Page 27 of 29 1 2 25 26 27 28 29
#1018615 - 01/19/15 01:59 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Tunedss86 Online content
Tunedss86  Online Content
Eastern Virginia
Spectra makes a kit that has a bunch of grommets & inserts to allow you to drill a hole (comes with a xxxx drill bit too) into plastic or aluminum tube to add for the vent tube. You want to put the port behind the MAF so it reads that air, the port on drivers side valve cover is regulated to only allow a certain amount of vacuum. Other LS engines have a port on the valley cover too, mine didnt.
#1018630 - 01/19/15 07:24 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Thanks for the info Scot.
#1020249 - 02/26/15 04:59 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
awssum Offline
awssum  Offline
gulfport, ms
Looking at buying some spark plug wires for my LQ4 for my 87 Monte Carlo SS. I have Hedman's longtube headers and was wondering what MSD part number to buy?
#1020258 - 02/26/15 09:26 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
32829 for red
32823 for black
You just buy ones for a Silverado, those are the MSD part numbers.
2015 GMC Sierra Denali
#1027469 - 07/27/15 10:09 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
s10mike Offline
s10mike  Offline
herminie, pa
is anyone using the factory ls1 fuel rail cover in there ls1 swap? I'm not using them right now, but I'm thinking that they will really spruce up the engine compartment. but it looks like the passenger side fuel rail cover will need some trimming to clear the AC box
86 monte carlo ss
6.0 ls/4l80e dana 60
#1028979 - 09/06/15 08:53 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
305hoSS Offline
305hoSS  Offline
Millstone, NJ
Will LS2/LS3 corvette Exhaust manifolds fit a g-body?
87 ss- Almost sold my SS then changed my mind...Now working on an LS swap
#1028982 - 09/06/15 09:46 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Montague Offline
Montague  Offline
Fond Du Lac, WI
305hoSS, not sure on LS2/3 but the Y body LS1 manifolds definitely will not clear. They hit the clam shells. read my thread. It tells you exactly what ended up fitting, what hit and what the clearance was. Same with the oil pans.
86 SS LSX/4l60E
I wonder IF I'll ever get to finish the dang blasted hot sides?
#1029801 - 09/22/15 01:10 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
305hoSS Offline
305hoSS  Offline
Millstone, NJ
I wonder if any of the gen5 camaro ss manifolds would fit?
#1029826 - 09/23/15 12:22 AM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Montague Offline
Montague  Offline
Fond Du Lac, WI
The truck manifolds fit with modification. The F body longtubes fit with clearancing on the #2 primary unless you have aftermarket upper control arms. If you have aftermarket UCA's then no clearance required.
86 SS LSX/4l60E
#1029831 - 09/23/15 01:28 AM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
305hoSS Offline
305hoSS  Offline
Millstone, NJ
I'm sorry I was referring to the gen5 camaro stock exhaust manifolds not any headers. Im only asking because I can get a good deal on a pair. also, I think they look better than the ls1 f-body manifolds.
#1029840 - 09/23/15 11:53 AM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
It will likely all depend on your mounts. I was able to use stock LS1 manifolds just fine, but I'm using custom plates and different chassis mount location than most guys. If you can borrow some to try out, that might be the only way to say for sure if they would work on your car.
#1030981 - 10/20/15 04:16 AM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
jmireles Offline
jmireles  Offline
El Paso, Tx
I'd like to make sure I have the vacuum hose routings/connections correct on my LS2 swap:
1. Can I route the Charcoal canister to the plastic line that connects to the driver's side of the throttle body?
2. There is a plastic line on the passenger side valve cover. I think that goes to the stock intake elbow, correct?
3. Can I "T" the vacuum line from behind the intake manifold for the vacuum ball and then to the clear or grey color plastic line that runs under the evaporator?
4. Does the purple plastic vacuum line that again, comes from under the evaporator connect to the heater valve?
in '08. 3K
#1030988 - 10/20/15 01:37 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
spacemanspif Offline
Sewell, NJ
One of those lines near the throttle body is not under vacuum, its the fresh air side of the PCV system but I'm not sure what one is which on the LS2 intake.
1. Not sure about running vacuum to the charcoal canister without some sort of valve. Stock set up used some kind of thermal valve that only sucked up fumes when the engine was warmed up, connecting the charcoal canister direct to vacuum could try to collapse the gas tank. I left my tank hooked to the charcoal canister and didn't connect anything to the engine side.
2. Pretty sure, on my truck intake it goes right to the port by the throttle body (as mentioned in my the first paragraph)
3. If you want to possibly loose vacuum for your booster due to broken vinyl tubing down the road.
4. Not sure, can't check my car while at work for color confirmation.
-Mike
Killed a few cones too
#1031011 - 10/20/15 06:29 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
jmireles Offline
jmireles  Offline
El Paso, Tx
There is another vacuum line behind the manifold that isn't for the brake booster. Can I use that for the vacuum ball and HVAC line?
in '08. 3K
#1031014 - 10/20/15 07:25 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: jmireles]
Eastern Virginia
That's what I used them for on mine.
#1031031 - 10/20/15 11:46 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
jmireles Offline
jmireles  Offline
El Paso, Tx
Cool, that's what I'll use.
Scott, are you using your charcoal canister?
in '08. 3K
#1031037 - 10/21/15 01:31 AM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Montague Offline
Montague  Offline
Fond Du Lac, WI
JMireles, when are you going to finish that swap? If you ditch the factory charcoal canister and use one from a truck or camaro off the tank vent it works perfectly.
86 SS LSX/4l60E
#1031038 - 10/21/15 01:34 AM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Montague Offline
Montague  Offline
Fond Du Lac, WI
Gotta wait till I get home for body work/turbos amd AWD. Sometimes zi hate being on the road for work. Btw if any of you ls guys are interested I should have the design done for the turbo kit by spring.
86 SS LSX/4l60E
#1031041 - 10/21/15 02:40 AM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
jmireles Offline
jmireles  Offline
El Paso, Tx
Well Montague, I hope to have it running before the end of the month. There are still a few loose ends to tie up before I can fire it up. I'm really close though. I'm waiting on a pigtail from Jabin.
in '08. 3K
#1035885 - 03/04/16 07:29 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
s10mike Offline
s10mike  Offline
herminie, pa
Hi, I'm currently using fbody pacesetter longtube headers in my car. They fit ok, but I was thinking about stepping up to a 1 7/8 primary tube headers. I was looking at the holley(hooker) gbody ls1 swap headers and I'm trying to figure out if they will work. They are designed around holleys engine mounts, which are 3/4 setback. Whereas I'm using 1" set back mounts. Has anyone used these headers with 1" setback engine mounts?
86 monte carlo ss
#1035892 - 03/04/16 08:34 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Sewell, NJ
Friend used their whole kit and the header fitment is top notch but you'll need to get the car way in the air to get them in from under the car. I don't remember any tight looking spots, but for the fitment they may be worth trying.
-Mike
#1035895 - 03/04/16 10:27 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: spacemanspif]
s10mike Offline
s10mike  Offline
herminie, pa
I found a thread on ls1tech where a guy test fit the hooker 1 7/8 headers along with 1" setback plates. And they fit like a glove.
Here is the link, enjoy!
http://ls1tech.com/forums/conversions-hy...ons-thread.html
86 monte carlo ss
#1035896 - 03/04/16 10:52 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: spacemanspif]
s10mike Offline
s10mike  Offline
herminie, pa
Was your friend able to install them from underneath with the ac box in place?
86 monte carlo ss
#1035897 - 03/04/16 10:54 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: BRPhotrods]
Sewell, NJ
Good to know thanks for sharing. I will say that my friends were some of the first ones off the line and after some run time one of the primary tubes split at the seam. Hooker sent him a new set and he sent them back with no questions asked. I assume if there was a problem with the material or process they have the necessary adjustments to make sure it doesn't happen again.
-Mike
#1036043 - 03/07/16 11:45 PM Re: STICKY: LS series engine swap - 78-88 G-Body [Re: s10mike]
Full Hooker swap thread here..
http://ls1tech.com/forums/conversions-hybrids/1733542-new-hooker-g-body-ls-swap-system-preview.html
500/thumbs/1122091338a.jpg
by 85lolo
500/thumbs/143.JPG
by CashMoneyMotorsports
500/thumbs/Z65_Paul-7.jpg
500/thumbs/IMG_1565.JPG
by T-Top Tony
728/thumbs/rearendside1.JPG
by THEmean1
