Page 2 of 2 1 2
#427456 - 04/06/07 04:35 PM Re: MSD Ignition setup pictures [Re: dns87ss]
Black Rocket Offline
MN
thanks for the pictures everyone. i mounted mine exactly where crusher and Bri86SS mounted their's on the drivers side fender. keep the pictures coming, im curious to see other custom set-ups.
Bigthreefan: do you have any pictures of the way the 6AL is mounted where the factory computer is?
#427870 - 04/07/07 10:33 PM Re: MSD Ignition setup pictures [Re: Black Rocket]
1984Monte Offline
1984Monte  Offline
Austin, Texas
I like to place all my electronics inside the car where Heat and Water can't reach them. The passenger kick panel is a perfect spot to put an igntion box. The glove box is another good place to put other small electronic boxes (two-step, window switch, ect) in case you don't have the new digital box.
#429055 - 04/11/07 02:16 AM Re: MSD Ignition setup pictures [Re: 1984Monte]
Pyroguy Offline
Pyroguy  Offline
Houston, TX
Guys,
Great looking installs! However, a word of caution.
Awhile back I was using a Mallory ignition box which was mounted on the driver's side fender in the vertical position (like several have done in a couple of previous posts). One evening it rained and water ended up seeping into the box and caused the main internal capacitor to short out.
I have since installed a MSD 6AL unit but I mounted in on the driver's side inner fender well with the top pointing upwards instead of mounting it on it side against the metal fender. I have not had a single problem.
Please keep in mind that, for some unknown reason, neither Mallory nor MSD thought it prudent to completely seal off the bottom plate of their ignition boxes. Therefore, in order to minimize the possibility of a wet failure they should always be mounted with their labels pointing upwards.
(Just my $0.02)
- Jesse
#431175 - 04/16/07 05:19 PM Re: MSD Ignition setup pictures [Re: Pyroguy]
Monte88 Offline
Monte88  Offline
Johnston, RI
I put my Mallory Box in the driver's footwell mounted to the back of my A/C block-off plate.
'88 SS. Twin Turbo 374ci 600rwhp with only 6psi!
'77 Camaro 406/5spd
'46 Chevy Truck Hodrod
www.sd-concepts.com
#1067854 - 09/05/20 08:06 PM Re: MSD Ignition setup pictures [Re: Black Rocket]
markg Online content
markg  Online Content
nj
where did everyone get the hot wire to tie into?was there somethging under the hood?
#1067858 - 09/06/20 01:07 AM Re: MSD Ignition setup pictures [Re: Black Rocket]
OK, I'll be the devil's advocate here. Unless you're participating in competitions(racing), all that MSD and other aftermarket stuff is a waste of money. You're Factory HEI ignition is fine and will do all you need/want(yes, the CCC will work fine too, even for built engines to a point), but it's your money!! Most of those parts are made in Mexico or China now!
#1072065 - 09/20/21 09:20 PM Re: MSD Ignition setup pictures [Re: Black Rocket]
nj
im hoping to finally do this in a few days.
where did you get the keyed 12 volt source from for the box?
#1072080 - 09/21/21 10:22 PM Re: MSD Ignition setup pictures [Re: Black Rocket]
nj
there is a hotwire that works off of the key that goes to the power side of the hei coil but dont you still need that one for the coil?where can i grab a second one from?
Page 2 of 2 1 2
500/thumbs/signature71.jpg
by toddztoyz
500/thumbs/Monte_overlooking_river.JPG
by Ricks88SS
560/thumbs/MM_05_23.jpg
by NYmonteSS
500/thumbs/DSC_0014.JPG
by wanadrv
1188/thumbs/4_-_Copy.jpg
by mclellan83
