Posts: 90 |
Thought I would put this out there in case someone wanted to know Vision 143 Wheels - 18x9.5 w/ 5.25BS / 0mm Offset These pics are with no spacers, stock frame rails - about 1/4" of clearance to the rail (not the "LH" plastic thingy)
Posts: 22 |
great thread very helpful
Posts: 2,080 Likes: 12
20+ Year Member
20+ Year Member
Posts: 2,080 Likes: 12 |
Adding the image back: I had posted the chart below in another thread but thought it might be useful here. The measurements were taken utilizing stock upper and lower controls arms with drop spindles. The spindles won't affect the sub-frame and fender clearances, but by raising the mounting point of the wheel two inches in order to give the body a 2" drop, 17" or smaller wheels with 4.5" backspacing (or more) can or will give clearance problems at the tie rod. I know it was extremely close on my SS (less than 1/8") when using a 17x8 SLP ZR-1 wheel with a 4.5" backspacing. However, 1/2" more radius provided by an 18" wheel (compared to the 17" wheel I used for measurements) should give ample clearance at the tie rod for more than 4.5" backspacing but I have no idea how much more. ![[Linked Image]](https://i.imgur.com/y5CUsyC.png) Basically it looks like clearance is tight, but good enough to run 245/45-17s and 245/40-18s on an 8" wheels with 4.5" backspacing. I know some have run a 255/45-17 and 255/40-18 tire on 8" wheels with 4.5" BS, but based on my measurements anything wider than a 9.8" section width is pushing things. Don"t just go by the tire size since section widths vary between manufacturers and even lines of their tires. Some have reported rubbing with 245/40-18s with a 4.5" backspacing and others have not. There may be suspension differences at play, but I'd lean towards the differences in section widths and sidewall stiffness between brands of tires as the issue. It seems from the consensus of those that participated in the original thread containing the chart, 8" wheels with the more commonly available 4.5" backspacing give the appearance the tire is sitting in a little more than optimal, especially when running wider tires and wheels out back. It makes sense if you think about it. If you're taking the tire as close to the edge of the fender lip as you can in the rear, if you don't do the same for the front, the fronts could look a little sunken. If you're running the same size wheel/tire front and rear (or slightly larger for the rear) this probably won't be an issue. Also, if you're dropping the front more than a couple inches, you may need the tire to set in closer to the sub-frame than the fender anyway. Looks aside, it appears an 8" wheel with a 4.25" backspacing will come close to centering the wheel in regard to sub-frame (under full lock) and fender lip clearance. As will an 8.5" wheel with a 4.5" BS, a 9" with a 4.75" BS and a 9.5" with a 5" BS. Technically, a 0.25" offset (bringing the center forward) is a negative 6.35mm (-6.35mm). The trend is to advertise offset and many advertise a -6mm and -7mm offset which is technically 0.236" and 0.276" respectively. I doubt that the few hundredths of an inch one way or the other will present an issue.
Posts: 6 |
i just joined the forum since i just bought a 85 ss and i was looking to run a bigger rim and a wider tire since i plan on running a ls engine in the future the rim i was looking at was 17x8 with 4.5 bs the tires the recommended was a 235/50 i dont know how this would fit rubbing was in the front and rear if anyone could help me with this id be thankful
Posts: 1,937 Likes: 3
15+ Year Member
15+ Year Member
Posts: 1,937 Likes: 3 |
i just joined the forum since i just bought a 85 ss and i was looking to run a bigger rim and a wider tire since i plan on running a ls engine in the future the rim i was looking at was 17x8 with 4.5 bs the tires the recommended was a 235/50 i dont know how this would fit rubbing was in the front and rear if anyone could help me with this id be thankful I ran a 245/45/17 on a 17x8 with 4.5in BS with no rubbing at stock ride height. When I lowered it, I ran into some slight rubbing in the wheel wells and at the 12 o clock position of the wheel well.
Posts: 6 |
how much did you lower it
15+ Year Member
15+ Year Member
how much did you lower it it has 2 inch drop spindles, .5 inch taller lower ball joints which drop it another half inch, and coilovers. so a bit.
Posts: 6 |
well looking around at tires the 235/50 are supposed to be 9.3 inches wide but there all 9.7 i would think that would be to wide for the front i would think the rear would be fine what would be a good size tire for the front end i plan to drop the car a inch or 2 in the future i was thinking about running a 225/50 which is 9.2 inches wide im not sure what to do for front tires
20+ Year Member
20+ Year Member
well looking around at tires the 235/50 are supposed to be 9.3 inches wide but there all 9.7 i would think that would be to wide for the front i would think the rear would be fine what would be a good size tire for the front end i plan to drop the car a inch or 2 in the future i was thinking about running a 225/50 which is 9.2 inches wide im not sure what to do for front tires As Pez indicated the 245/45/17 is a proven fitment for the front. If you want a square fit - same on all four wheels, the 245/45/17 is a good choice. Some run a 255/45/17 on all four corners without issue. I have 2" drop spindles and 1" drop springs on the front and a 245/45/17 with a 4.5" backspacing and with the wheels I have, the tie rod hits the inner rim but will clear with a 1/4" spacer. I'm going to sell them and get a 8" with a 4.25" backspacing (like the 17x8" N90s). If you're looking for a smaller tire on front and larger on the rear, the 225/50/17 on a 7" front and a 255/45/17 on an 8" rear would work and I'd think look pretty good. You could put a 225/50/17 on an 8" rim, but if I were going 8" on all four corners, I'd do the same size on all four tires, like a 245/45/17 to be able to rotate them. I think with the right offset you may be able to get a 26.3" tire on the front with a dropped suspension, but I've asked the forum before if anyone has run that tire on the front with a dropped suspension but didn't get a response.
Posts: 6 |
i was going to put baer breaks all the way around and run their spindles which add .4 to the width so i shouldnt have any clearance issues
Posts: 25 |
I am ready to purchase rims for my new car. I want 17 x 8 inch rims. I read through this thread and a few others but am a little confused on the recommendation for back spacing. Here is an actual link to the rims I am purchasing. If I go with 245/45/17 will that work for all 4 tires? And is the correct back spacing 4.75 (120.65)? They have these spacings available (Available PCDS: 5- 114.3, 120.65, 127). In this thread for 17 x 8 it is recommended 17 x 8": 3.75 - 4.0" B.S.? Your response is appreciated. Thanks http://voxxwheel.com/virtual-wheel-...el=Old%20School%20Chrome&color=Black
Posts: 6,034 Likes: 32
20+ Year Member
20+ Year Member
Posts: 6,034 Likes: 32 |
The tire contact point that touches first is usually the rearward side of the frame on my car. Also you need to check both sides for clearance. With a GM rear it's usually closer on the right side. I know you went 9". When clearance on fat tires is good on the inside the outer sidewall gets closer to the lips on the quarters. I've run BFG 255/50x16, Hoosier A6 275/45x16 and Hoosier GTP 11.50x27 tires on my car. The trick is to run the minimum clearance on the inside so the tire stays inside the opening, and never touches/rubs the frame. When the tire contacts the frame is when turning corners, straight ahead doesn't mean squat.
The section width of a tire mounted on a specific rim width can vary, more on a 9" less on an 8 1/2". The tire size you mentioned, 255/45x17 has a section width on an 8 1/2 rim of 10.0 give or take. The Comp 2 255/50x16 I run is 10.4 on an 8". The 275/45x16 A6 has section width of 10 7/8" on an 8, and the fat QTP 11.50x27x15 are a whooping 11 3/8". The QTP slicks will touch the frame if I corner the car, but who corners a tire with 12 psi and no real sidewall. They are inside the body line but i don't consider it pretty, just a drag race car look.
With what you are building i would think fatter in the rear is in order, like a 275/40. But the N90 wheels are only 8" and the 275 wouldn't be a good fit on that wheel width. Bob
Posts: 22 |
I noticed on the first page the recommended tire sizes for 16x8 and 16x9 are listed as r15. Am I missing something? I just purchased some 16x8 rallies and I wanna know my tire size choices.
Posts: 4,567 Likes: 2
20+ Year Member
20+ Year Member
Posts: 4,567 Likes: 2 |
Hi Jason,
No, you didn't miss anything, but the original poster for that sticky sure did 18 years ago! The entire 16" section is wrong. Here is the corrected version, which I'd recommend to a moderator to have corrected in the original:
225/60- R16 (26.6") 245/50- R16 (25.6") 255/50- R16 (26.0") 265/50- R16 (26.4")
Note that the tire OD is independent of rim width. As has been noted and lamented since at least a decade ago, pickings in the R15 and R16 tire range are very slim these days. R17 and especially R18 are now far more common.
As for the tire width and aspect ratio, go back to post #866662. A little bit of algebra is involved, but nothing that would stop a 9th-grader.
In the intervening 11 years since that post, I have still found no better overall fit than this key equation: Wt = (Wr-8.4mm)/[1-0.42*((AR-5)/100)]
Your question fits into Case 1. You must choose between scenario A or B.
HTH, MAP
0 members (),
57
guests, and
13
robots. |
Key:
Admin,
Global Mod,
Mod
