#21059 - 04/28/00 07:44 PM
Re: Water Leak on floorboard???
monte_383
hannibal, mo
i had that leak on my '81, the sealant between the heater&a/c box and the firewall was cracked. i took the lower windshield trim(about 4" wide) off, slapped on a generous dab of black RTV in the crack and that seemed to help. i don't think i got to the whole crack, some parts were hard to access, but i didn't have such a big puddle anymore.
'83 383 with ported Vortec heads, GW upper arms for the 12" discs in front. Custom aluminum dash with full compliment of Auto Meter guages and a little custom interior work.
#21061 - 05/11/00 04:39 AM
mrgoodwrench
Phoenix,AZ
Thanks for the info, I also have this problem and I also don't have T-tops. I will have to go out and try this fix tomarrow. Thanks Again.
------------------ 86 SS Stock L69 60,000 miles B & M Stage 2 Shift Kit Flowmaster 40's 3"high flow Cat 88 SS 120mph speedo K & N air filter
86 SS 80,000 miles Stock L69 KYB Shocks 88 SS 120mph Speedo B & M Stage 2 Shift Kit Flowmaster 40's 3"high flow Cat
#21063 - 05/11/00 08:11 PM
mssa87
South Carolina USA
Cue I am just wondering do you have an SS or other Monte Carlo? If your lower windshield trim is chrome its not a stock SS piece it should be black on the SS, and chrome on regular LS&CL models. All the trim on SS's are supposed to be black. I also have this same problem and need to check under that piece.
[This message has been edited by mssa87 (edited 05-11-2000).]
87 T-TOP AEROCOUPE 355 700R4 FULL MANUAL VALVE BODY 3000 STALL 8.5 4.10 GEARS 17x7 215-45-17 FRONT 17X8 255-5017 REAR CENTERLINE RHINO BILLET WHEELS CUSTOM WHITE PAINT BURGANDY TRUNK AND HOOD STRIPES BELLTECH SPINDLES AND REAR SPRINGS POLY BUSHINGS BOXED LOWER CONTROL ARMS ADJUSTABLE UPPERS
#21064 - 05/11/00 08:57 PM
Cue
Moderated by 85_SS, Dalt10, Gruvin, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, TPI Monte SS
by juan r
by BOHNZ
by 468beast
by Big Reazon
by TestMySS87
Rob Forbes
