#189353 - 05/05/04 11:41 PM
STICKY: Cruise without the ECM.. The Answers !!!!
85SSMan
Wichita, Kansas
Here is the scoop, I recently rebuilt my engine and like many others took out the computer harness, BUT, here is the difference, From what I gather alot of us are just pulling the sensors, and not cutting out the harness at the computer like I did. So for those of us that have cut the harness, and now have no Cruise Control fear not!!! The only thing that we need to fix is.. Find your buffer box, it is a small green box located behind the stereo(drivers side) there is a total of 7 wires coming out of it. Three are together coming out of the bottom (RED, GREEN, BLACK) these wires run to the VSS on the back of the speedo, GREEN is 12V, BLACK is Ground, and RED is the SIGNAL to the BUFFER. Next you will find two harnesses on the top off the buffer box, one SINGLE YELLOW wire, this sends the signal to the Cruise Control Module, also there is a 3 wire harness, this is where the BIG PROBLEM lies, PINK/W BLACK STRIPE wire is your 12V to power the VSS, BLACK/W WHITE STRIPE this is the GROUND, THIS WIRE USED TO GROUND TO THE COMPUTER HARNESS, THAT IS WHY YOUR CRUISE WONT WORK!!! CUT THIS WIRE AND GROUND IT WITH YOUR STEREO HARNESS. NOW YOUR CRUISE SHOULD WORK. Also has a brown wire, this can be ignored, it is the VSS signal to the computer. IF this doesnt fix your CRUISE after you have removed the computer harness let me know, I have been through this entire system and know it pretty well now, I am positive that I can diagnos your system, just try to be specific with your problem, and what you have done. Chris
 1985 Monte SS, Rebuilt L69 with TPI. 200-4R Tranny. 951 Modine with TPI duel fans. True 2 1/4 Flowmaster Duals. B.F.H. made dual hump crossmember. Stock Suspension, interior, and body. SOLD TO INTMDATR3 ON 03/04/06
#189354 - 05/06/04 02:23 PM
Re: Cruise without the ECM.. The Answers !!!!
jzajac1
MI usa
#189355 - 05/06/04 11:04 PM
Draxx'87SS
Lurker
Lurker
Not Here, USA
#189358 - 05/07/04 01:28 AM
Draxx'87SS
Lurker
Lurker
Not Here, USA
#189359 - 05/07/04 03:51 AM
200kSS
Bloomsdale, MO
I'll print this out and try it out on the Malibu. Right now I've got the computer and complete harness laying on the floorboard just so the cruise will work.
88 SS Black/Oxblood. Power Tour car 80 Malibu 2dr. Drag Week car
#189360 - 05/08/04 02:02 AM
85SSMan
Wichita, Kansas
200kSS, that should work for you if not let me know and I will try to help you out. why did you have to CUT your computer harness out? i pulled the whole thing out, without cutting any wires.
i had to cut all the wires that are in the dash harness that went into the engine compartment. The computer harness did unplug, I just thought I would rip it all out, but now starting to regret that. Chris
#189361 - 05/11/04 06:40 PM
84montecarloss
Cedar Falls, Iowa
thank you. will try this after i put all the stuff back on...took it off cause it diddn't work. thank's again u are a good man
1984 Pontiac Fiero 1979 Kawasaki KZ1000 2017 Camaro SS
#189362 - 05/11/04 09:26 PM
chevelle502
Dundalk. MD
this should also become a question on the FAQ section, very good info here.
1988 Monte Carlo SS Black w/T-tops Mods: Jet stage 2 chip, 2.5" cat back with flow super 44's, chrome valve covers, custom interior from a 2003 Monte SS, 3.73 posi rear (waiting to install), re-built tranny, Elec fan setup, Msd Ignition, LED Headlights http://chucks88ss.tripod.com/Montepics/index.album?i=1
#189363 - 08/14/04 01:13 AM
Draxx'87SS
Lurker
Lurker
Not Here, USA
#189366 - 08/14/04 03:24 PM
85_SS
Moderator 20+ Year
Moderator 20+ Year
Originally posted by speeddemon: Not to start anything but why not use the 78-80 style cruise that doesn't have the ECM? It's probably a matter of using what you have - and if I am reading that right, it is as simple as manually grounding one wire that the ECM used to ground
#189367 - 08/14/04 04:45 PM
Draxx'87SS
Lurker
Lurker
Not Here, USA
#189368 - 08/18/04 02:16 AM
baaboo
Racine, WI
How about this question for the experts, that I'm NOT! I put a TPI with a 7730 computer in my car. I needed the 4-pulse VSS. Any idea what is a good cruise control to use in the Monte body with the TPI computer and harness?
#189370 - 08/21/05 03:20 AM
realsurfer88
Tallahassee
before i start getting out blade and hacking up a perfectly good harness, i should ask if i can run this setup, the re grounded wire, on a ss with the ecm still in use. im pretty sure that everything else on the setup is perfect , vac lines, motor connector, everything, but i just want to know if this has the same effect on an ecm car. thanks guys Max
Super....scr3wduh at the moment..gah
#582051 - 06/29/08 11:10 PM
[Re: 85SSMan]
spudmanmike
Waterford, CT
I will know more when I finally get an LT1 for the beast. But I think I will try to keep the Stock cruise system. If you plan on going with a 4L60E or T56 where there is no mechanical speedo drive, its easy using a cruise control drive from an Impala or Caprice and the LT1s PCM. I think its a half dozen wires all together. I'll be trying this later this year with my car, which did not have factory cruise. It is completely feasible if running the mechanical speedometer to use the stock system as there is no hookup to the stock ECM, but that cruise assembly with the vacuum actuator is PLAIN UGLY!!!!!!
86 SS Iron-head LT1, 4L60E, GN 8.5" All self-wired/installed/programmed ZQ8's, Toyos, Blazer Brakes, Moog and SC&C, HRparts rear sway, ice cold A/C, too much to list.. 2011 Audi S4 Prestige, M6, Brilliant Red 1997 K3500 Masons Dump, 454/4L80E
#627743 - 12/04/08 01:30 PM
[Re: chevelle502]
bradleyls103
Imlay City, MI
this should also become a question on the FAQ section, very good info here. I agree!
Bradley
#634473 - 12/31/08 10:56 PM
[Re: realsurfer88]
Mikey340
Woodstock, IL
before i start getting out blade and hacking up a perfectly good harness, i should ask if i can run this setup, the re grounded wire, on a ss with the ecm still in use. im pretty sure that everything else on the setup is perfect , vac lines, motor connector, everything, but i just want to know if this has the same effect on an ecm car. thanks guys Max Pretty much same question. Mine is a 1985 body with an 87 motor and ecm. Cruise doesn't work have vacuum but no power at the connector on the side of the diaphragm? Mike
 Monte resto Here '85 Monte SS Bedliner Paint w/87 motor+trans, GTA rims,95 Formula seats(sold) '05 GTO 1977 Monte Carlo bedliner v2
#649956 - 02/17/09 07:54 PM
[Re: Mikey340]
WaSSted
Kennewick
Not only is my ECM gone, I also replaced the stock speedo with a mechanical Autometer speedo. In 2000 I purchased a VSS form jegsthatrun with hopes to reinstall my cruise and never got around to it. Turns out I got the wrong VSS so 9 years later I called JTR and they are sending me the correct parts for my VSS. My question, how do I wire it up? JTR told me that one wires goes to ground and the other goes to the VSS input. Where is the VSS input? The Haynes manual that I have is absolutly no help. So I managed to borrow the 1988 Monte Carlo electrical services manual (yes, I scanned every page into PDF format  ). So if you are like me and have aftermarket gauges and no ECM, you will need to ground the wire from the buffer as mentioned in previous posts and in the FAQ. In addition, the VSS from JTR has two wires; one goes to ground, I will go into more detail on the VSS wire. Now this is my theory, please correct me if I am wrong: From what I have learned, there are three wires in our cars that go from the buffer(green box) to the back of the speedo (where the factory VSS is located). You have a red positive, black negitive and green is the VSS signal, correct? I believe the green wire is what you need to splice the JTR speed sensor into. I will not know if this actually works until I receive my parts from JTR and install my heads. Maybe this weekend I will know if my theory is right or wrong.
Kirk Herres 86' SC/SS, 350 Vortec, Rpm intake & Cam, 750cfm Edlebrock Carb, 3" True Duals w/Flowmasters and DR. Gas X pipe, All Autometer Gauges, B&M Hammer Shifter, Accel wires & ign., and 3.73 Posi.
#653426 - 02/26/09 02:59 PM
[Re: WaSSted]
WaSSted
Kennewick
Ok, my cruse works! Yippee!
I got the VSS from JTR last weekend and installed it. It did not work at first, i hooked it up to the green wire coming from the stock VSS behind the speedo going to the buffer. The buffer is not required for this VSS to work, so I pulled the yellow wire from the buffer, cut the end off and wired it to the VSS, and PRESTO!
by SickSpeedMonte
by 86 monte carlo ss
by Chief Jimbo
by LXXXIV SS
by monteman251981
