Topic Options
#597556 - 08/18/08 06:26 PM 200r4 tcc solenoid switch wiring.
WildMonteFan Offline
Loc: missouri
Hello again everyone!!!
Well i have been looking at posts for the last hour and a half and i am still confused lol. I would like to know how to wire a switch for my lockup converter. i have 3 wires that come out of the plug on the side of the tranny. i have found explanations for 2 of the 3 wires. can anyone could tell me what color to hook and were on a switch??? thanks in advance!!!
_________________________
1985 Monte CL Soon with 350.
350 build now in progress!
Top
#597679 - 08/18/08 11:05 PM Re: 200r4 tcc solenoid switch wiring. [Re: WildMonteFan]
Loc: missouri
Maybe someone has some pictures? Im not very swift with wiring but i can do it if i need to.
Top
#597959 - 08/19/08 10:56 PM Re: 200r4 tcc solenoid switch wiring. [Re: WildMonteFan]
Loc: missouri
does anyone know about this? i am happy to wire in just a toggle switch for now. i still dont know how though frown
Top
#598009 - 08/20/08 04:59 AM Re: 200r4 tcc solenoid switch wiring. [Re: WildMonteFan]
Retro Offline
Loc: Macon,Ga.
Top
#598503 - 08/21/08 05:50 PM Re: 200r4 tcc solenoid switch wiring. [Re: Retro]
Loc: Antioch, California
86 MCSS Notchback coupe, stock, silver with maroon bench interior. 2007 Best in class and best Monte Carlo show winner, Super Chevy Show, Fontana, Ca
Top
#598517 - 08/21/08 06:19 PM Re: 200r4 tcc solenoid switch wiring. [Re: upflying]
rons87mcss Offline
Loc: Albion, Pa
I'm gonna spend some time and actually figure out what the three wires do in the plug that goes to the trans.
EVERY post, link, etc I have ever read doesn't really explain anything about what I would like to know. I have been trying to read every post that I see that has something to do with this and I have yet to get an answer to my question. It would seem a TON of people had to of done exactly what the original poster has asked about hooking up a simple toggle switch (a switch that is "on" or "off") to operate the lock up of the converter.
Does anyone know how to do this?What does 12 volts to the purple wire do? Lock the TC? Unlock it? I thought the computer supplied a ground to the purple wire? Which wire do you either interupt, or supply power or a ground to of those three wires going to the trans. It would be great if someone could explain how they did it without posting a link to an aftermarket kit that doesn't really explain anything unless you buy the kit.
I think my TCC is bad since my car feels like the TC is locked up when it shouldn't be.
Anyone?
Top
#598520 - 08/21/08 06:21 PM Re: 200r4 tcc solenoid switch wiring. [Re: rons87mcss]
SSLance Online   content
Loc: Smithville, MO
I'm not sure but I'm anxiously awaiting what you find out on this topic...
I've got power where it's supposed to be on my connector at the trans...but mine does NOT lock up.
Top
#598548 - 08/21/08 08:26 PM Re: 200r4 tcc solenoid switch wiring. [Re: SSLance]
rons87mcss Offline
Loc: Albion, Pa
SSLance, I believe that would be a problem with the TCC solenoid(?) or whatever the tech name of it would be. I think Paul has a thread in the DIY section if you haven't read that yet.
Top
#598609 - 08/21/08 10:18 PM Re: 200r4 tcc solenoid switch wiring. [Re: rons87mcss]
Retro Offline
Loc: Macon,Ga.
Top
#599073 - 08/23/08 03:05 PM Re: 200r4 tcc solenoid switch wiring. [Re: Retro]
rons87mcss Offline
Loc: Albion, Pa
THANKS Retro thumbs
Just what the doctor ordered, or patient needed smile .
Top
#599096 - 08/23/08 04:51 PM Re: 200r4 tcc solenoid switch wiring. [Re: rons87mcss]
Loc: Smithville, MO
The other thread linked has this way to test.
"Just ground pin "F" of the ALDL connector under the dash and it will accomplish the same thing. Pin "A" is ground, you could do it with a paper clip if you wanted to."
When would one try this? when traveling above 45 mph in 3rd or 4th gear?
Top
#599969 - 08/26/08 06:14 AM Re: 200r4 tcc solenoid switch wiring. [Re: SSLance]
Retro Offline
Loc: Macon,Ga.
Answer=
could i check the constant positive with just the key in the on position with out turning on the car?
Yes.
Should be able to hear the solenoid click when testing. Could also be tested at speed with a jumper in Pin F & A of ALDL. Paper clips & aligator clipped test leads. So your not driving with your head under the dash. LOL!!
Top
#600082 - 08/26/08 02:26 PM Re: 200r4 tcc solenoid switch wiring. [Re: Retro]
Loc: Smithville, MO
So if grounding pin F doesn't do anything...and I know I've got 12 volts to the connector at the trans...I'm guessing the next step is to replace the TCC solenoid huh?
Top
#600177 - 08/26/08 08:25 PM Re: 200r4 tcc solenoid switch wiring. [Re: SSLance]
Loc: Smithville, MO
Well, let me take that back. Above 45 mph, when the "F" pin is grounded to the "A" pin...the TC DOES lock up... laugh
That's the good news...because I think it means I don't have to drop the trans pan again. The question now is...what do I have to find now to get the ECM to lock up the TC?
Top
#600273 - 08/27/08 03:54 AM Re: 200r4 tcc solenoid switch wiring. [Re: SSLance]
Retro Offline
Loc: Macon,Ga.
More things to check, maybe 1 of these will help you out.
http://www.turbobuick.com/forums/transmi...ot-lock-up.html
http://www.turbobuick.com/forums/transmission-talk/260965-converter-will-not-lock.html
http://www.turbobuick.com/forums/transmission-talk/260212-tcc-valve-question.html
Top
#600293 - 08/27/08 07:42 AM Re: 200r4 tcc solenoid switch wiring. [Re: Retro]
maverick Offline
Loc: Stearns Ky
http://www.chevyasylum.com/tech/4thgear.html
This is the article I used for my lock up mod. Now my convertor locks up whenever my car hits overdrive, and unlocks when I hit the brakes or downshift from od to third. I love the way it works. I don't have to worry about forgetting the toggle switch and stalling the motor when I stop. I did have to order the pressure switch the article mentions at the bottom. I think it was like $13 plus shipping. It only takes about an hour to do this, and is well worth it.
Top
500/thumbs/front_logo_1_.jpg
by Rodney
500/thumbs/2638192_14_full.jpg
by FiremanIFD
500/thumbs/030.JPG
by dcvp
500/thumbs/PA080075-small.JPG
by ProTourAero
564/thumbs/oscars_LS_MONTE_CARLO_003.jpg
by Big Reazon
MonteCarloSS.com Stickers
Order MonteCarloSS.com Stickers
Site Contributors
in the last Month:
GuysMonteSS
montaguemonte
amazine
71BLACKSS454
1A Auto Parts
BRP HotRods
GNS Performance
Mac-Ink Customs
MidNight Powder Coating
MV85SS Powder Coating
RetroLSX
SDCE
SMM Enterprises Inc.
