#328594 - 10/22/03 05:02 PM mini tub, minus the four link, to stance 335's
**DONOTDELETE**
Unregistered
Guest
Unregistered
I have an 81 Monte cl, and its been a project for some time. It went from a straitline care with the bare minimum, and is slowely being changed into more of a driveable scca car. I have been
trying to decide on how to minitub the car and at the same time ditch the 4 link, and retain the original trailing arm mounts (nothing has been cut out) My goal is to fit 335 on 17's. any ideas or pictures of this type of chassis work
id really like to see. Thanks
#328595 - 10/22/03 06:18 PM Re: mini tub, minus the four link, to stance 335's
Dom87SS Offline
Dom87SS  Offline
Lake Villa, IL
why do you want to rid your self of the 4-link? and what are you planing on putting in there instead of a 4-link?mini tubbing is not hard if you can weld. cut thw old wheel wells out, and weld some new ones in. you can notch the frame rails to almost paper thin, but make sure you have some type of cross bracing between the two frame rails. a friend of mine has tubs, and very notched frame rails on his bu, the frame itself is no more than a 1/4in thich but the car go straight in the 8's cause of the bracing and suspension.
1987 Monte Carlo SS - 2006 GXP
http://drd-photos.smugmug.com/
#328596 - 10/22/03 11:20 PM Re: mini tub, minus the four link, to stance 335's
Marcus Offline
Authorized Vendor
Marcus  Offline
Authorized Vendor
PA.
You can section the frame so that it`s flush with the inner wheel wells,open up the radius of the ends of the wheel wells and fit 315s on 10 wheels with perfect backspacing. There are some pics of this mod on the Your SS forum posted by jwz87 (I did the job at my shop BTW \:\) ). 335s will leave the frame one layer thick and very weak,to do it right you`ll have to hack the rails off and backhalf it. Are you planning on swapping in torque arm,3 link or something else? Marcus
--Savitske Classic & Custom--
Cutting edge suspension & brakes
--Author of "How to Make Your Muscle Car Handle"--
www.SCandC.com
sales@scandc.com 610-381-6100
#328597 - 10/23/03 02:10 AM Re: mini tub, minus the four link, to stance 335's
Minotaur15 Offline
Minotaur15  Offline
Neptune NJ
Go for a truck arm. ;\)
Dan - minotaur15@hotmail.com
'86 MMC Road Course Ready
#328598 - 10/23/03 05:49 AM Re: mini tub, minus the four link, to stance 335's
SStavin Offline
SStavin  Offline
North Chicago burbs,IL.
Hey jay. Bout time you started hangin out with us on the MCSS.com board! Were you thinking of something along the lines of this? Notched Frame This tech guide came from gnttype.org Theres some pretty good stuff on there.
#328599 - 10/23/03 06:09 AM Re: mini tub, minus the four link, to stance 335's
SStavin Offline
SStavin  Offline
Also found this link from John B... Notched Looks really good. Lots of info on that post. I think he can fit 315's on there now?
500/thumbs/th_069-1.jpg
by MikePEI
500/thumbs/Copy_of_engine.jpg
by 555ss
883/thumbs/rust_1_x2.jpg
by DSMonteSS
500/thumbs/monte_carlo4.jpg
by hotrodmc
500/thumbs/SS_for_sale_1.jpg
by 86BAM
Rob Forbes
