#563109 - 05/01/08 01:03 AM craig weld dragstars VS weld prostars in Summit
monte87LSsssssssss Offline
Marlton ,NJ
in my summit mag theres these rims that look exactly like prostars but they just switched the name up a bit, there about $100 each compared to $160 each, and they look good in the pics, but does anybody know if there made from exactly the same material and if there just as light
1987 MonteCarlo LS---345HP/370torque GM ZZZ crate motor---Holley 670cfm Street avenger---Mallory HEI---TH350/shift kit/2300 stall converter---GN 8.5" rear 342 gears---2" drop spindles with 1" springs up front, Moroso drag springs in back---275/60r15 Mickey Thompson drag radials---reduced weight to about 3000 pounds even
#563287 - 05/01/08 02:52 PM Re: craig weld dragstars VS weld prostars in Summit [Re: monte87LSsssssssss]
1984Monte Offline
1984Monte  Offline
Austin, Texas
There is a reason why they are cheaper... Im sure they use different material and are alot heavier.
#563309 - 05/01/08 04:24 PM Re: craig weld dragstars VS weld prostars in Summit [Re: 1984Monte]
Gruvin Offline
Gruvin  Offline
Texas
I have a set of cragar aluminum rims that look like Weld pro stars and they are really light... these may be the same. I know the street stars are steel and heavy.
#563315 - 05/01/08 04:45 PM Re: craig weld dragstars VS weld prostars in Summit [Re: Gruvin]
white88ss Offline
white88ss  Offline
long island, new york
If they are legit Greg Weld Prostars, they should be close to the same weight as the normal Weld Prostars..
From LS1TECH from Greg Weld himself..
FACTS
1. Greg Weld sold Weld Racing to American Racing In October of 2006
2. Greg Weld Wheels is a new company with new products that competes directly with American Racing and Weld Racing
3. Neither Greg Weld or myself signed or are under any kind of non compete with American Racing
4. We are not currently doing business with Forgitron.
5. The Greg Weld facility is located in Kansas City, MO
6. We Are working with ALCOA on some of our forged products.
7. The Dragstar name is a trademark of Greg Weld
8. Greg Weld designed the Weld Racing Prostar and Draglite in 1982. The new Greg Weld Dragstar and Prolite are completely re-engineered and improved variations of his original Prostar and Draglite wheels.
9. The new Dragstar and Prolite are LIGHTER and STRONGER than the original designs
10. No spacers are utilized in the new designs
11. YES these wheels were engineered to fit the 4th generation cars
12. YES stock studs will work
13. Yes the wheels will clear the calipers with NO grinding necessary.
14. Greg Weld Wheels are NHRA and IHRA legal
Run what you brung, and hope what you brung is enough...
#563316 - 05/01/08 04:45 PM Re: craig weld dragstars VS weld prostars in Summit [Re: white88ss]
white88ss Offline
white88ss  Offline
somehow I forgot this one
15x3.5=10.5 lbs
15x5=11.5lbs
15x7=12.0lbs
15x8=13.0lbs
15x10=14.5lbs
15x12=16.0lbs
15x14=17.5lbs
17x4.5=17.0lbs
17x7=18.5lbs
17x8=20.0lbs
17x9.5=21.5lbs
20x8=22.5lbs
20x9=24.0lbs
20x10=25.5lbs
500/thumbs/monte58.jpg
by juan r
by BOHNZ
500/thumbs/Full_Motor.jpg
by 468beast
by Big Reazon
by TestMySS87
Rob Forbes
