#468852 - 08/09/07 06:30 PM
Re: fi fuel tank sending unit
[Re: steve 1961]
TPI Monte SS
Moderator 15+ Year
Moderator 15+ Year
North Jersey
You will probably have to go to the source; AC Delco. Try to find a Delco dealer in your area as they should have the correct fitting on the end.
#468859 - 08/09/07 07:27 PM
[Re: tonys57chevy]
tri5ss
Lebanon,Missouri
The last 4.3 sender that I bought from a A\C-Delco supplier 3 years ago had a slip on for the 3\8. I just got some AN fittings and made it a thresd on.
Cars Ain't Art! They Are Meant To Be Driven!
#468907 - 08/09/07 10:20 PM
[Re: SS Ninja]
m0ntecarloss
Windsor, NY
I bought mine from RockAuto and it had the threaded fitting. Unfortunately I don't remember what I chose for year, I will see if I have the part number when I get home.
86 SS - 1 billion horsepower vortec 355/WC T5/Megasquirt
#468912 - 08/09/07 10:28 PM
[Re: m0ntecarloss]
m0ntecarloss
Windsor, NY
Actually if you go to http://www.rockauto.com and look up part number: 25004938 The pic they have shows the threaded fitting. I'm not saying this is what I purchased for sure but it has the right pic at least : ) To find it I looked up the sending unit for an 86 4.3L Monte Carlo. I believe 87/88 monte carlo's had a different sending unit, maybe thats the problem.
#468957 - 08/10/07 12:05 AM
[Re: Tunedss86]
tonys57chevy
Rockauto has the same one i have pulled out of every 4.3 car i ever partedout
Pres. Wicked Rides car club,member of NJMCC,NYMCC 1983 Monte Carlo Convertible white, 1983 Monte Convertible red 1983 Monte Convertible white, 1983 monte convertible white 1957 Chevy 85 SS, 86 SS 8,272 miles www.wickedmontes.com www.wickedridesnj.com
by GearHeadDrew
by BaerMonteSS83
by troublesnc
by kpetry
by PoorBoysRacing
