#610154 - 09/30/08 06:58 AM
Re: Intermediate shaft upgrade on flea bay
[Re: grwhite038]
Minotaur15
Manahawkin NJ
Not sure what you see on Ebay, but I went with a flaming river collapsable shaft with stainless u-joints on top and bottom. Never have to worry about a loose feel from the intermediate shaft again, thats for sure.
Dan - minotaur15@hotmail.com Used to have: '86 MMC Road Course Ready 2020 Kia Forte GT Manual - Daily Driver
#610214 - 09/30/08 04:18 PM
[Re: Monte_ExpreSS]
Travis Jones
eliminating the rag joint will probably give you all kinds of squirm in the wheel going down the road. not to mention the vibration
#610222 - 09/30/08 04:55 PM
[Re: Travis Jones]
grwhite038
Virginia Beach, Va
any feedback from anyone running the flaming river setup
also found this on a blazer forum So anyway. The shaft is a perfect fit. My steering wheel is the straightest it's ever been, and plenty of space between the manifolds and the shaft. I breathe a sigh of relief.
So Grappler and I take it out for a test drive and beat on it pretty hard. As I said, the steering wheel is straight, responsiveness and tightness is incredible (especially w/ my ZQ8 steering box). The truck practically drives itself now! I don't have to swing the steering wheel back and fourth to keep the damn thing straight anymore! YAY! Several miles and tons of turns and curves later, I'm quite happy.
On my way home, I start thinking. GM put the rag joint in, in part for vibration dampning. Hmmm. We really didn't run it through a test for that. What can I do? Well, this being Pennsylvania, the Pothole capital of the world, and being in Pittsburgh, the cobblestone capital of the world, I figured a little more testing was in order.
First I head down some side streets where I know there are some bad potholes. Pretty good, but very hard to tell if there is any vibration when your truck is rocking back and fourth on the pothole slolam (sic?) I needed something else. I head for Squirrel Hill. (Those of you who live around here know what that area is like) I drove 2 miles worth of cobblestone streets. Not one iota of vibration through the steering column. It was a very smooth (albeit noisy) ride. I'm happy...
But wait! There's more!
I figured a speed test was in order. A lot of vibration can happen at higher speeds. Had to do it. I hit I-279. It's me, the road, the truck and a Venti coffee w/ a shot. (I picked up Starbucks). 50, 60, 80, 96 MPH.....Smooth as glass! I finish my coffee and go home.
So in conclusion, for an average $25.00 or less and 2 hours of your time, you can have this mod and eliminate that damn steering slop causing rag joint and be happy! Just please be aware, this is a PERMANANT modification. Once you cut that stem off the steering shaft you are committed. It's not a hard mod. On a 1-10 difficulty level, I would rate it a 5. If you do do it, you will love it and wonder why you didn't do it sooner. If you decide not to do it, you can remain jealous of those that have and continue to complain about your steering slop.
and this update Update It's now 1-1/2 years later, no issues to date with the steering or handling.
you know what I think I talked myself into it. I'm in the process of rebuilding so once i get it all together and on the road i will let you all know.
#610368 - 10/01/08 02:35 AM
[Re: grwhite038]
TPI Monte SS
Moderator 15+ Year
Moderator 15+ Year
North Jersey
I know they said the ZJ ('93-'98) Grand Cherokees are a good donor for the shaft, but they share a lot of steering components with the smaller Cherokee (XJ). I'll measure the steering shaft on my '01 Cherokee Sport tomorrow if the weather cooperates and report back if it'll work as a donor. I also found this thread over on ROP - http://www.oldspower.com/vb/showthread.php?p=370166 with some good pics and info about doing the ZJ steering shaft swap too. There is no cutting or welding necessary, the only reason they mention cutting of the steering shaft in the link copied from the S-series forum is because the 2nd-gen S-truck ('94-up) has a longer piece coming out from the firewall and needs to be shortened to allow sufficient room for the shaft to collapse. It's not an issue with the G-body.
#610433 - 10/01/08 12:11 PM
[Re: Travis Jones]
Minotaur15
Manahawkin NJ
eliminating the rag joint will probably give you all kinds of squirm in the wheel going down the road. not to mention the vibration I have to say, I could not be happier without a rag joint. Vibration? Not really, and though it was a long time between factory parts and my mods, I think there is about -zero- difference in vibration transmittance. Steering is rock solid and a pleasure!
#610479 - 10/01/08 04:32 PM
[Re: SickSpeedMonte]
TPI Monte SS
Moderator 15+ Year
Moderator 15+ Year
North Jersey
BTW, the 2nd gen S10's are 94+
Thanks Bernie, I updated my post to reflect that.  I'm going to be on the hunt for one of those ZJ steering shafts as well!
#610971 - 10/03/08 11:50 AM
[Re: TPI Monte SS]
SickSpeedMonte
Thanks Bernie, I updated my post to reflect that.  I'm going to be on the hunt for one of those ZJ steering shafts as well! Hey man, no problem  I've got one and the damn thing is driving me up a wall.
#611053 - 10/03/08 07:09 PM
[Re: robs 85ss]
Minotaur15
Manahawkin NJ
Rob, I know this probably won't work for your situation, but there is always www.flamingriver.com
#611125 - 10/04/08 12:51 AM
[Re: grwhite038]
robs 85ss
pa
Ok guys now that ive had some time to look at it the top U joint just might work, it is a VERY tight fit at least in my case. Tomorrow morning I will hopefully get it in. The top bolt was a 7/16ths head also. Ill take pics tomorrow and report back.
If all else fails I just might be calling up the guys at flaming river and opening up my wallet haha.
Rob
1985 Monte Carlo SS Nasty 355/ Tremec 5 speed
by mightymonte10
by Joe87monteSS
by carlosmontez
by amendez86
by 84casper ss
