#250331 - 08/25/03 11:05 PM Compression ratio question
chevelle502 Offline
chevelle502  Offline
Dundalk. MD
what is the highest comp. ratio you can have and still run todays pump gas? i was watching speed channel tonight and they said that the '62 vette, 327 had 11.25:1 comp. ratio. I thought that was a little high for pump gas? Also, what is a good streetable ratio for a 350 putting out about 450 hp? Thanks in advance. Chuck!!
Black w/T-tops
Mods: Jet stage 2 chip, 2.5" cat back with flow super 44's, K&N filter,extreme lid, chrome valve covers, custom interior from a 2003 Monte SS, 3.73 posi rear (waiting to install), re-built tranny, Elec fan setup, Msd Ignition, LED Headlights
#250332 - 08/25/03 11:18 PM Re: Compression ratio question
Gruvin Offline
Gruvin  Offline
Texas
10.0 to 1 or less on standard high octane pump gas with Iron heads(Aluminums can get another .8 to 1 point of CR on the pump gas).
I am pushng the limits with between 10.5/11 to 1 compression and Iron heads but I am going ot be running EFI which has way more spark and fuel tuning than a carb/HEI distrib have.
#250333 - 08/26/03 12:33 AM Re: Compression ratio question
lefty o Offline
lefty o  Offline
mpls,mn
i tend to agree with gruvin, for the most part. the other thing to consider is your cam- bigger cams tend to bleed off some cylinder pressure donw low allowing you to get by with a little more mechanical compression ratio.
bad black '87 SS, 474hp-355
#250334 - 08/26/03 12:37 AM Re: Compression ratio question
TooSlow406 Offline
TooSlow406  Offline
Friendswood, TX
There has to be more to it than just that. My Camaro had 10.5:1 and I had to retard the timing and run 93. If I ran any less it would spark knock. But I just saw a motor today on the dyno that had 11:1 on 93 with normal timing.
#250335 - 08/26/03 12:48 AM Re: Compression ratio question
littlelefty Offline
littlelefty  Offline
Lockport, IL
shane- the only thing i can say about that is that is not uncommon. each motor seems to have its own set of rules. no two are the same.
#250336 - 08/26/03 12:51 AM Re: Compression ratio question
Barney Offline
Barney  Offline
Radcliff, Kentucky
Don't make the static compression ratio the limiting factor, most of the time they are over rated anyway. Here is the biggest over-estimation, a stock 350 with flat top pistons and 76cc heads. Most people say 8.5:1 when in fact it is more like 7.8:1. Use the cranking psi keep all cylinders within 10% of each other and your good. 200psi cranking is max for the street and pump gas. Like Lefty O said the cam controls the bleed off which allows a higher compression ratio late. This is appearent by the cam grinders warnings like; this cam is to be used with 11:1 or greater static compression. I read an article in Chevy High Performance that tested a 13:1 compression motor on pump gas with no problem. I was running 12:5 slugs in my motor with 72cc heads for about 11:1 static with 190-195 psi cranking on pump gas with no problem.
Barney
Barney
88 MCSS, 427CI SBC, Dart Little M, Team G Intake, PBM Strike Force Heads, 950 Holley, Schoenfeld Headers, Coan Glide W/Brake & Coan 5500 Converter. Ford 9" full spool and 5.83 gears. Ladder Bar QA1's. 32X14 Hoosier's on 15"X15" Weld's.
#250337 - 08/26/03 12:56 AM Re: Compression ratio question
littlelefty Offline
littlelefty  Offline
Lockport, IL
again. no two are alike. sometimes i think their is no "normal" anything that applies to all motors.
#250338 - 08/26/03 01:41 AM Re: Compression ratio question
chevelle502 Offline
chevelle502  Offline
Dundalk. MD
thanks guys, every time i read about something i dont really know much aboout i figure its best to ask here!! The more i know, the better i can build my motor!! Thanks again.
Black w/T-tops
#250339 - 08/26/03 01:48 AM Re: Compression ratio question
Gruvin Offline
Gruvin  Offline
Texas
Barney
Good setup Barney, thats about perfect cranking pressure.
You can get away with more compression with polished chambers and piston tops.
Alot of good stuff here in this post.
#250340 - 08/27/03 02:59 AM Re: Compression ratio question
TooSlow406 Offline
TooSlow406  Offline
Friendswood, TX
What we need is for 114 race fuel to sell for .78 cents a gallon. Then we could all run 12:1 CR easily and afford it.
#250341 - 08/27/03 12:04 PM Re: Compression ratio question
supernova455 Offline
tampa, fl usa
I say YES to polishing the cumbustion chambers. I have noticed
a hug difference in pump gas freindlyness. My 70 455 has 10:1 from the factory. Before the rebuild (factory) it would ping and knock on 93. After the rebuild and polishing the chambers, I run 89 no problems.
Supernova455
500/thumbs/5_0_tpi_monte1.jpg
by toddztoyz
768/thumbs/l_20a13e1f37454cc5a688768866e100c9.jpg
by 396 MonteC
500/thumbs/parts3.jpg
by go3and8
500/thumbs/my_monte_carlo_-9-3-08_-bsr.jpg
by BENCHSEATRACIN
500/thumbs/monte510.jpg
by SeanSC85
