#606730 - 09/18/08 06:24 PM Big Block Oil Pan in G-Body
roughskinjrz Offline
Miramich, NB
hey well i ordered an oil pan Moroso MOR-20460 which i thought would be alright but i guess they engine shop is telling me its way too deep and i should go shorter and wider if need be.
MOR-20460
- 8 quarts
- 9.750" depth
- 4.250" maximum stroke
- also MOR-23030 windage tray
- also MOR-25970 oil dipstick
- also Summit SES-3-90-08-007 oil pump/pickup
i CANNOT use this and all we be for sale. but wondering who is riding a big block and what oil pan are you using with no complications. the shop would like to know ASAP so they can order me a pan.
489 BBC, Eagle Steel 4.250 Crank, Eagle 6.385 Forged Rods, SRP 0.030 Flat Top Forged Pistons, Crane Z 244/256 .632/.632 Roller Cam, Pro Comp 320cc Heads, Harland Sharp 1.7 Roller Rockers, Weiand 8-71 Blower, 2 x 800cfm Barry Grant Mighty Demon Blower Carbs. TH400 Trans Brake, Full Manual Reverse Valve Body. QP Ford 9" 3.70 Gears Spool 31 Spline.
#607365 - 09/20/08 07:19 PM Re: Big Block Oil Pan in G-Body [Re: roughskinjrz]
BBCregal Offline
BBCregal  Offline
aaaaa
I am using the stock oil pan. I think my big block was from an early 80s truck.
#607372 - 09/20/08 07:39 PM Re: Big Block Oil Pan in G-Body [Re: BBCregal]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
stock from a 95 truck fit mine then i got a steff's pan it was a seven quart, 8" deep and 4" at the front i think
#607374 - 09/20/08 07:45 PM Re: Big Block Oil Pan in G-Body [Re: pazzo1969]
SS402 Offline
SS402  Offline
Beaverton, Oregon
i have same pan in my Monte and it fits well, the only thing i scrape is the collector flanges..
George
Monte, Gone but not forgotten
The More I Learn About Dogs
The Less I Like About People
#607459 - 09/20/08 11:44 PM Re: Big Block Oil Pan in G-Body [Re: SS402]
Miramich, NB
yeah i figured it was just the headers im running 2" hooker super comps. do you have enough power to lift the front wheels off the ground? im just worried about hitting mostly when i come back down.
#607484 - 09/21/08 01:16 AM Re: Big Block Oil Pan in G-Body [Re: roughskinjrz]
Dru1376 Offline
BANNED
Dru1376  Offline
BANNED
New Jersey
#607486 - 09/21/08 01:30 AM Re: Big Block Oil Pan in G-Body [Re: Dru1376]
Chevyman540 Offline
Chevyman540  Offline
LaPorte, Indiana
When I mocked up the big block, I had a Moroso 8qt. deep pan. It hung down below the front crossmember by 2 inches. It fit, but hung too low for my needs. I ended up using a Big End BEP 43011 6qt pan with kickout sump. Fits good. I'm sure Moroso makes the same style pan for a few more dollars.
87 MCSS 540 BBC 736hp@6300 677tq@4800 t400w/transbrake 9"rear 4.30 gear
#607773 - 09/22/08 02:20 AM Re: Big Block Oil Pan in G-Body [Re: roughskinjrz]
SS402 Offline
SS402  Offline
Beaverton, Oregon
if the car would hook, probably..
i finally got the low-down on g-body suspension mods and will be replacing and relocating the upper control-arms with adjustable units and relocation brackets, when i'm done the "instant-center" will be 6" off the ground and 50" in front of the rear-axle centerline. throw in some double-adjustable shocks..then see if i can break the axles..lol
George
#607780 - 09/22/08 02:51 AM Re: Big Block Oil Pan in G-Body [Re: SS402]
Miramich, NB
im running double upper adjustables and relocation brackets, i was told to make travel limiters which is what im going to do.
#608047 - 09/23/08 01:35 AM Re: Big Block Oil Pan in G-Body [Re: roughskinjrz]
SilverSS Offline
SilverSS  Offline
Ocala, FL
I've got the Moroso 20403- it fits good
550/thumbs/small118.JPG
by stonecoldtim
500/thumbs/IMG_0390.JPG
by PrinceJay
by GearedSS
500/thumbs/Monte_Radio.jpg
by Chevyman540
500/thumbs/after2.jpg
by 87/88 SS's
