Topic Options
#555261 - 04/09/08 06:42 PM A/C Blowing Out of the Defrost?
rmodys Offline
Loc: Ft. Myers, Florida
I recently charged my A/C (R134 retrofitted, all new parts) and noticed that sometimes my A/C either only blows from the defrost and floor vents (on both A/C settings) or it blows through the defrost, floor, and dash vents. I checked all of the vacuum lines and verified their correctness using a 1986 Service Manual so I know that's not the problem.
Does anyone have any idea what could be wrong?
_________________________
1986 Monte Carlo SS. Family owned 1987-1999; 2004-present, rust-free Florida car, L69 with TPI, B&M shift kit, 3.73 posi, new PUI interior, t-tops, lowered 2", refinished stock rims, Goodmark cowl hood, and amber DRL's.
Top
#555268 - 04/09/08 06:58 PM Re: A/C Blowing Out of the Defrost? [Re: rmodys]
baaboo Offline
Loc: Racine, WI
Do you have good vacuum at the diverter valve behind the dash?
Top
#555285 - 04/09/08 07:19 PM Re: A/C Blowing Out of the Defrost? [Re: ]
redlineSS Offline
Loc: South Jersey
Diverter DOOR is probably stuck, check that out!
Dave
~Dave~
Top
#555306 - 04/09/08 08:01 PM Re: A/C Blowing Out of the Defrost? [Re: redlineSS]
rmodys Offline
Okay so I jiggled the arm on the HVAC control panel and it started blowing out of the vents instead of the defrost.
Is it supposed to also blow out of the bottom? Or is that a fluke?
Top
#555435 - 04/10/08 05:53 AM Re: A/C Blowing Out of the Defrost? [Re: redlineSS]
84LS1T56SS Offline
Loc: Central, Arkansas
Dave
This is probably the place to start. You can see the vacuum can that operates the door in the pic. It's ALMOST impossible to change without removing the dash.
85 MCSS, 02 5.3/4L60E stock daily driver, (given to daughter-in-law)
84 MCSS, LS3 418, 248/254, 615/595, XER and XE lobes, AFR 225's, 1 7/8 BRP headers, 9" ford, 350 gears, 200-4R tranny.
Top
#555449 - 04/10/08 07:38 AM Re: A/C Blowing Out of the Defrost? [Re: 84LS1T56SS]
redlineSS Offline
Loc: South Jersey
There is also a vacuum manifold behind the heater control panel that may need some attention. Sometimes the head works loose from the nozzles, push it back on, and look for broken hoses.
Dave
~Dave~
Top
#555456 - 04/10/08 07:54 AM Re: A/C Blowing Out of the Defrost? [Re: redlineSS]
bug Offline
Loc: winchester, TN
don't mean to thread jack, but I also have a simuler problem. Mine is not with the A/C but with the heater. It blows hot air out the floor vents all the time, even when the blower is not on. My father said there is a plastic arm on the blower door that might have broke. Could mine be the same problem as the one above?
86 monte ss currently body off resto.
http://s1013.photobucket.com/albums/af260/wclintprince/monte%20carlo%20ss/
Top
#555473 - 04/10/08 09:04 AM Re: A/C Blowing Out of the Defrost? [Re: bug]
redlineSS Offline
Loc: South Jersey
Clint (bug), your heater hose control valve may be shot. It is the vacuum operated valve under the hood on the heater hose line. alot of the thin plastic lines get broken from age and may not be shutting off the water flow to the heater core??
Dave
~Dave~
Top
#555504 - 04/10/08 10:56 AM Re: A/C Blowing Out of the Defrost? [Re: rmodys]
jaywos Offline
Loc: New Jersey
This might be silly, there is the little vent below the steering column. I believe a hose connects to this vent. Mine was not connected and would always get cold air to my feet. re attached and now it blows out of the vent. The hose is in the nest of wiring i think.
1987 SS
Top
#555518 - 04/10/08 12:12 PM Re: A/C Blowing Out of the Defrost? [Re: jaywos]
The Cadillackid Offline
Loc: columbus, ohio
the HVAC control panel itself might be bad... the biggest thing that selector arm does is open and close vacuum ports as you slide it.. if the "vacuum valve" is loose it will allow vacuum to go places it shouldnt resulting in erratic operation...
also there is a round "connector" omn the back of the HVAC control that often pops loose creating vacuum leaks.. esp if you have worked beind it - ie putting in a radio etc..
-Christopher
1988 LS, 385,edelbrock performer RPM and holley SA 770 carb, Headers,Duals,flow 40's, Gforce X-member, 2004R, Kevlar clutches ,Sonnax Servo,3000 Stall,3.73 Posi,Vette Rallies, Eagle GT II's, Nordskog Digital Dash, Mark VIII Fan, Ice Cold A/C,!Rebuild in progress!
** New 475HP Stroker SBC up and running!! and fryin Tires! **
Top
#555649 - 04/10/08 06:06 PM Re: A/C Blowing Out of the Defrost? [Re: jaywos]
rmodys Offline
Nahh, it's coming out through the center and on both sides. I might have to check out the connections on the HVAC control panel. Thanks guys
Top
#555773 - 04/10/08 09:24 PM Re: A/C Blowing Out of the Defrost? [Re: redlineSS]
86ttop Online   grandpa
Loc: Colonial Beach, Va
Dave
Just an FYI, the heater valve only shuts off flow in the MAX A/C position.
You have a broken/misadjusted arm like your Dad said. Take everything out of the glove compartment and take the screw out of the retainer cable and let if fall all the way down. Look in the opening and operate your temp cable and watch to see if it operates the arm and the rod for the blend door. Good luck with your repair.
Top
#555945 - 04/11/08 12:41 PM Re: A/C Blowing Out of the Defrost? [Re: 86ttop]
DLV555 Offline
Loc: Rochester, NY USA
I've had this problem with my A/C since I bought the car in Jan. '07. All of my vac line are good and I have manually supplied vacuum to the individual motors and they work, so in my case it looks like my A/C control head has taken a dump. Hopefully I'll get that fixed this year before it get too hot...and then maybe also tackle the A/C leaks that I have too! If all of your vac motors work when you supply vacuum, and all of your vacuum lines hold a vacuum then I would suspect the control head.
Former Member SMCC
1992 Pontiac Firebird TBI 305, shorty headers, 3" exhaust, Flowmaster 80, boxed SFCs and LCAs
1973 Mercury Montego MX 351C
1987 Monte Carlo SS, 400SBC, Edelbrock Intake, mild Lunati Voodoo cam, Flowtech LT headers, 2.5" true dual exhaust, Delta-Flow 40s
1987 Monte Carlo SS(RIP 11/17/2001)
Top
#558432 - 04/17/08 09:00 PM Re: A/C Blowing Out of the Defrost? [Re: DLV555]
Don85SS Offline
Loc: chicago, il
Does anyone know what color cables control what?
I have had this problem in the past and it usually works after switching between vent/heater/defrost. But recently my car was broken into and the stereo stolen now this "little trick " is not working so maybe one of the hoses is damaged.
Any tips on troubleshooting is appreciated.
Top
568/thumbs/nuseat.jpg
by battz89
995/thumbs/82.jpg
by knight77
500/thumbs/Monte_47.jpg
by TAZ67
500/thumbs/NYMCC_Cruise.jpg
by RocknSS
989/thumbs/my_monte_51_80x80.jpg
by 85montanezcarloss
Site Contributors
in the last Month:
ronnie84ss
BADD87SS
Monte_ExpreSS
Steve Lane
notsocleverusername
jwc55
MonteCarloSS.com Stickers
Order
Stickers
