lubricated it, problem solved. The needle still wiggles a little bit but it doesn't squeak anymore. While you're in there you might as well do the lighting upgrade and maybe even replace the headlight switch if it needs to be done.
1986 Monte Carlo SS. Family owned 1987-1999; 2004-present, rust-free Florida car, L69 with TPI, B&M shift kit, 3.73 posi, new PUI interior, t-tops, lowered 2", refinished stock rims, Goodmark cowl hood, and amber DRL's.
Top
#643651 - 01/30/09 05:18 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: rmodys]
sapost Offline
In order to remove the speedometer, I need to remove the needle first right? Is there a better way to remove the cable and lube it without removing the speedometer?
Top
#644373 - 02/01/09 06:22 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: sapost]
daveSS1987 Offline
Loc: Enfield, CT
No don't remove the needle. You have to remove the small silver bolts that hold the speedometer to the inner housing (the blue plastic) then pull it out far enough to reach back & press in the clip that retains the cable. the speedo should pull right out then but there is a wire holding the VSS to the back of the speedo that has to be removed if you want to take out the speedo.
Top
#644470 - 02/01/09 11:32 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: daveSS1987]
83montecarlo632bbc Offline
Loc: omaha nebraska
sometimes you cant pull it out far enough to get to the clip, better off reaching from the bottom and pressing the clip, all 3 dashes i have taken out i had to reach through all of the wire throught the bottom
1983 monte carlo ss "drag car"
powered by 638 cubic inches of big block power
1985 monte carlo ss "street car"
eventually will be powered by a 434 ci sbc f2 procharged
Top
#644592 - 02/02/09 01:53 PM Re: Speedometer Needle Wiggles, Removing Speedometer?? [Re: 83montecarlo632bbc]
sapost Offline
Thanks for the help guys - I really appreciate it!!
Top
500/thumbs/My_old_87_Aerocoupe.jpg
by 86asccoupe
546/thumbs/MVC-016S_1.JPG
by 86AeroDave
865/thumbs/sneakpreviewtake2.jpg
by THEmean1
500/thumbs/SS_Front.jpg
by QuikZilver
500/thumbs/Radfan.jpg
by 87/88 SS's
Site Contributors
in the last Month:
ronnie84ss
BADD87SS
Monte_ExpreSS
Steve Lane
notsocleverusername
jwc55
MonteCarloSS.com Stickers
Order
Stickers
