OP
Posts: 2,180 |
Subject:General Wheel/Tire Fitment and Suspension Guide. Since these questions arise quite often, we have decided to put together just a general overview of the basic suspension and wheel upgrades owners of 78-88 G-bodies commonly make. We have tried to outline the most common wheels sizes, and as such, anything over 17" diameter and 9" width will not be discussed. Disclaimer: No guarantee of fitment is made or implied. Each car is different, and you should take the time to carefully measure YOUR car to make sure the chosen wheel will fit without interference. As the title says, this is only a general fitment guide. Also, the owner, administration, staff, membership nor anyone else affiliated with www.montecarloss.com assume no legal liablity implied or otherwise for the content in this guide. Use at your own risk! Wheels & Tires The stock 4th Generation Monte Carlo SS wheel is 15 x 7", a 5 on 4 3/4" bolt pattern, and 3.75" backspacing. The SS was outfitted with 215/65-R15 tires from the factory. The following are recommended backspacings for a variety of wheel sizes, followed by the recommended range of tire sizes according to www.tirerack.com in italics, overall height of the tire in parentheses. Realize that the overall height of the tire will have an effect on speedometer and mileage readings. See The Tire Size Calculator to determine the percentage error of your speedometer with non-stock sized tires. Follow this link for John Bzdel's excellent diagram explaining the various terms commonly used in tire/wheel discussion. Click here for a great tire math website. -Thank you to Larry (whitess) (Added 2/18/04)Please note: Rubbing or other interference problems may occur with non-stock wheels/tires, especially extremely wide tires. This problem can usually be remedied with the use of a steering box with shorter stops, either the XH F-body box or other aftermarket boxes.<blockquote> For 15" wheels: <blockquote> 15 x 7": 3.5 - 4.0" B.S. - 215/65-R15 (26.0")
- 225/60-R15 (25.6")
- 235/60-R15 (26.1")
- 245/60-R15 (26.6")
15 x 8": 3.5 - 4.0" B.S. - 225/60-R15 (25.6")
- 255/60-R15 (27.1")
- 265/50-R15 (25.5")
- 275/50-R15 (25.9")
15 x 9": 4.0 - 4.5" B.S. - 255/60-R15 (27.1")
</blockquote> For 16" wheels: <blockquote> 16 x 8": 3.75 - 4.0" B.S. - 225/60-R15 (24.9")
- 245/50-R15 (25.7")
- 255/50-R15 (26.1")
- 265/50-R15 (26.5")
16 x 9": 4.0 - 4.5" B.S. - 255/50-R15 (26.1")
</blockquote> For 17" wheels: <blockquote> 17 x 8": 3.75 - 4.0" B.S. - 235/40-R17 (25.3")
- 245/40-R17 (24.7")
- 245/45-R17 (25.6")
- 255/45-R17 (26.1")
17 x 9": ~4.5" B.S. - 255/45-R17 (26.1")
- 265/40-R17 (25.3")
- 275/40-R17 (25.7")
</blockquote> </blockquote> Springs and Shocks This is only a partial listing of available springs and shocks available for the G-body. We have tried to gather part numbers for the most commonly used spring/shock combos. Most part numbers taken from www.jegs.com . Part numbers may vary by vendor. Check before you order to ensure that you have ordered the correct spring or shock for your application. <blockquote> Springs: - Eibach - 363-3803-140</font>
- Hotchkis - 515-1902F & 515-1902K (1" drop)</font></font>
- Edelbrock - 350-5230
- Moog - See Jeff Davidson's Moog Spring Chart for part
numbers as well as exhaustive specs. Shocks: - Bilstein - B36-0949 (F) & B46-0929 (R)</font>
- Edelbrock IAS - 350-3377 (F) & 350-3477 (R)</font></font>
- Belltech Nitro Drop - 146-7012 (F) & 146-7517 (R)
- KYB - KG4513 (F) & KG5548 (F) - Thanks to Zack (ZMonte85)
- Monroe Sensa Trac - MNR 5840 (F) & MNR 5802 (R)
- Competition Engineering - ???
</blockquote> Brakes By far, the most popular major suspension upgrade is the "Big Brake Swap." This swap consists of either Global West, Hotchkis, or UB Machine upper control arms, spindles and calipers from a '77-'96 B-body, 1LE or comparable rotors, B-body master/booster or G-body dual diaphragm booster, and assorted hardware. For an excellent write up on the 12" Brake Swap, reference one of the following links: <blockquote> </blockquote> Frame Braces As you may well know, the stock G frame isn't very rigid. Simple, but extremely effective, handling mods is the addition of frame bracing. Some have chosen to fabricate their own, and various braces can be pulled from Pontiac Grand Prixs. Marcus, an authorized vendor on this site, makes very nice custom bars for the G chassis. Contact him for more information. Here are some words from Larry (whitess) concerning some of the braces on his car. (Added 2/18/04) I just put on the Frame braces that Mark sells, both front and rear, and even with stock size wheels and tires (even got snows on the back!), the improvement is amazing. As I'm sure you've noticed the tires can only do so much if the frame/body is twisting around. I did the front bar first so I could see the difference. Turning was vastly improved because the frame ends were tied together and it allowed the steering to be more responsive.
I had to re-teach myself to change lanes at hwy speeds with this car!? I put the rear one on this last weekend and went for a drive this morning on a back road that has a couple of
90*/30 mph turns at a about 45 mph. Didn't slide and very little lean. Still a little understeer but not much.
I'm running KYB shocks, stock springs and poly sway bar bushings. Not bad for a basically stock car. For other information not contained in this guide, see the Suspension Technical Section on this site. There are many excellent links detailing specific chassis components and modifications for the G-body. Q & A: <blockquote> Originally posted by lt1malibu: I was curious about the b-body spindle upgrade how much do we add to the back spacing to get the wheels back to wear they started It has been measured to be about 3/8" per side. It is slightly noticable, but will not cause problems unless your current wheels are extremely tight-fitting. Originally posted by 355 SS: I just had tires mounted Friday on stock 87 rims, and they measured 7.5,have my rims been modified, or are there two types? If you measure from inside lip to inside lip (where the tire comes in contact with the rim), it should be 7", assuming they are stock Originally posted by mymonte-ss: Will a 17 X 8 with a 4.5 inch offset work or will it rub on the outer part of the fender? 4.5" backspacing should be just fine. </blockquote> General Comments: <blockquote> Originally posted by lt1malibu: Thats alot of great info thanks Originally posted by 87_Monte_SS: This type of information is INVALUABLE, and is a great idea for a sticky post. Thank you so much! Originally posted by wykkidss: Awsome info here... Originally posted by cheese: thanks for the great info on tire sizes,it sure helped me Cheese Originally posted by Carman83SS454: Something that might be interesting is a good listing of the different factory F-body/Vette front wheels that will work on all four corners of our cars.
Scott This is a great idea, Scott. We will work on this list soon. Anybody with anything to contribute to this idea, please do so </blockquote>
86SS
OP
Posts: 2,180 |
Okay guys, in an effort to put together an exhaustive FAQ for the basic suspension/wheel/tire questions often asked here, we have started this "guide." Please realize it is in its infancy, and anything and everything any of you can contribute will be added. Please keep replies on topic and only to contribute to the guide.
Also, we realize that 275 is not the widest tire that has ever been put on a G-body. I know several people here are running 295s, and I'm sure somebody out there has a 3-- tire in the stock wheel wells. But that is severly streching the limitations of the fenders, and we do not recommend it.
If you disagree with anything posted here, by all means voice your opinions and it will be discussed.
Again, post any and all part numbers or other useful links you have and we'll add it.
Thanks again, Brandon
86SS
OP
Posts: 2,180 |
Alright, errors have been corrected and it's been updated, I think  Sorry for the long delay in updating this thing. We've given credit to those who have contributed part numbers and links. (Thank you  ) Also, I added a "Q&A" and "General Comments" section because I felt bad for just deleting everybody's posts. Any comments/questions/corrections you have, let us hear 'em. Also, Phil (phil240) or anyone, do you have the C.E. shock part numbers? Thanks again, Brandon
86SS
Posts: 2,875 |
Under the KYB shocks, you have an F for the rear shocks, the second number. Just thought I'd point it out so it doesn't confuse anyone.
This was definetly a good idea!
1985 Monte Carlo SS 178K and not stock 1987 Turbo T 33K and not stock either Member of GMMOC & SMCC #3 - Gone But Not Forgotten
20+ Year Member
20+ Year Member
Posts: 1,780 |
"the recommended range of tire sizes according to [url= http://www.tirerack.com"] http://www.tirerack.com"[/url] Are the sizes listed recomendations from tirerack or are they tried and true sizes known to work on our Montes? Also, It would be nice to differentiat between the front and the rear. In other words...Front, range of tire sizes,BS,rim size etc and the same for the rear.
Posts: 115 |
on the stock aluminum wheels for 86-88 ss's is there supposed to be more torque used to keep these wheels on these cars.in other words should i use a air impact gun on these wheels or can i just use my four way lug wrench.thanks for any help.
86 MonteCarlo SC-86MC4 20 years 211,000 miles 88 MonteCarlo SS-88MC4 96,000 miles.sold with regrets
Posts: 931 |
^^^ just make sure that you tighten them equally. ive never torqued my wheels, but i always triple check to make sure theyre equally tight.
1987 Chevrolet Monte Carlo SS Finally got the motor from the shop. Time to get to work!
20+ Year Member
20+ Year Member
Posts: 310 |
never use an impact, and always torque them. They call for 85, but I run 100 in the rears. They can be sensitive and warp rotors if over torqued.
Posts: 9,309 Likes: 3
20+ Year Member
20+ Year Member
Posts: 9,309 Likes: 3 |
Originally posted by SuprSlow: 235/40-R17 (25.3") 245/40-R17 (24.7")
Are you sure about this? Why would a 235/40 be taller than a 245/40? It is my understanding that the 40 means that the profile of the tire is 40% of the 235mm or 245mm respectively. Is this incorrect?
20+ Year Member
20+ Year Member
Posts: 2,498 |
To figure a tires diameter, here is the method.
Lets use 275/40/17 for an example. 275 is the metric cross section width of the tire. 40 is the heighth of the tire from the rim to the OD. This is a percentage of the tire width. 17, of course is the rim diameter.
So for this tire we take 275/25.4 to get the english width of 10.8". 40% of that is 4.3". So the diameter of this tire is 17" + 4.3" + 4.3" = 25.6".
I get so tired of hearing people say that they have 50 series tires, "they are wide!", wider than my 40 series tires. Not necessarily, depending on what the first number is. My 275/40/17 & 245/45/17 tires are about the same diameter.
Scot
Posts: 1,384 |
Originally posted by SSCarlo86: Originally posted by SuprSlow: 235/40-R17 (25.3") 245/40-R17 (24.7")
Why would a 235/40 be taller than a 245/40? It is my understanding that the 40 means that the profile of the tire is 40% of the 235mm or 245mm respectively. Is this incorrect? I think thats a typo it would seem to me 40% pf 245 would be more than 40% of 235...and you can use an impact if you have the special torque sockets that are meant for bolting up wheels
1988 Monte Carlo SS fully customizedm, cowl hood, Kandy paint w/ ghost flames, power sunroof, 24" rims 327 SB - SOLD 1986 Monte Carlo SS 350 create motor, cowl hood, shaved handles & trunk, power sun roof, digital dash http://youtu.be/aKZI0FhUP6U1984 H/O Cutlass lightning rods 8.5" rear LT1 and C5 brake conversion under way 24" rims
20+ Year Member
20+ Year Member
Scot good, thats exactly how I understood it. thanks Originally posted by Atl_Monte: I think thats a typo it would seem to me 40% pf 245 would be more than 40% of 235 my thoughts exactly. The only reason I ask is because I am looking into a set of 17X8's or 17X9's and I wanted a taller profile in the rear, which SHOULD result in a taller tire. Also... will a 17X9 fit in the rear without modification? I will already be modifying the inner fenders on the front because I want to lower it more than they will allow
20+ Year Member
20+ Year Member
So how bout them 17X9's?
Will they fit without notching the frame rails or any other mods?
20+ Year Member
20+ Year Member
Posts: 2,498 |
I currently have 17X9.5" Centerlines in the back with 275/40/17 tires. It is close but they clear.
Scot
20+ Year Member
20+ Year Member
Originally posted by Tunedss86: I currently have 17X9.5" Centerlines in the back with 275/40/17 tires. It is close but they clear.
Scot what backspacing are you running?
20+ Year Member
20+ Year Member
Just wanted to let everyone know that I managed to shove a set of 295/50/15's on the rear of my car with an 8" wide rim and they fit PERFECT. The were about 1/4" from the frame rails and right under the fender lip. Didnt stick out at all. And the car has belltech rear springs, so its lower than stock. I can get the back spacing off of them for anyone that is interested.
1 member likes this:
88ss408 |
15+ Year Member
15+ Year Member
Posts: 968 |
Would f-body spindles(70-78) with a 2" drop still be fine for the big brake swap? I was looking into the possibilities and found these and a coil over setup that is designed to replace stock GM parts which would allow you to adjust ride height. Would that be too much?
Posts: 84 |
on my 87ss im looking for 2in drop in front and rear..have 5660 springs, wheels looking to use 16x8 or 17x8 will i still have to use drop spindles???/
DOUG RICH
Posts: 872 Likes: 1
Posts: 872 Likes: 1 |
i learned today that 275/60/r15s will fit on an 8" rim.
1983 Monte Carlo SC Landau
88ss408 |
20+ Year Member
20+ Year Member
Posts: 1,618 |
Posts: 2,106 |
20+ Year Member
20+ Year Member
Posts: 1,618 |
Posts: 1,467 Likes: 1
Posts: 1,467 Likes: 1 |
For those that are also young and stupid...... 295/50/15's will fit on a stock 87-88 15x7 wheel just fine with stock suspension and a 5/16" spacer, and it is safe as I have just went on a trip to Texas and back with absolutely no trouble at all, which was 1400 miles round trip.
1988 MCSS 427 SBC and changing all the time   please use chyaitsbear@yahoo.com for email thanks
88ss408 |
Posts: 115 |
I'm not so young, but maybe stupid. Do you think a set of 275/60/r15's will fit under the car? I'm gonna try since I just bought a new set of four for $190. I got a suspicion I'll only be using two of them if any.
Posts: 1,173 |
^ 275's work fine on the rear. I have them on stock 86' Rims(I know dangerous, I didnt put them on)
John B has 275's up front!
Posts: 4,567 Likes: 2
20+ Year Member
20+ Year Member
Posts: 4,567 Likes: 2 |
Hi Folks, Here's an approximate rule of thumb I use for calculating rim width to keep the sidewall neutrally biased, and not bowed inward nor outward at the rim, relative to the tread area: Wr = Wt*[1-0.42*(AR/100)]+8.4mm (This should get you within about a half-inch of the correct value.) Where: Wr = rim width in mm (measured inside-to-inside) AR = tire Aspect Ratio (40,50,60,etc.) Wt = advertised tire section width (245mm, etc.) Remember that 1" = 25.4mm (exactly.) Example: I have a 265-50 R15 tire. What rim width should I buy? Wr = 265mm*[1-0.42*(50/100)]+8.4mm = 265mm*0.79 +8.4mm = 209.4mm +8.4mm = 217.8mm = 217.8mm*(1"/25.4mm) = 8.575" > ans.: a rim width of 8.5" or 9" should be viable. Best, MAP On edit: I've changed the AR factor from 0.44 to 0.42, to give better agreement with the data I have. As a sanity check, I also compared the recommended tire and rim sizes posted at the beginning of this thread, and they agree well with predictions from this formula. On further edit: The prediction you get from this formula probably won't yield a value which corresponds exactly to a stock rim width (as in the example cited here: you can't buy a rim that's 8.575" wide off-the-shelf.) This being the case, do you go wider or narrower than the indicated value? I believe that from a handling perspective, it's generally better to go wider. Here's why: as the car rolls in a turn, the wheel top generally tilts away from the center of the car's direction of turn. As the tire top tilts outward, the centrifugal force simultaneously acting on the wheel causes the rim to be pushed outboard with respect to the center of the tread area in contact with the ground. This lateral displacement between rim and tread causes a distortion of the sidewalls. If the rim is narrower than the tread area, then this lateral displacement causes the outboard sidewall to "want" to assume a more planar shape, while the inner sidewall "wants" to do the opposite and assume a more conical shape. In so doing, the outer sidewall "pushes down" on the contact patch, while the inner sidewall "pulls up" on the contact patch. The net result is a distortion of the tread area where the contact pressure is concentrated on the outboard side of the contact patch: the tire almost literally wants to "roll over" itself in a lateral sense. Such pressure concentration reduces total lateral traction. If the rim, on the other hand, is wider than the tread area, then the lateral displacement causes the inner sidewall to get more planar, and the outer more conical. In so doing, the inner sidewall "pushes down" in the tread area, while the outer sidewall "pulls up" on the tread area. This is the exact opposite, of course, of the narrow-rim scenario. The net result is that the tread area in contact with the ground is distorted in a way that tends to oppose that created by the outward tilting of the wheel overall. This counterbalancing effect tends to maintain uniform pressure across the contact patch, and so lateral traction is maximized. Hopefully the crude sketch below conveys what I'm trying to say (shapes, angles, and distortions have been simplified and exaggerated to increase clarity...) With further consideration given to how much each wheel tilts outward as a function of body roll, one can generally conclude that a solid live axle should probably have a neutrally-biased sidewall, while the front end should be biased toward a wider rim in relation to the tread area, with the difference in width: 1.) growing as the front roll center height decreases (relating to the matter of camber gain,) and 2.) diminishing as the car's roll stiffness increases.  Comments: 1.) Despite the optical illusion effect, both tread widths (and presumed advertised section widths) are equal. 2.) In the accelerated case, we have the angle of wheel roll, theta (which looks like a zero with a horizontal line through its middle,) which is a function of: the magnitude of centripetal acceleration a sub c; the car's roll stiffness; and the camber gain at that particular wheel as a function of suspension deflection at that wheel. 3.) Note that in the static case, the tread centerline is coincident with the rim's centerline. 4.) Note that in the accelerated case, because of centrifugal force, the rim centerline is displaced outboard of the tread centerline by a distance delta (which vaguely resembles a "six."). It is this displacement which fundamentally causes the kind of sidewall distortion shown here (again, simplified for the sake of clarity. Sidewall vertical compliance and its resulting deflection aren't even suggested in this sketch, for instance.) 5.) The displacement delta is roughly proportional to the centripetal acceleration, a sub c.
20+ Year Member
20+ Year Member
20+ Year Member
20+ Year Member
Very nice explanation MAP!
That explains how you came up with that tire width vs. rim width formula... I was at a loss at first as to how you did that.
20+ Year Member
20+ Year Member
Hi SSM,
Thanks! But truth be told, I never did explain how I got that formula, but rather the reasons why one would, or wouldn't, want to go with a higher rim width than what the formula predicts. The formula is only an approximation for the rim width that yields a neutrally-biased sidewall, i.e., one that ignoring the overall convex bulge of the sidewall viewed in cross-section, generally conforms to a plane, rather than to a frustum (frustum = section of a cone, from the Latin.)
If you or anyone else would be interested, I could post the derivation of the formula.
Thanks, MAP
20+ Year Member
20+ Year Member
Yes, I would be interested in seeing that. I thought you might have worked backwards from the geometry above to optimize a ratio between tire and rim width.
20+ Year Member
20+ Year Member
Hi SSM, Here's the derivation of the equation: Wr = Wt*[1-0.42*(AR/100)]+8.4mm  Thanks, MAP
Posts: 19 |
MAP's formula probably works well in a lot of cases. However,folks should know that tire and wheel manufacturers design to the standards of the Tire & Rim Association. TRA produces their guidelines with updates every year. So when you look up a tire size on a manufacturer's website, normally they show you the approved rim widths for a given tire. Set of formulas they use for rim width hasn't been published to the public that I have seen, though I do know that there is a series of "if/and" statements and is based largely on aspect ratio.
20+ Year Member
20+ Year Member
Hi FM, I found their website here: http://www.us-tra.org/traHome.htmBut for non-members, there's very little to see, and I admit that the price of admission is higher than my cost of curiosity. Anyone have an inside scoop? Thanks, MAP
Posts: 61 |
Here is a link I found helpful Wheel Technical Information Hope its useful to others as well
Posts: 693 Likes: 1
Posts: 693 Likes: 1 |
I have 275/60/15's on the rear of my 87, no problems with rubbing at all.
1987 Monte Carlo SS 355/200-R4 - Moser 12 Bolt/4.56 gears  CLICK HERE ^
88ss408 |
Posts: 3,015 |
Did you see the shiny area on your frame? If not, you will eventually...
20+ Year Member
20+ Year Member
Hi Folks,
Since I posted the formula for rim width (see a few posts back with drawing) about one year ago, I thought I'd offer an update.
I've used this formula and compared results with known data over the past year quite extensively; in fact, to a far greater extent than all of the times previous to the posting of said formula.
What I've learned is that the formula is considerably more accurate and general than I first suspected. This surprised me, since some of the presumed values of constants (in particular, that of "k",) were based on eyeball estimates of averages for many tires and many rims.
For the record once again, the equation is:
Where: Wr = rim width for neutral sidewall bias, in mm. (1in = 25.4mm exactly.) Wt = advertised tire section width, in mm. (e.g., 215,225,235,245,...) AR = advertised tire aspect ratio. (e.g., 40,45,50,60,65,...)
Best, MAP
Posts: 263 |
i have a 275/50/15 on the rear of my 85' with no probs.the car is lowered and without tailpipes.im liking this guide and look forward to using it when the time comes.
Posts: 693 Likes: 1
Did you see the shiny area on your frame? If not, you will eventually... Never, been that way for over two years now.
Posts: 622 |
Has anyone posted the Z-28/Trans Am/GTA wheel fitment to the Monte? I'm interested in the GTA 16" wheels that look like the GNX wheels and heard you need spacers to fit the rear wheels. also heard you can run front wheels on the rear and rear wheels on the front without any problem? anyone know for sure what needs to be done? Thanks, Dave
20+ Year Member
20+ Year Member
Posts: 1,618 |
when they say cross section arent they actuallt saying at the widest part of the bulge and not actually the tread width? i have 255r70 15s on the rear and 245r60 15s on the front of my 86 cl.the bulge in the 255s is wide but the actual tread width is kinda skinny
10+ Year Member
10+ Year Member
Posts: 1,242 |
John B has 275's up front! Holy mega bump... But why is it not safe on an 86 wheel but is on an 87-88?
Posts: 3,746 |
Has anyone posted the Z-28/Trans Am/GTA wheel fitment to the Monte? I'm interested in the GTA 16" wheels that look like the GNX wheels and heard you need spacers to fit the rear wheels. also heard you can run front wheels on the rear and rear wheels on the front without any problem? anyone know for sure what needs to be done? Thanks, Dave Fronts only on our cars, is what I've heard....Ask SSNinja (Dave)....thats what he's running I believe
20+ Year Member
20+ Year Member
Hi Folks,
A thread from 2/09 titled, "Your rim opinion," speaks of rim options for a 275mm-wide tire on an MCSS. Since this tire is about as large as can fitted on these cars, I thought the following post in that thread merits inclusion here:
"Hi Mike D,
About what rims I recommend - use the equation in the sticky. You'll just about always be right within a half-inch of the correct value.
Also, agree about going at least 17" with the rim to maximize performance options with tires. In the first decade of the 21st century, 17" is what 16" used to be in the '90's, and 15" in the 80's.
Next - with a 275 and an 8-1/2" to 9" wide rim, you'll be pushing the envelope to the very edge in terms of what's likely to fit on the car without rubbing. Rim backspacing will need to be exactly on the money, or you'll have problems. You'll also want to make sure the car body is centered on the frame.
If I were you, I would remove all four springs from the car and disconnect both sway bars. Make a tire/rim template that mounts to each hub just the way the actual rim would. The template will have a puck that represents the rim/tire radial cross-section. This puck gets mounted parallel to the hub's axis of rotation. The puck mounts in an adjustable way to the hub-mounting feature of the template, so you can mock-up and adjust backspacing as well as rim diameter. Obviously, you swing the template a full 360 degrees on the axle to sweep-out the full displacement of a real tire/rim. Making such a template is a snap - I made mine in about an hour with some 1/2" plywood and a block or two of simple wood. A C-clamp is used to adjust the puck position relative to the rest of the template, to explore different rim diameter and backspacing possibilties.
Once you get to this point, check for interference over the full range of suspension travel at each corner of the car. In addition, at the front, repeat over the full range of steering input.
Don't be surprised if you find that a 275 doesn't fit no matter what you do with the rim diameter and backspacing - you'll probably find at least one point of interference. At this point, you'll then have to judge the probability and severity of this occurence (I'm talking a DFMEA for you engineering types here,) and determine whether you could tolerate this. If the answer is "no," then your only easy option is a smaller tire - sorry. Or, if you're really, really determined: some serious surgery on the car."
Best, MAP
10+ Year Member
10+ Year Member
Posts: 60 |
I want to run a 24x12 wheel on a 365/15/24 tire in the back what are some good mods to do without hacking up the body.
Mini Tubbing?
Posts: 3 |
Only the car craft 12"brake conversion write up link is functional.
20+ Year Member
20+ Year Member
Hi Folks,
After watching questions on this forum about tires and rims for several years, it seems that all conform to just two simple cases.
CASE 1: I've got a RIM of a certain width (Wr) and a certain diameter (Phir). Question: What's the best size of tire to get?
Answer: You'll need at least one additional piece of information before you can proceed. Scenario A: I'm set on a particular tire aspect ratio (AR).
Then: Tire width = Wt = (Wr-8.4mm)/[1-0.42*(AR/100)] Tire OD = Phit = Phir + Wt*2*AR/100 Tire ID = Rim OD = Phir
Scenario B: I'm set on a particular tire OD (Phit,) probably because I want to keep speedometer calibration.
Then: AR = [100/(2*Wt)]*(Phit - Phir) Wt = (Wr-8.4mm)/[1-0.42*(AR/100)]
CASE 2: I've got a TIRE of a certain width (Wt,) a certain aspect ratio (AR,) and a certain ID (Phir.) Question: What's the best size of rim to get?
Answer: Wr = Wt*[1-0.42*(AR/100)]+8.4mm Tire OD = Phit = Phir + Wt*2*AR/100 Rim OD = Tire ID = Phir
A caution about rims: rim OD (Phir) and width (Wr) are measured at the mounting surface of the tire, and do not equate with the extreme width and diameter you would measure on the rim. A typical 17" x 8" rim would probably have an extreme OD of about 18.5" and an extreme width of about 9.2", for example. As always, use the conversion factor of 1" = 25.4mm (exactly,) since industry standards are persisting to keep units jumbled. You've got to keep units consistent within any given equation to get valid answers. And, the answers you get will rarely correspond exactly to something you can buy off the shelf. For instance, let's try a Case 2 example:
I've got a 245/45/17 tire. What's the best size of rim to get?
Plugging-in: Wr = 245mm*[1-0.42*(45/100)]+8.4mm = 207.095mm. Round to 207mm. Units conversion: 207mm*(1"/25.4mm) = 8.15" Tire OD = 17"+(245mm*1"/25.4mm)*2*45/100 = 25.68" Rim OD = Tire ID = 17"
Interpretation: the math tells us we need a 17" x 8.15" rim. Obviously, unless this is a custom rim, you can't get that width. Plus, the width equations aren't exact, but will almost certainly get you to the nearest half-inch. So what to do? 8" would work, but 8-1/2" would probably work even better, since it's usually better (see discussion previous posts) to go a bit wider than a bit narrower than what the equation would tell you for neutral sidewall bias. This is especially true for the front of the car.
Let's try another Case 2 example, and go back two posts to the person with the 365/15/24 tire. Is his desire to run a 24" x 12" rim a good idea?
Wr = 365mm*[1-0.42(15/100)]+8.4mm = 350mm = 13.8". Conclusion: a 12" rim is way, way off. Btw, even with the right rim, this is far beyond anything that mini-tubbing could afford unless you just let the wheels "hang out" and hope you never hit any big bumps. Tire OD = 24"+(365mm*1"/25.4mm)*2*15/100 = 28.31". Rim OD = Tire ID = 24"
Now, let's turn this into a Case 1-a question: I've got a 24" x 12" rim, and want to run a tire with a 15 aspect ratio. What tire do I buy?
Wt = (12"*25.4mm/1"-8.4mm)/[1-0.42*(15/100)] = 316.3mm. Get a 315mm tire. Tire OD = 24" + (315mm*1"/25.4mm)*2*15/100 = 27.72" Tire ID = Rim OD = 24"
Answer: I buy a 315/15/24 tire.
Best, MAP
20+ Year Member
20+ Year Member
Hi Folks,
Some further clarification. In case 1-b the equations seem to be largely reciprocal since they involve similar unknowns. They way to approach this is as follows:
1.) Use a first-guess for tire width (Wt) to get aspect ratio. 2.) Plug the resulting aspect ratio (AR) into the second equation to see if the resulting Wt matches the first guess. If yes, then stop. If no, then adjust Wt accordingly and plug back into the first equation. Iterate as many times as necessary to get convergence.
About having the rim to be wider than these equations would indicate, go back to roughly the middle of the thread to the post which shows a picture of how the tire gets distorted in a turn in the case of a rim that's too wide versus one that's too narrow for a full explanation.
Best, MAP
20+ Year Member
20+ Year Member
Hi Folks,
As time has passed and I've tested more and more tires against the equation I first posted, I've noticed that an improvement and refinement are probably called for.
The issue is the presumed nature of convexity in the sidewall bulge. The factor of 0.42 comes from the presumption that the transverse bulge of the sidewall is, on average, about 21% of the exposed sidewall height (see derivation a number of posts back.) But more recent tests have revealed that this fraction declines as we make the sidewall shorter.
That is, instead of k = constant = 0.21, it should probably refined according to:
k = a1 + a2*H, where "a1" and "a2" are two, new constants.
The refinement amounts to presuming that the sidewall bulge is not a linear function of H, but quadratic, and where a2 is negative. Once I have a more comprehensive study finished about this, I'll share.
Best, MAP
Posts: 10 |
Just picked up a set of 1987 aluminum 15 inch SS rims to put on my 1986 G body last night. Bolt pattern is correct, but this morning I noticed (1) that the SS rim mounting holes are much larger than on the stock steel wheels on my car, and (2) the mounting holes are not chamfered.
Is there a special nut available / required to mount the aluminum rims? Couldn't find this in the FAQs so ...........
Posts: 9 |
Hello Everyone,
I am looking to purchase 2009+ Corvette wheels. A couple of options I am looking into are:
Front 18x8.5in either +40 or +56mm offset 18x9.5in +56mm offset 19x9.5in +
Rear 19x10 either +40, +56 or +79mm offset 19x11 either +63mm offset or +73mm offset 19x12 +59mm offset
I'd like to fit as wide a tire as I can, but I would like to know is any of this possible? Would I need to do any mods? Mini tubs? If possible, what tires should I use? I searched and I could not find the answers I was looking for so any insight is greatly appreciated. This would be for an '87 SS BTW.
Posts: 12 |
I'm thinking about having some (Stockton) ralley wheels built for my SS 17x8 4.5 & 17x9.5 5 backspacing. Will be able to run them year-round........ Please help with feed back.
20+ Year Member
20+ Year Member
Hi Folks,
I have a small, but significant, refinement to report for calculating rim and tire widths. I was able to conform the refinement to something simpler than a quadratic fit, so it would remain easy to use on a calculator.
Then: Tire width = Wt = (Wr-8.4mm)/[1-0.42*((AR-5)/100)] Tire OD = Phit = Phir + Wt*2*AR/100 Tire ID = Rim OD = Phir Scenario B: I'm set on a particular tire OD (Phit,) probably because I want to keep speedometer calibration.
Then: AR = [100/(2*Wt)]*(Phit - Phir) Wt = (Wr-8.4mm)/[1-0.42*((AR-5)/100)]
Answer: Wr = Wt*[1-0.42*((AR-5)/100)]+8.4mm Tire OD = Phit = Phir + Wt*2*AR/100 Rim OD = Tire ID = Phir
I've got a 245-45/17 tire. What's the best size of rim to get?
Plugging-in: Wr = 245mm*[1-0.42*((40-5)/100)]+8.4mm = 217.39mm. Round to 217mm. Units conversion: 217mm*(1"/25.4mm) = 8.54" Tire OD = 17"+(245mm*1"/25.4mm)*2*45/100 = 25.68" Rim OD = Tire ID = 17"
Interpretation: the math tells us we need a 17" x 8.54" rim. Obviously, unless this is a custom rim, you can't get this exact width. Plus, the width equations aren't infinitely precise, but will almost certainly get you to the nearest half-inch. So what to do? 8-1/2" would probably work well. In cases of doubt, and especially when body roll plants the outer tire with positive camber, as is likely to happen mostly at the front of the car, go wider than the equation dictates. 9" at the front of the car should work quite well.
Let's try another Case 2 example, and go back several posts to the person with the 365/15/24 tire. Is his desire to run a 24" x 12" rim a good idea?
Wr = 365mm*[1-0.42((15-5)/100)]+8.4mm = 358mm = 14.1". Conclusion: a 12" rim is way, way off. Btw, even with the right rim, this is far beyond anything that mini-tubbing could afford unless you just let the wheels "hang out" and hope you never hit any big bumps.
Wt = (12"*25.4mm/1"-8.4mm)/[1-0.42*((15-5)/100)] = 309.39mm. Get a 305mm tire. Tire OD = 24" + (305mm*1"/25.4mm)*2*15/100 = 27.60" Tire ID = Rim OD = 24"
Answer: I buy a 305/15/24 tire.
Best, MAP
PS: It would make things a whole lot easier if I could paste a spreadsheet in here. Does anyone know if this can be done, or do I need to post a link external to the forum?
20+ Year Member
20+ Year Member
Hi Folks,
In case the eye-strain factor is overwhelming in the post above, just remember this one equation:
Wr = Wt*[1-0.42*((AR-5)/100]+8.4mm
The refinement compared to the previous expression, is that we now deduct 5 points from the aspect ratio when making the sidewall convexity correction. Predicted rim widths increase modestly as a result, and more so for the lower aspect ratios.
Best, MAP
Posts: 259 |
285/40/17 the ultimate rear 17' tire for g-body. has anyone made them fit w/ stock rear springs no lip rolling ?
Posts: 5,146 Likes: 1
15+ Year Member
15+ Year Member
Posts: 5,146 Likes: 1 |
285/40/17 the ultimate rear 17' tire for g-body. has anyone made them fit w/ stock rear springs no lip rolling ? Running 17x9.5 5" bs, Nitto 555 Extreme in 285/40/17, with a 5/16 spacer on both sides. A 4.75" bs would be best, as they are VERY close to the frame. I would not recommend for everybody, rear UCA/LCA bushings need to be in good shape, otherwise you will have light contact when you drive it hard. Front are 17x8 4.5" bs w/ Nitto 555 in 255/45/17, still running stock coils, new coils going on this summer along w front adjustable SPC LCA.  If you run it low, you will need to roll the rear fender lips, the lines on the tire are the tire design, not slices.
Posts: 259 |
wondering if a 8.5 or 9.0 rim width would suck the sidewall in to help this or does the 285 need a 9.5 min. rim width. when I put 275/50/15 on a 8' rim it looked bubbled on sidewall and probablly lost some tire contact patch as it needed a min 9.0' rim . A fine line...... a fine line
Posts: 332 |
How about 215-70R15 on the front and 255-70R15 on the back? I think they'd fit.
Sold my toy...
Posts: 570 |
How about 215-70R15 on the front and 255-70R15 on the back? I think they'd fit. Fit perfect, even lowered 3", with the right backspaced wheels. Ran this setup on my old '88 SS. Front: 15x6 with 3.5" backspace. 215/70-15 Rear: 15x8 with 4.5" backspace. 255/70-15
10+ Year Member
10+ Year Member
Posts: 3,827 |
Eric that looks amazing...it has the perfect stance and look. I like the 3 star center caps on the Welds. That is the first I seen anything like that done. By the way love the first name.
Eric
84 Monte Carlo SC 406 SBC 78 Monte Carlo 305 sbc SOLD 78 Monte Carlo Landua 350 sbc SOLD 81 Malibu Classic 350 sbc SOLD 84 Monte Carlo LS 350 sbc SOLD 84 Buick Regal 229 v6 SOLD
Posts: 332 |
It does look great!! Thanks for the response.
Sold my toy...
Posts: 570 |
It does look great!! Thanks for the response. Thanks! You are welcome. Eric that looks amazing...it has the perfect stance and look. I like the 3 star center caps on the Welds. That is the first I seen anything like that done. By the way love the first name.
Eric Thanks, Eric. Yeah, the 3 bar knockoffs was just something to be different. I miss that old car sometimes, but wouldn't take 100 on trade for my '86. Here is a short video of it: http://www.youtube.com/watch?v=1mSb-coZHyQYou can see that tire fitment a little better. You know, there was a lot of great men named Eric. Still is...... LOL! Great to meet you! ERIC
10+ Year Member
10+ Year Member
Posts: 3,827 |
Man Eric, your old 88 was awesome. That thing looked and sounded great. I may just need to copy that stance on it. I will send you a link to the way my Monte sounds with a 406 in it.
Posts: 570 |
Man Eric, your old 88 was awesome. That thing looked and sounded great. I may just need to copy that stance on it. I will send you a link to the way my Monte sounds with a 406 in it. Thanks, bud. My '86 has the exact same stance. A 3" drop on these cars seems to be perfect in my opinion. I think I have already heard that big 406 which sounds great! But, you can send me that link anyway.
10+ Year Member
10+ Year Member
Posts: 2,671 |
A few members have inquired so I thought I'd share some info-as seen in my sig., I run Impala SS wheels (funny story about those too) which measure out as a 17x9 wheel (5" BS) and I have 255/45/17 up front and 285/40/17 out back. Overall installed height is 28" in front and 28.1" in the rear-running Firestone Firehawk SZ50 EP series tires which have a stiff sidewall but a fairly soft tread compound-imo the best road racing style tire for the street. Full Hotchkis suspension allows me to run as tight as 1/8" at the rear frame and not have any rubbing issues. Car also sits 3" lower up front and 2.5" in rear-all custom parts-not many "catalog" parts on this car-mostly all GM components but from a variety of cars-at least 5 different cars that IO remember....lol. This car does everything extremely well-accelerates hard, stops quick and corners amazingly.
gbodyparts1234@yahoo.com
HARNESSWORX
Posts: 678 |
Would some c5 rims off a 99 vette work for a stock suspension monte? I do plan on lowering it eventually though.
The wheels are :
17x8 1/2 up front with 245/45/17 tires and 18x9 1/2 in the back with 275/40/18 tires
Posts: 20 |
I just bought an new set of 4, ZQ8 Chevrolet 16x8 with 5 x 4 3/4" bolt pattern with a 4 1/4" backspace. Looking for the widest tire I can get on the front and rear without modifying anything.
"84 ZZ4 posted pics earlier in this post of his tires: Front are 17x8 4.5" bs w/ Nitto 555 in 255/45/17 and 17x9.5 5" bs, Nitto 555 Extreme in 285/40/17, with a 5/16 spacer on both sides."
I like the height of 84 ZZ4 tires, so Im looking for a similar look of tire's for my 16's. 84 ZZ4 setup is just slightly to wide in the rear, because it would require lip rolling if I ever lowered the car 2in or 3in in the future(which I will). So, I need a tire that will not be as wide. I also want a slightly taller tire in the rear by 1 inch to 2 inches than the front. Any help or suggestions is greatly appriciated? Thanks
Posts: 20 |
So, on a 9" wheel at the rear, what will be the right offset? This is know in each wheel as the ET and on must of the brands measuere this in mm. So we know the Backspacing is 4-4.5" but what we really need to know is ths ET on the wheel for the rear and the ET for the front on 8" wide.
Posts: 20 |
This is what I´m talking about A stock 1985 SS wheel is a 15 * 7 et 10 mm With a 18 * 9 the et -15 mm The Inner clearence is the same and the outer Position is extended by 50mm Check it out in this web page http://www.1010tires.com/WheelOffsetCalculator.asp
20+ Year Member
20+ Year Member
Offset is the distance from the center of the wheel to the wheel flange (positive if the wheel flange is outboard of the centerline, negative if it is inboard.)
Backspacing is the distance from the wheel flange to the most inboard point of the rim, including the lip for the tire bead.
Width is measured from inside of the tire bead flanges, so an 8" wide rim typically measures 8.5" at it's widest point.
To convert from backspacing (BS, in inches) to offset (OS, in mm), knowing rim width (W, in inches):
OS(mm) = [(BS-0.25)-(W/2)]*25.4
conversely:
BS(in) = (OS/25.4)+(W/2)+0.25
25.4 is just the conversion from mm to in.
Posts: 190 |
looking at getting some new wheels and was wondering what is the most backspacing you can run without usuing spacers.stock suspension.looking at 16x7 for the front and 16x8 on the rear.
Posts: 2,080 Likes: 12
20+ Year Member
20+ Year Member
Posts: 2,080 Likes: 12 |
I had posted the “chart” below in another thread but thought it might be useful here. The measurements were taken utilizing stock upper and lower controls arms with drop spindles. The spindles won’t affect the sub-frame and fender clearances, but by raising the mounting point of the wheel two inches in order to give the body a 2” drop, 17” or smaller wheels with 4.5” backspacing (or more) can or will give clearance problems at the tie rod. I know it was extremely close on my SS (less than 1/8”) when using a 17x8 SLP ZR-1 wheel with a 4.5” backspacing. However, 1/2" more radius provided by an 18” wheel (compared to the 17” wheel I used for measurements) should give ample clearance at the tie rod for more than 4.5” backspacing – I have no idea of how much more. Basically it looks like clearance is tight, but good enough to run 245/45-17s and 245/40-18s on an 8” wheels with 4.5” backspacing. I know some have run a 255/45-17 and 255/40-18 tire on 8” wheels with 4.5” BS, but based on my measurements anything wider than a 9.8” section width is pushing things – don’t just go by the tire size since section widths vary between manufacturers and even lines of their tires. Some have reported rubbing with 245/40-18s with a 4.5” backspacing and others have not. There may be suspension differences at play, but I’d lean towards the differences in section widths and sidewall stiffness between brands of tires as the issue. It seems from the consensus of those that participated in the original thread containing the chart, 8” wheels with the more commonly available 4.5” backspacing give the appearance the tire is sitting in a little more than “optimal”, especially when running wider tires and wheels out back. It makes sense if you think about it – If you’re taking the tire as close to the edge of the fender lip as you can in the rear, if you don’t do the same for the front, the fronts could look a little sunken. If you’re running the same size wheel/tire front and rear (or slightly larger for the rear) this probably won’t be an issue. Also, if you’re dropping the front more than a couple inches, you may need the tire to set in closer to the sub-frame than the fender anyway. Looks aside, it appears an 8” wheel with a 4.25” backspacing will come close to centering the wheel in regard to sub-frame (under full lock) and fender lip clearance. As will an 8.5” wheel with a 4.5” BS, a 9” with a 4.75” BS and a 9.5” with a 5” BS. Technically, a 0.25” offset (bringing the center forward) is a negative 6.35mm (-6.35mm). The trend is to advertise offset and many advertise a -6mm and -7mm offset which is technically 0.236” and 0.276” respectively. I doubt that the few hundredths of an inch one way or the other will present an issue.
Posts: 1,854 Likes: 1
Posts: 1,854 Likes: 1 |
15x10 with 5.5 back spacing with 5/16 spacer 28x10.5 slick, notched to the seam and lip rolled. fits like a glove.
88 turbo'd ss
88ss408 |
Posts: 1,937 Likes: 3
15+ Year Member
15+ Year Member
Posts: 1,937 Likes: 3 |
Will a 275/40/17 fit under all four corners without rubbing on a 9 inch wheel with 4.5 in backspacing and -12mm offset? These wheels http://www.summitracing.com/parts/brw-997793445These tires http://www.summitracing.com/parts/bfg-31629
Posts: 90 |
Thought I would put this out there in case someone wanted to know Vision 143 Wheels - 18x9.5 w/ 5.25BS / 0mm Offset These pics are with no spacers, stock frame rails - about 1/4" of clearance to the rail (not the "LH" plastic thingy)
Posts: 22 |
great thread very helpful
20+ Year Member
20+ Year Member
Adding the image back: I had posted the chart below in another thread but thought it might be useful here. The measurements were taken utilizing stock upper and lower controls arms with drop spindles. The spindles won't affect the sub-frame and fender clearances, but by raising the mounting point of the wheel two inches in order to give the body a 2" drop, 17" or smaller wheels with 4.5" backspacing (or more) can or will give clearance problems at the tie rod. I know it was extremely close on my SS (less than 1/8") when using a 17x8 SLP ZR-1 wheel with a 4.5" backspacing. However, 1/2" more radius provided by an 18" wheel (compared to the 17" wheel I used for measurements) should give ample clearance at the tie rod for more than 4.5" backspacing but I have no idea how much more. ![[Linked Image]](https://i.imgur.com/y5CUsyC.png) Basically it looks like clearance is tight, but good enough to run 245/45-17s and 245/40-18s on an 8" wheels with 4.5" backspacing. I know some have run a 255/45-17 and 255/40-18 tire on 8" wheels with 4.5" BS, but based on my measurements anything wider than a 9.8" section width is pushing things. Don"t just go by the tire size since section widths vary between manufacturers and even lines of their tires. Some have reported rubbing with 245/40-18s with a 4.5" backspacing and others have not. There may be suspension differences at play, but I'd lean towards the differences in section widths and sidewall stiffness between brands of tires as the issue. It seems from the consensus of those that participated in the original thread containing the chart, 8" wheels with the more commonly available 4.5" backspacing give the appearance the tire is sitting in a little more than optimal, especially when running wider tires and wheels out back. It makes sense if you think about it. If you're taking the tire as close to the edge of the fender lip as you can in the rear, if you don't do the same for the front, the fronts could look a little sunken. If you're running the same size wheel/tire front and rear (or slightly larger for the rear) this probably won't be an issue. Also, if you're dropping the front more than a couple inches, you may need the tire to set in closer to the sub-frame than the fender anyway. Looks aside, it appears an 8" wheel with a 4.25" backspacing will come close to centering the wheel in regard to sub-frame (under full lock) and fender lip clearance. As will an 8.5" wheel with a 4.5" BS, a 9" with a 4.75" BS and a 9.5" with a 5" BS. Technically, a 0.25" offset (bringing the center forward) is a negative 6.35mm (-6.35mm). The trend is to advertise offset and many advertise a -6mm and -7mm offset which is technically 0.236" and 0.276" respectively. I doubt that the few hundredths of an inch one way or the other will present an issue.
Posts: 6 |
i just joined the forum since i just bought a 85 ss and i was looking to run a bigger rim and a wider tire since i plan on running a ls engine in the future the rim i was looking at was 17x8 with 4.5 bs the tires the recommended was a 235/50 i dont know how this would fit rubbing was in the front and rear if anyone could help me with this id be thankful
15+ Year Member
15+ Year Member
i just joined the forum since i just bought a 85 ss and i was looking to run a bigger rim and a wider tire since i plan on running a ls engine in the future the rim i was looking at was 17x8 with 4.5 bs the tires the recommended was a 235/50 i dont know how this would fit rubbing was in the front and rear if anyone could help me with this id be thankful I ran a 245/45/17 on a 17x8 with 4.5in BS with no rubbing at stock ride height. When I lowered it, I ran into some slight rubbing in the wheel wells and at the 12 o clock position of the wheel well.
Posts: 6 |
how much did you lower it
15+ Year Member
15+ Year Member
how much did you lower it it has 2 inch drop spindles, .5 inch taller lower ball joints which drop it another half inch, and coilovers. so a bit.
Posts: 6 |
well looking around at tires the 235/50 are supposed to be 9.3 inches wide but there all 9.7 i would think that would be to wide for the front i would think the rear would be fine what would be a good size tire for the front end i plan to drop the car a inch or 2 in the future i was thinking about running a 225/50 which is 9.2 inches wide im not sure what to do for front tires
20+ Year Member
20+ Year Member
well looking around at tires the 235/50 are supposed to be 9.3 inches wide but there all 9.7 i would think that would be to wide for the front i would think the rear would be fine what would be a good size tire for the front end i plan to drop the car a inch or 2 in the future i was thinking about running a 225/50 which is 9.2 inches wide im not sure what to do for front tires As Pez indicated the 245/45/17 is a proven fitment for the front. If you want a square fit - same on all four wheels, the 245/45/17 is a good choice. Some run a 255/45/17 on all four corners without issue. I have 2" drop spindles and 1" drop springs on the front and a 245/45/17 with a 4.5" backspacing and with the wheels I have, the tie rod hits the inner rim but will clear with a 1/4" spacer. I'm going to sell them and get a 8" with a 4.25" backspacing (like the 17x8" N90s). If you're looking for a smaller tire on front and larger on the rear, the 225/50/17 on a 7" front and a 255/45/17 on an 8" rear would work and I'd think look pretty good. You could put a 225/50/17 on an 8" rim, but if I were going 8" on all four corners, I'd do the same size on all four tires, like a 245/45/17 to be able to rotate them. I think with the right offset you may be able to get a 26.3" tire on the front with a dropped suspension, but I've asked the forum before if anyone has run that tire on the front with a dropped suspension but didn't get a response.
Posts: 6 |
i was going to put baer breaks all the way around and run their spindles which add .4 to the width so i shouldnt have any clearance issues
Posts: 25 |
I am ready to purchase rims for my new car. I want 17 x 8 inch rims. I read through this thread and a few others but am a little confused on the recommendation for back spacing. Here is an actual link to the rims I am purchasing. If I go with 245/45/17 will that work for all 4 tires? And is the correct back spacing 4.75 (120.65)? They have these spacings available (Available PCDS: 5- 114.3, 120.65, 127). In this thread for 17 x 8 it is recommended 17 x 8": 3.75 - 4.0" B.S.? Your response is appreciated. Thanks http://voxxwheel.com/virtual-wheel-...el=Old%20School%20Chrome&color=Black
Posts: 6,034 Likes: 32
20+ Year Member
20+ Year Member
Posts: 6,034 Likes: 32 |
The tire contact point that touches first is usually the rearward side of the frame on my car. Also you need to check both sides for clearance. With a GM rear it's usually closer on the right side. I know you went 9". When clearance on fat tires is good on the inside the outer sidewall gets closer to the lips on the quarters. I've run BFG 255/50x16, Hoosier A6 275/45x16 and Hoosier GTP 11.50x27 tires on my car. The trick is to run the minimum clearance on the inside so the tire stays inside the opening, and never touches/rubs the frame. When the tire contacts the frame is when turning corners, straight ahead doesn't mean squat.
The section width of a tire mounted on a specific rim width can vary, more on a 9" less on an 8 1/2". The tire size you mentioned, 255/45x17 has a section width on an 8 1/2 rim of 10.0 give or take. The Comp 2 255/50x16 I run is 10.4 on an 8". The 275/45x16 A6 has section width of 10 7/8" on an 8, and the fat QTP 11.50x27x15 are a whooping 11 3/8". The QTP slicks will touch the frame if I corner the car, but who corners a tire with 12 psi and no real sidewall. They are inside the body line but i don't consider it pretty, just a drag race car look.
With what you are building i would think fatter in the rear is in order, like a 275/40. But the N90 wheels are only 8" and the 275 wouldn't be a good fit on that wheel width. Bob
Posts: 22 |
I noticed on the first page the recommended tire sizes for 16x8 and 16x9 are listed as r15. Am I missing something? I just purchased some 16x8 rallies and I wanna know my tire size choices.
20+ Year Member
20+ Year Member
Hi Jason,
No, you didn't miss anything, but the original poster for that sticky sure did 18 years ago! The entire 16" section is wrong. Here is the corrected version, which I'd recommend to a moderator to have corrected in the original:
225/60- R16 (26.6") 245/50- R16 (25.6") 255/50- R16 (26.0") 265/50- R16 (26.4")
Note that the tire OD is independent of rim width. As has been noted and lamented since at least a decade ago, pickings in the R15 and R16 tire range are very slim these days. R17 and especially R18 are now far more common.
As for the tire width and aspect ratio, go back to post #866662. A little bit of algebra is involved, but nothing that would stop a 9th-grader.
In the intervening 11 years since that post, I have still found no better overall fit than this key equation: Wt = (Wr-8.4mm)/[1-0.42*((AR-5)/100)]
Your question fits into Case 1. You must choose between scenario A or B.
HTH, MAP
