#595981 - 08/13/08 05:42 AM 1978 Monte Carlo-factory 4-speed found
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Okay, I cannot find any info on production numbers for the 4-speed cars. Can anybody help? This car is a black hardtop-no vinyl, dark red 60/40 split bench interior with a V8 and a 4 speed. Has the rear anti-sway bar but other than that, no options. AC delete even. The body is pretty nice too as are the framerails. I'm thinking about stripping it for the pedals which I can use on my 1980 t-top car for my build but since this is the very first verifiable 4 speed I've ever found for 78-80 Montes, I am reluctant to strip it even though it is a bare bones optioned car otherwise.
gbodyparts1234@yahoo.com
HARNESSWORX
#596010 - 08/13/08 12:17 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: gmachinz]
robs 85ss Offline
robs 85ss  Offline
pa
I wouldnt strip it for the pedals you can buy them cheap enough on musclecarsonly.com The car sounds pretty cool any pics?
1985 Monte Carlo SS
Vortec headed 357 smile
Muncie m20 4 speed.
#596064 - 08/13/08 03:55 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: robs 85ss]
monteman1978 Offline
Downingtown, PA
DO NOT STRIP IT!!! I do not have the exact #'s on how many 4 speed 78's that where made. But they are a very rare car. If you do not mind cound u take as many pics as possible and send them to tgmcc@thirdgenmontes.com cause I am rebuilding the Third Generation Monte Carlo Club and would like to have it in the site when it is done. Come check us out soon. www.thirdgenmontes.com or www.thirdgen.tk rite now the only thing running is the forum.
Audrey C. Duff Memorial Car Show @ the Relay 4 Life 5/16/09 11-4PM www.acdcarshow.com
Keep On Walkin Until A Cure For Cancer Is Found.
In loving memory of Mom.
President of the PA Chapter of MMG
Always looking for new members. We can be found at
www.mmgpa.motortopia.com
#596118 - 08/13/08 07:43 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: monteman1978]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
I have to agree, don't strip it. Keep it & restore it someday, buy the clutch pedal from John Bzdel. It is no different than the ones you have except the bolt is longer, some bushings & the brake will need trimmed. I wish I could find one to build someday.
#596262 - 08/14/08 03:54 AM Re: 1978 Monte Carlo-factory 4-speed found [Re: Tunedss86]
mountainman Offline
mountainman  Offline
Balsam Grove, NC
I had a 1978 monte with a factory 4 speed but it had a V6(Buick 231). I had it back in 1984 till 1987 with I sold it for a truck what a mistake. If I remember I read somewhere back then there were only 1700 made with the V6. But I could be wrong. My wife found the car years later but it had no motor or tanny and had been wreaked so I did not get it.
#596477 - 08/14/08 11:40 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: mountainman]
gbodydude496ci Offline
scranton,pa
do not strip it!! these cars are getting rare every day. people are junking cars every day.
85'monte ss race car with a cage and notch frame.soon to have my bbc and t400 trany wih a 9inch rear.86'monte ss sbc,200r4 plan for it.
#596536 - 08/15/08 02:54 AM Re: 1978 Monte Carlo-factory 4-speed found [Re: gbodydude496ci]
We have junk yard here closing, price of scrap is so high a junk car will bring $300. If you have 200 junkers in your yard that is a lot of cash.
I have mixed feeling about the 3rd gen Montes. If the body is junk, which many are at THIRTY YEARS OLD, I would take the stick parts out of it and leave it for someone else to pick on. If the body is good, and particularly the front and rear bumpers, lights, grille, maybe consider buying it to resale. Those are the hardest parts to find in fair condition, really hard to find good pieces.
If it's a V-8 car take everything related to the stick, bell, fork, linkage, pedals, leave the Saginaw 4 spd, flywheel, clutch. The flywheel is a two piece seal and most likely junk. If the clutch is used forget it, probably mostly a non-performance piece anyway. The Saginaw is at best comparable to a T5 for strength, usually a 2.87 1st gear, BUT NO OD.
Decisions, decisions, to many decisions.
#596588 - 08/15/08 12:18 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: mmc427ss]
robs 85ss Offline
robs 85ss  Offline
pa
Hey mmc427ss Im pretty sure your the guy I met at the kimberton car show.
If you do end up parting it you might want to save the trans/shifter hump console and boot as these would make good conversion pieces for someone. This is if they are using the saginaw of course. Also incase you run into a v6 3 speed car somewhere the bellhousing and clutch fork are the same as the v8 cars. (78-81)
1985 Monte Carlo SS
Muncie m20 4 speed.
#596706 - 08/15/08 08:21 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: robs 85ss]
Downingtown, PA
Man either way do not part it out. The body is repairable as long as the rust did not make it into the a-pilers.
#596744 - 08/15/08 11:23 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: monteman1978]
BADD87SS Offline
BADD87SS  Offline
belton, mo
I didn't know they made V8 4 speeds in those years. i always thought and heard, that if they were 4 speeds, then they came with a V6 only.
In that case, its really rare.....
87 SS/54767 original miles
07 Monte SS
86GMC4X4/355/700R4/4.56
#596865 - 08/16/08 01:26 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: BADD87SS]
robs 85ss, yes we met at Kimberton. Should have stopped over to talk a little. Sean, monteman1978 and I know each other also, he is just a LITTLE biased toward 3rd gen Montes.
I've seen several 3rds in the U-Pull yard around here and they are usually rusted very badly and would cost a bundle to bring back to life.
#596872 - 08/16/08 02:03 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: mmc427ss]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I have seen only one other manual equipped 3rd gen and it was a V6 car prior to finding this one. I would not have much fun driving it in the humid midwest being a black car with AC delete-ugh! But it is rare. I don't know how many memebers know, but I also have what I believe to be THE rarest Malibu as far as any I've seen from anybody else-and it was a Maliburacing.com member who won it on Ebay two years ago and it changed hands twice before I ended up with it through shear dumb luck and it's never going to leave my possesion. It's a factory triple black 79 Malibu and here's the total list of options it has according to the build sheet which matches the car and its optons: 305/4-barrel, 4-speed with the optional Hurst shifter, buckets, console, pw, pdl, rear defrost, AC, tilt wheel, tach/gauge package, pulse wipers, AM/FM digital stereo(wow), power antenna, fr/rr bumper guards, F41 suspension, 2.73 posi, HD cooling and it still wears its original aluminum drums out back. This car sat in MN. for the last 10 years and now I have it. I would like to think as far as options, this is the rarest Malibu I've ever seen for 78-83 cars. I could not belive my eyes when I seen it-why somebody could not see the rarity of it is beyond me. Its not an LS6 car, but for these years, it just like finding one. A guy asked me once what it would take to buy it and I didn't want to sell it but after some hounding from him, I said $8500 as-is. He thought I was crazy and maybe I am but you'll never find another one like this one. My first few NOS pieces I found for it are outer tail light housing bezels, GM power antenna assembly and a factory NOS digital stereo correct only for 1979 cars. This one will be a keeper for me-one day when the magazines want to find who has the rarest G-bodies (a technically), I'll roll this car out and freak some people out.
HARNESSWORX
#596904 - 08/16/08 05:45 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: gmachinz]
BADD87SS Offline
BADD87SS  Offline
belton, mo
I would verify the VIN, for the correct engine, and if it really is suppose to be a V8, then i would keep it.
07 Monte SS
#597127 - 08/17/08 03:34 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: BADD87SS]
ZZ430T56 Offline
ZZ430T56  Offline
Central Virginia
Ya I thought all the 4 speed Montes were V6.
....Bill
Bill Rossi
88 Monte SS
ZZ430 350/430hp
T56 6 speed
Ford 9"
WEBPAGE: Bill's 88SS
#597506 - 08/18/08 07:48 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: mmc427ss]
Downingtown, PA
Bob quit being nice I am not a LITTLE Bias, I am totally Bias towards 3rd gens. rofl5 Seriously I have not seen any 3rd gen sticks at all. BTY Bob building an 83 SC right now. Hope to have it out soon.
#597510 - 08/18/08 07:52 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: monteman1978]
Downingtown, PA
I say if the a-pillars are good keep it if not pull the the stuff and ditch the car.
#597513 - 08/18/08 08:07 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: monteman1978]
BADD87SS Offline
BADD87SS  Offline
belton, mo
Our old neighbors had one, that he bought new from the dealer and his was a manual with a 231. It was brown with tan colored interior. I would have bought if, if i knew what it was back then. I was like 16 when they sold it, but i didn't care for the V6..lol, so i never even gave it a thought...........
07 Monte SS
#603032 - 09/05/08 05:41 PM Re: 1978 Monte Carlo-factory 4-speed found [Re: monteman1978]
That's too bad, Sean. A guy I knew in college had one ... light blue color with (iirc) white and blue interior.
500/thumbs/monte214.jpg
by tovann
536/thumbs/IMG_0611.jpg
by ssmnt408
500/thumbs/P1030365.JPG
by Ole Blue
500/thumbs/my_81_SS_Monte_clone2.jpg
by Dave84
688/thumbs/l_619513f50c2a3391323ff09f4b35de59_2_.jpg
by Vondross
