Page 29 of 29 1 2 27 28 29
#1054151 - 10/30/17 06:50 PM Re: LS series engine swap info for the 78-88 G-Body [Re: pukas]
Originally Posted by pukas
True, but I kind of don't like the way the truck manifold looks, kind of bulky.
Gen IV looks waaay better than the LS 6 in my opinion. but I am biased.
#1054153 - 10/30/17 07:16 PM Re: LS series engine swap info for the 78-88 G-Body [Re: BRPhotrods]
MC96 Offline
MC96  Offline
St. Johns MI
I see guys on facebook smoothing them out and prettying them up quite a bit.
I winder if there are aftermarket covers available?
86 SS
In progress
#1054157 - 10/30/17 09:14 PM Re: LS series engine swap info for the 78-88 G-Body [Re: BRPhotrods]
pukas Offline
pukas  Offline
honolulu, hawaii
thepezking639, that does look better than the Gen 3. where did you pick that up and how much, if you don't mind me asking. I have a LS6 manifold that I got on the side when I bought my 5.3L. Where did you get your radiator and fans from? Also where did you get your gas tank too? Thank you.
#1054167 - 10/31/17 01:25 PM Re: LS series engine swap info for the 78-88 G-Body [Re: pukas]
http://www.pro-touring.com/threads/126188-SSLOW6-0-Build
All the answers you seek are there. the Radiator is a Champion CC162, Fans are from a 97 Dodge Intrepid. I got the manifold off of craigslist, it was from a trailblazer SS for $150, but any 07 and up truck motor should have it. Mine has 30lb injectors, but some of the flex fuel cars had 60lb-ers.
#1055456 - 01/21/18 06:08 PM Re: LS series engine swap info for the 78-88 G-Body [Re: BRPhotrods]
Atl_Monte Offline
Atl_Monte  Offline
Atlanta, GA
About to start my LS7/4l80 swap 😫🙈
1988 Monte Carlo SS fully customizedm, cowl hood, Kandy paint w/ ghost flames, power sunroof, 24" rims 327 SB - SOLD
1986 Monte Carlo SS 350 create motor, cowl hood, shaved handles & trunk, power sun roof, digital dash
http://youtu.be/aKZI0FhUP6U
1984 H/O Cutlass lightning rods 8.5" rear LT1 and C5 brake conversion under way 24" rims
#1058193 - 07/10/18 03:46 PM Re: LS series engine swap info for the 78-88 G-Body [Re: BRPhotrods]
TheBurkey Offline
TheBurkey  Offline
Auburn, KS, USA
Getting everything together for my LS swap. Have a complete Lq4 that i am going to keep the truck intake on and a 4l80e. Going to get the conversion brackets to move the AC compressor up top also. Has anyone used the Hooker Blackheart setup?
Motor mounts: 12643HKR
X-member with bracket for 4l80e: 12644HKR
Full length headers: 2332HKR (not sure if I can justify the price yet on the headers)
They claim it will optimize clearance for LS swaps in the G-bodys. Anyone use this setup for an LQ4 and 4L80e combo?
#1059726 - 11/06/18 02:54 PM Re: LS series engine swap info for the 78-88 G-Body [Re: BRPhotrods]
2085Monte Offline
2085Monte  Offline
Louisville,Ky
Where is a good place to find a 6.0 with transmission?
#1061513 - 04/15/19 07:01 PM Re: LS series engine swap info for the 78-88 G-Body [Re: BRPhotrods]
2085Monte Offline
2085Monte  Offline
Louisville,Ky
Just found a local that will swap me for $3300 including 6.0 LQ4 engine. Taking it to him this weekend
#1062042 - 05/27/19 12:25 AM Re: LS series engine swap info for the 78-88 G-Body [Re: Atl_Monte]
jmireles Offline
jmireles  Offline
El Paso, Tx
That'd be the ideal engine time swap in. I have an '06 GTO LS 2 swapped in my Monte, which is no slouch but it isn't an LS7.
in '08. 3K
#1064214 - 11/21/19 02:57 PM Re: LS series engine swap info for the 78-88 G-Body [Re: benen]
84ss355*4spd Offline
Edmonton,AB,Canada
LT1 SWAP .COM do some reading .lots of info with pictures.i just depinned a harness with the steps provided very easy to do .i knew nothing and in a week of reading i know now .not hard at all.u dont even have to depin if u dont want .u can even use the truck fuse block and its only a couple wire hook up
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
500/thumbs/monte_after_recovered_1.jpg
by clyde
500/thumbs/side2.JPG
by Ted88SS
854/thumbs/100_7996.JPG
by FuzzyDnkn
500/thumbs/87powerwindowcomponetlocation_1000x727_.jpg
by ls1_monte
500/thumbs/eddyville_06_2.jpg
by montess406
