Suspended
Suspended
Good find - I'll report this to be added to the tech section \:\)
Good find
*SOLD*87 Aero Coupe,White/Burgundy,T-Tops,383,200R4, 3.73 Posi,18 & 20 inch IROC's,JVC & Rockford Fosgate award winning sound system. Car went 13.423 @ 103.15 mph @ 3000'. Super Chevy Show Street Class (Winner) Pomona 2002/2006/2007/2008 & Street Class (First Runner-up) Pomona 2003 & 2005. Monte Carlo Best of Show Winner, Pomona 2006 *SOLD*
B
B
Scweeeeeeeeeeeeeet! I put it on my desktop!
ss4ever Offline OP
Thanks for finding this link!
That is a pretty cool sight.
Is it just me, or does that site calculate backspacing wrong?
I put in an 8" wide rim with 0mm offset. That should make for 4" of backspacing, and its giving me 4.5" The way the dimension is drawn even looks like half of the wheel width.
Suspended
Suspended
remember its giving you the backspacing to the rim EDGE ,not the tire monting edge ,its 8inches to the INSIDE of the lips,on most wheels a 8 inch wide wheel is 8inches to the inside and 9 inches total with on the OUTSIDE of the edges.
that'd be it. They estimate the width of the wheel lip at a half inch it looks like.
Also a handy tool when changing tire sizes or gear ratios, this is for changing the speedo gears to keep your speedometer correct.
http://www.tciauto.com/Products/TechInfo/speedo_gears.asp
87 Monte,TPI conversion eng/trans from an 89 IROC had a paxton on it, its for sale! LS1 brakes and 9" rear finished, 3.56 with a locker to be tested. Been sitting since I graduated in 04 on the verge of resurrection. http://www.cardomain.com/ride/3192829
I would go with a 15 x 8 rim with 4" BS. 275/50r15 tire and you should have no probs.
A 275/60r15 is too tall and your gear ratio and speedpo will be off.
...Bo;;
Bill Rossi
88 Monte SS
ZZ430 350/430hp
T56 6 speed
Ford 9"
WEBPAGE: Bill's 88SS
I like that one. The one I have been using is at, 1010tires
1987 Monte Carlo SS Aerocoupe
[Linked Image from i1123.photobucket.com]
Nice! I just spent some time checking out all the rims and tires. Pretty cool! Thanks
1984 Monte Carlo SS - "010" 4bolt 350, GN 8.5, 700R4, 3.42
Here's another good wheel/fitment Info site.
http://members.cox.net/completevalue/wheelpat.html
C
C
nice site
U
U
Nice find. That is the best one I have used yet.
Gary
Nice finds, I haven't seen any of those before.
One I like to use is a real simple one:
http://www.miata.net/garage/tirecalc.html
1986 Monte Carlo SS SOLD
2009 Trailblazer SS 2WD - Silver
8
I'm thinking about having some (Stockton) ralley wheels built for my SS 17x8 4.5 & 17x9.5 5 backspacing. Will be able to run them year-round........ Please help with feed back.
B
B
i have a 197 monte carlo ss with a 1972 chevy 350 im stumped on trying to hook my ac bracket to the car would I need a bracket for that year chevy or can I use the a/c bracket for the year car that went on the original 305 please help
Have you seen this one on tires?
W
W
5 inch bs in the (stock) rear is pushing it without modifications or at least spacers.
I run 19X9.5 on the rear lowered 3" without spacers. I just had to massage the inner sheet metal just above the frame a hair. If you have the rear centered (sometimes requires adjustable uppers because of the tolerances), it works.
2 members (88ssBrent, 86eses), 62 guests, and 13 robots.
16,053 Registered Users
