#423114 - 03/24/07 04:18 PM MSD Ignition setup pictures
Black Rocket Offline
MN
i just got a full MSD ignition put in yesterday but we just temporarily mounted it under the hood for now just to see what the dyno numbers were. now that i know im keeping it i want to wire it up to make it look nice under the hood. does anyone have any pictures of how or where they mounted their MSD box and blaster coil?
#423116 - 03/24/07 04:26 PM Re: MSD Ignition setup pictures [Re: Black Rocket]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
These are not the best pictures, the core support is not in, but I mounted my ignition box (I have a Crane) on the pass side front core support on a custom made alum bracket. It is away from the engine compartment heat, and harm.
1987 Monte Carlo SS Aerocoupe "Pro Touring", 436ci All Alum. SBC, 18 Aluminum Heads, 700R4, 3000stall, Ford 9 inch, 3.90 gears, 620 H.P., 590 FT LBS Torque. E.T. 11.229 @ 123.62 on motor. 10.213 @ 137.58 NOS (10/02/2010)!
www.protouraero.com
#423117 - 03/24/07 04:32 PM Re: MSD Ignition setup pictures [Re: ProTourAero]
MN
did you have a blaster coil also? i dont know how far away from the distributer the coil can be, otherwise i could mount it right next to the box in the front core also
#423133 - 03/24/07 06:46 PM Re: MSD Ignition setup pictures [Re: Black Rocket]
Z65_Paul Offline
Z65_Paul  Offline
McDade, TX
I mounted my MSD 6AL on the driver's side fender:
#423139 - 03/24/07 07:35 PM Re: MSD Ignition setup pictures [Re: Z65_Paul]
Aeroaddict Offline
Aeroaddict  Offline
Fairfield County ,CT
You dont nessesarly have to mount the box/coil under the hood.
I hid everything under the dash and ran the wires through the firewall. Its much cleaner and it keeps everything away from engine heat.
#423141 - 03/24/07 07:41 PM Re: MSD Ignition setup pictures [Re: Aeroaddict]
MN
Z65_Paul: i like how you have that set up..i'll take a look at mine to see if i can do the same.
aeroaddict: where exactly did you mount your stuff under the dash - i have a hard enough time keeping all the other wiring down there hidden and neat
#423170 - 03/24/07 10:13 PM Re: MSD Ignition setup pictures [Re: Z65_Paul]
Bri86SS Offline
Bri86SS  Offline
Phila, PA
Exactly where I put mine at.
Brian
#423182 - 03/24/07 11:06 PM Re: MSD Ignition setup pictures [Re: Bri86SS]
Aeroaddict Offline
Aeroaddict  Offline
I installed the box and coil againts the inside firewall on the trans hump. I did rip out all the HVAC ducting which help find some room.
I mounted the coil through the firewall and Im running the wiring through the wall as well to the distributor.
I have pics somewheres, email me, and I will send some to you.
#423715 - 03/26/07 04:38 PM Re: MSD Ignition setup pictures [Re: Aeroaddict]
QuikZilver Offline
QuikZilver  Offline
Delray Beach,FL
My box is the same place as Paul's. Coil is mounted on the firewall, near distributor, between valve cover and brake booster on driver side.
1986 Monte Carlo SS - lots done to it! And more to come!!
2007 GMC Yukon XL
#426337 - 04/02/07 04:34 PM Re: MSD Ignition setup pictures [Re: QuikZilver]
Joe87monteSS Offline
Memphis,TN
Currently I'm using the stock ZZ4 HEI coil. But I will add an MSD coil later.
Joey
Engine/head builder/machinist
2004 Silverado
Facebook
#426809 - 04/04/07 01:07 AM Re: MSD Ignition setup pictures [Re: Joe87monteSS]
Blackened Offline
Blackened  Offline
Ontario,Canada
I've never actually hooked up an ignition box. How do you go about it...what does it hook up to?? Is it something you need to do if removing the computer??
#426820 - 04/04/07 01:17 AM Re: MSD Ignition setup pictures [Re: Blackened]
MN
hard to explain it in a post but if you want to do some reading here is the instructions for the MSD ignition box i have (PDF file about 2.2Mb) MSD 6 Series Ignition Box Installation
#426853 - 04/04/07 02:11 AM Re: MSD Ignition setup pictures [Re: Black Rocket]
mysteriouSS88 Offline
Hazlet NJ
I mounted mine on a bracket that I made on the driver fender. it;s an L shaped bracket but when it's mounted the box looks like it's floating. all the wires wrap underneath the the box and go into the fender and then are all ran through there into the firewall. i'll post some pics tomorrow when i get them out
#426855 - 04/04/07 02:13 AM Re: MSD Ignition setup pictures [Re: mysteriouSS88]
Hazlet NJ
you can kind of see it in the corner of this pic here i'll find one of a close up tomorrow
#426861 - 04/04/07 02:19 AM Re: MSD Ignition setup pictures [Re: mysteriouSS88]
MN
that is one great looking engine bay mysteriouSS88! wow
#426959 - 04/04/07 10:45 PM Re: MSD Ignition setup pictures [Re: Black Rocket]
Hazlet NJ
ok i finally got the pic of my MSD all mounted sorry for the blurry pic. Blackrocket, thanks for the comments. unfortunately all of that is getting ripped out and getting redone...again but a lot better.
#427018 - 04/05/07 02:36 AM Re: MSD Ignition setup pictures [Re: mysteriouSS88]
1fastmonte Offline
1fastmonte  Offline
virginia beach
I would not put the box out ther they hate heat. heat is evey electric componets nightmare. the #1 reason for electronics to fail if heat
#427127 - 04/05/07 03:35 PM Re: MSD Ignition setup pictures [Re: 1fastmonte]
ssmnt408 Offline
ssmnt408  Offline
Michigan
I mounted mine to the back of my glove box, I can't seem to get the pic to upload to my computer..
88 turbo'd ss
#427369 - 04/06/07 12:16 PM Re: MSD Ignition setup pictures [Re: ssmnt408]
Big3 Offline
Big3  Offline
Lancaster, Ohio
My MSD6al is mounted exactly where the factory computer was .... under the pass. kick panel
87 MCSS Black w/Saddle
383 w/dart heads,Functional Goodmark hood.
700r-4, Gforce member,4.10s
1LE's w/Hotchkis uppers,2" drop & ZQ8's
#427378 - 04/06/07 01:24 PM Re: MSD Ignition setup pictures [Re: Big3]
Crusher Offline
Crusher  Offline
Jersey Shore
I mounted mine in the same place as Paul. You can see the top of the box in the picture...
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
637 RWHP 587 TQ
http://SSMonteCarlo.com
#427410 - 04/06/07 03:07 PM Re: MSD Ignition setup pictures [Re: Black Rocket]
Blackened Offline
Blackened  Offline
Ontario,Canada
Thank you for the link
#427419 - 04/06/07 03:24 PM Re: MSD Ignition setup pictures [Re: Crusher]
dns87ss Offline
dns87ss  Offline
Timmins, ON
I made a bracket and mounted mine in the fender behind the battery.
Here's a pic when I was installing my rpm heads. You can see the msd box in the top corner.
[img]C:\Documents and Settings\Owner\My Documents[/img]
black 87 SS,grey int,355, Edelbrock rpm intake and rpm heads,xe262,holley 600 vac,x-stream k&n,goodmark cowl, 18" Billet Specialties wheels, Nitto 245/45 and 275/40 tires, GN rear diff. Baer brakes 13"front, 12" rear, Street-Comp AFX front suspension
#427420 - 04/06/07 03:25 PM Re: MSD Ignition setup pictures [Re: dns87ss]
dns87ss Offline
dns87ss  Offline
Timmins, ON
sorry no pic...it's been a while since I did this...trying to figure it out
#427425 - 04/06/07 03:36 PM Re: MSD Ignition setup pictures [Re: dns87ss]
dns87ss Offline
dns87ss  Offline
Timmins, ON
[img][/img]
#427426 - 04/06/07 03:36 PM Re: MSD Ignition setup pictures [Re: dns87ss]
dns87ss Offline
dns87ss  Offline
Timmins, ON
There we go...just a bit slow..lol
665/thumbs/GUAGES.JPG
by MOSTWANTED
500/thumbs/Monte_Teardown_030.jpg
by kpetry
1096/thumbs/photo_17_.JPG
by 83/84/86*2/87ss
500/thumbs/ss_at_dyno1_small_file.jpg
by kahlua1836
by ray396
