#551150 - 03/30/08 08:08 AM
Benifits of a carb spacer?
Loc: Summersville, West Virginia
What are the pros and cons of running a carb spacer? I have read that they help with top end performance, but do they take away from the low end? Im thinking of trying one out but want to read some input first.
_________________________
85 Silver SS, T-Tops, 335 Stroker, Eddy 4bbl, Holley Street Dominator intake, mild cam, W/ Vortecs, headers, and posi rear ASAP GREAT! Gift from my Dad The Car-/- The Motor
Top
#551160 - 03/30/08 08:36 AM
Re: Benifits of a carb spacer?
[Re: Monte_ExpreSS]
Loc: Jacksonville, Fl.
x2 4 hole for the street and open for top end hp.
 1984 SS, w/87 Grand National 2004R, 355 vortec, CCC, Crane XE262, true 2 1/2 duals w/h pipe & hooker aero chamber muflers 1969 Road Runner 2003 GMC Serria 1998 Pontiac GTP Supercharged
Top
#551167 - 03/30/08 09:20 AM
[Re: cj84ss]
Loc: West Warwick, RI
It makes the intake maniold think its bigger than it really is...some engines like them, some see no gains, or a loss of performance. Every engine is different, a dyno is the only way to see for sure how your engine reacts.
Top
#551171 - 03/30/08 09:23 AM
[Re: cj84ss]
Loc: Chesterton, IN
There is a spacer that starts out as a 4 hole & tapers into an open spacer. In every case we have used one on an engine on our dyno it has helped all around power w/o hurting torque or HP. Below is an example of the spacers Wilson makes, they are also made by other companies. http://www.wilsonmanifolds.com/shop/index.php?l=product_images&p=9 I have one of these on my engine.
 1987 Monte Carlo SS Aerocoupe "Pro Touring", 436ci All Alum. SBC, 18° Aluminum Heads, 700R4, 3000stall, Ford 9 inch, 3.90 gears, 620 H.P., 590 FT LBS Torque. E.T. 11.229 @ 123.62 on motor. 10.213 @ 137.58 NOS (10/02/2010)! www.protouraero.com
Top
#551172 - 03/30/08 09:23 AM
[Re: cj84ss]
Can I run a 4 hole spacer with my open intake?
Top
#551192 - 03/30/08 10:31 AM
[Re: Silver85]
Loc: Beaverton, Oregon
sure, the carb has 4 holes so your just just making the carb flange thicker by using a 4-hole spacer.. A tapered 4-hole spacer can provide the best of both worlds performer rpm intakes require a special unit that has a window machined into it designed to enhance cross-flow across the divider. Here is my HVH tapered 4-hole with a window..    and the matching intake manifold  On my engine combination the spacer can add up to 40hp..
George Monte, Gone but not forgotten The More I Learn About Dogs The Less I Like About People
Top
#551224 - 03/30/08 11:34 AM
[Re: jigsaw]
open, 4-hole, tapered 4-hole, they come in varying thickness..
Top
#551406 - 03/30/08 09:05 PM
[Re: MY FYN 79]
all i can tell you is i used one on "the other project" and it made a world of difference.. Never compared with a standard open or 4-hole unit so don't know if it's better, but it works for me.. It's not required for the manifold but it does compliment the existing setup.. Roughly $135 online..
Top
#551412 - 03/30/08 09:10 PM
[Re: MY FYN 79]
Loc: Dharma station 1 the Hydra
You may also want to think about phenolic spacers that help keep the carb cooler.
Edited by Buick Runner (03/30/08 09:10 PM)
>: 4 8 15 16 23 42 execute = 108 Station 1 of 7, the Hydra. SBC powered 1987 Regal with TES, ZZ4 intake, mini starter, THM2004R, 2500 stall converter, and 2040 cam with CCC system.
Top
#551475 - 03/30/08 11:36 PM
[Re: Buick Runner]
Absolutely, phenolic spacers can add performance by keeping the carburetor cooler, use a fuel cooler to maximize the benefits of a dense mixture...combine all these techniques and you maximise HP with the chosen selection of parts..
Top
#552092 - 04/01/08 05:03 PM
[Re: SS402]
Loc: Greenville, SC
is there a specific application one for holley street avenger carbs? all i'm seeing is the 4150 and 4500 series.
or can i just use one of those?
86 Monte Carlo SS - Computer Delete, Holley 670 Street Avenger, Flowmaster Exhaust
Top
#552109 - 04/01/08 05:52 PM
[Re: TigerSpeed]
the street avenger is a 4150.. what manifold do you have..?
Top
#552296 - 04/02/08 01:32 AM
[Re: SS402]
Loc: Greenville, SC
don't know yet. haven't decided between Holley street dominator, Edelbrock performer,
Top
#552521 - 04/02/08 07:00 PM
[Re: TigerSpeed]
both of those are low-rise dual-plane intakes, that motor won't turn enough rpm to benefit from a spacer..
if you were serious about makin power i'd recommend a 4-hole tapered, but not with those manifolds..
Top
#552530 - 04/02/08 07:28 PM
[Re: SS402]
Loc: Right by the Rocky Mountains
On my engine combination the spacer can add up to 40hp.. Wow,  I have always thought that those carb spacers were just one of those "rip off" products that didn't actually do anything. Guess I was wrong. How many inches tall of one should I get for my Holley 770CFM Street Avenger carb and Holley Street Dominator intake? Thanks, Jason
1985 Monte Carlo SS/w 350SBC - SOLD
Top
#552577 - 04/02/08 09:35 PM
[Re: Gamester]
It depends on the appication...
I was afraid this would happen, just because i run a spacer on my engine some of you might think your engine needs one too. This is not the case unless your building or have a serious street engine, spacers are designed to add power on top. the rpm where valve overlap is minimized, air-flow is maximized and the engine really starts to pull like a freight train on steroids.. This is when the tapered spacer really starts to shine by correcting and shaping the air-flow into the plenum..
If ya gotta high-rise and 270 debgrees of advertised duration ur probably a good candidate for the unit. Otherwise ur most likely wasting ur time n money..
That's the way i see it dawg..
Edited by SS402 (04/02/08 09:39 PM)
Top
#552594 - 04/02/08 10:13 PM
[Re: SS402]
Hmm, well I don't have a high rise intake, but my advertised duration on my soon to be installed Comp cam is 268/280. Do you think I would be fine without a spacer, or would I benefit from one? Here is some interesting results about spacers on a smaller engine than mine. Yea, it is a Ford, but interesting results none the less... http://www.fordmuscle.com/forums/tech-exchange/465957-carb-spacers-dyno-test-1964-falcon-302-a.htmlThanks, Jason
Edited by Gamester (04/02/08 10:32 PM)
Top
#552720 - 04/03/08 10:53 AM
[Re: Gamester]
i'd recommend switching to a high-rise dual-plane...then check out a spacer if ya like what the new manifold does to the powerband....glad to see you researched a little and found out that i'm not just passin gas...lol 15-40hp depending on application
George
Edited by SS402 (04/03/08 10:54 AM)
Top
#552754 - 04/03/08 12:23 PM
[Re: SS402]
Loc: Greenville, SC
So if i have the holley 670 and edelbrock performer, I would probably benefit most if i just got a 4 hole spacer up to an inch, maybe less? It would also be a benefit just for the fact of the heat transfer, right?
It's a street/strip car mostly street. Is it really even worth the spacer in my application?
Top
#552804 - 04/03/08 02:56 PM
[Re: TigerSpeed]
It would also be a benefit just for the fact of the heat transfer, right? that would be your biggest advantage, .25" or .5" phenolic..
Top
#552859 - 04/03/08 06:21 PM
With a Q-Jet............
[Re: Silver85]
Loc: Richmond, VA
Would a 4-hole benifit me at all on my stock chevy intake (I will put it on my edelbrock later)?
Jess
BKINBLK
Top
Moderator: 85_SS, Dalt10, Gruvin84SS, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, TPI Monte SS
by gashousemonte
by 350MCSS
by stonecoldtim
by
by PB86SS/87LS
Site Contributors
in the last Month:
ronnie84ss
BADD87SS
Monte_ExpreSS
Steve Lane
notsocleverusername
jwc55
