Topic Options
#592468 - 07/31/08 12:25 PM no computer,need cheap way to lock up 200
csb41502 Offline
Loc: highland falls ny
im on a very tight budget and dont wanna buy a 100 dollar kit and dont wanna do any internal wiring in the 200.is there any way to just wire up a toggle switch or something to make it lock up?i just put in a 350 and got rid off the computer and all that crap.just need an easy and cheap solution to have fourth gear lockup.thanks
Top
#592497 - 07/31/08 02:08 PM Re: no computer,need cheap way to lock up 200 [Re: csb41502]
nycitis Offline
Loc: New Windsor, NY
a 200 doesn't have a lockup....200R4? Not trying to bust your chops just making sure you get the right answer!
_________________________
build it like you love it, drive it like you stole it..
Top
#592501 - 07/31/08 02:17 PM Re: no computer,need cheap way to lock up 200 [Re: nycitis]
csb41502 Offline
yes its a 200r4.stock trans.where do u live in new windsor?im about 15 min from the 5 corners
Top
#592503 - 07/31/08 02:25 PM Re: no computer,need cheap way to lock up 200 [Re: csb41502]
kubihibi Offline
Loc: Kingsland, GA
Do you still have the connector that was plugged into the trans when you had th ecomputer?
modern-day minuteman
Top
#592505 - 07/31/08 02:30 PM Re: no computer,need cheap way to lock up 200 [Re: kubihibi]
csb41502 Offline
yes i still have the connector for trans from the computer
Top
#592543 - 07/31/08 04:57 PM Re: no computer,need cheap way to lock up 200 [Re: csb41502]
nycitis Offline
I am by Butter hill estates down on 94.....about 5 minutes from the 5 corners....
Top
#592764 - 08/01/08 10:56 AM Re: no computer,need cheap way to lock up 200 [Re: nycitis]
jrz126 Offline
Loc: Erie PA
I wired mine to a toggle switch. It was fairly easy to do and very cheap too.
You need to know if your 4th gear pressure switch is normally open or closed. Use an ohm meter and measure the resistance between the green/white wire and ground. If it reads near 0 ohms then your switch is normally closed.
If your switch is normally closed, you will need to use a relay. I made a couple quick pictures to explain it.
The first picture is when the car is not in 4th gear. The coil of the relay is energized and the tan/blk wire is not connected to ground.
The next pic is when the car is in 4th gear. The 4th gear pressure switch is open, which deenergizes the coil. This connects the Tan/Blk wire to ground when the toggle switch is on.
Hope that helps.
Top
#592768 - 08/01/08 11:27 AM Re: no computer,need cheap way to lock up 200 [Re: jrz126]
csb41502 Offline
where do i find the tan/black wire and what kind of diode do i use?
Top
#592781 - 08/01/08 01:15 PM Re: no computer,need cheap way to lock up 200 [Re: csb41502]
jrz126 Offline
Loc: Erie PA
Just a regular power diode will be fine. Anything in the 1N4001-1N4007 range will be fine. The diode isnt necessary for it to work. It will just minimize the electrical noise whenever the relay turns on or off.
There should be a tan/black wire coming off the transmission along with a purple and green/white wire.
I put my relay where the Check Engine Light Driver module is. All the wires I needed were in that area. +12V, GND from the light module and the 3 wires for the transmission from the computer harness. I had just cut the computer harness right by the fender in the engine bay. I just had to reattach the 3 transmission wires there and then find them on the inside.
Edited by jrz126 (08/01/08 01:22 PM)
Top
#592802 - 08/01/08 03:37 PM Re: no computer,need cheap way to lock up 200 [Re: jrz126]
84supersport Offline
Loc: Louisville, KY
Would something like this work on a th350c? And, if you accidently leave it locked will the car just die or will it hurt the transmission?
355, Hooker 2451s, Flow 40s w/X-pipe dumped, Air Gap, Holley 670 SA, Pro-Stick, 3" FR springs, 275s out back. Long way to go.
Daily Duty retired and broken. Getting built th350 soon. '96 Cherokee Daily: 31s, cut fenders, 2" lift.
EMail: maxxa87(at)hotmail.com
AKA Matt
Top
#593012 - 08/02/08 06:18 PM Re: no computer,need cheap way to lock up 200 [Re: 84supersport]
2mcss Offline
Loc: fredericton. N.B. Canada
nice schematic by the way JRZ126 . 84 supersport if your transmission as only one wire and I think its green you need a positive feed as the solenoid is grounded inside the transmission so you need 12 volt to turn it on or (engage it).
305 still WebCam http://personal.nbnet.nb.ca/alaindes/webcam.html
Top
#593264 - 08/03/08 03:55 PM Re: no computer,need cheap way to lock up 200 [Re: 2mcss]
Loc: Louisville, KY
I'll have to find the plug and look. The harness is stashed away in a box somewhere.
AKA Matt
Top
#593998 - 08/06/08 03:09 AM Re: no computer,need cheap way to lock up 200 [Re: 84supersport]
The Cadillackid Offline
Loc: columbus, ohio
i find not all 200-4r have the 4th gear switch... mine just has the purple and tan/blk wires from the trans... and no position in the connector to add the wire.. just be aware of that..
christopher
1988 LS, 385,edelbrock performer RPM and holley SA 770 carb, Headers,Duals,flow 40's, Gforce X-member, 2004R, Kevlar clutches ,Sonnax Servo,3000 Stall,3.73 Posi,Vette Rallies, Eagle GT II's, Nordskog Digital Dash, Mark VIII Fan, Ice Cold A/C,!Rebuild in progress!
** New 475HP Stroker SBC up and running!! and fryin Tires! **
Top
#598612 - 08/21/08 10:23 PM Re: no computer,need cheap way to lock up 200 [Re: The Cadillackid]
Retro Offline
Loc: Macon,Ga.
Mostly just the GrandNats/TR's & TTA's had the 3rd pressure switch & 4th Pr. switch. All others just had 4th gear switch.
Top
500/thumbs/004.JPG
by SSPARKY
500/thumbs/rr3quhi.jpg
by toddztoyz
500/thumbs/DSC03034_1_.jpg
by Rodney
500/thumbs/PICT0216.jpg
by 84SSleeper
500/thumbs/Monte5.jpg
by Hamburgerler1987SS
MonteCarloSS.com Stickers
Order MonteCarloSS.com Stickers
Site Contributors
in the last Month:
amazine
71BLACKSS454
1A Auto Parts
BRP HotRods
GNS Performance
Mac-Ink Customs
MidNight Powder Coating
MV85SS Powder Coating
RetroLSX
SDCE
SMM Enterprises Inc.
